I've just finished machining my instrument panel. It is (I say with
no small pride) nice. Milled out of 2024T3 3" thick, reduced to .120 with .120 webs between each instrument and around the perimeter. Now the question is: how should it be finished? Polished? Engine turned? Anodized? Clear powder coat? |
In Richard Riley wrote:
I've just finished machining my instrument panel. It is (I say with no small pride) nice. Milled out of 2024T3 3" thick, reduced to .120 with .120 webs between each instrument and around the perimeter. Now the question is: how should it be finished? Polished? Engine turned? Anodized? Clear powder coat? I think I would rather have a matte finish on mine, but ya gotta admit that Pat Fagan's engine turned panel is a thing of beauty: http://www.airbum.com/pireps/PirepPatFaganBH.html ---------------------------------------------------- Del Rawlins- Remove _kills_spammers_ to reply via email. Unofficial Bearhawk FAQ website: http://www.rawlinsbrothers.org/bhfaq/ |
On Sun, 01 Feb 2004 21:52:15 -0800, Richard Riley
wrote: I've just finished machining my instrument panel. It is (I say with no small pride) nice. Milled out of 2024T3 3" thick, reduced to .120 with .120 webs between each instrument and around the perimeter. Now the question is: how should it be finished? Polished? Engine turned? Anodized? Clear powder coat? Time to get the budget under control, Richard. Rust-o-Leum. Ron "It *is* a Fly Baby, ain't it?" Wanttaja |
Here's my experience with Anodizing. I liked it a lot.
http://www.eaa292.org/noon_patrol/dec_00/p1010006.jpg Richard Riley wrote: I've just finished machining my instrument panel. It is (I say with no small pride) nice. Milled out of 2024T3 3" thick, reduced to .120 with .120 webs between each instrument and around the perimeter. Now the question is: how should it be finished? Polished? Engine turned? Anodized? Clear powder coat? -- John Kimmel I think it will be quiet around here now. So long. |
Well, mine started out as just a plain piece of 0.125 aluminum and I used a
fly cutter to cut out the instrument holes and I went to Menards (Home Depot-like place) and bought countertop laminate to put over it. Drilled through a few instrument mounting screw holes and used machine screws and nuts to keep it in place and used a laminate cutting bit in my dremel to "rout" out the instrument holes. Worked really nice. Do not glue the laminate to the aluminum, just use the instrument and panel mounting holes to keep the laminate in place. I have an open cockpit plane, so laminate is good incase it rains while I'm at a fly in. -- Scott http://corbenflyer.tripod.com/ Building RV-4 Gotta Fly or Gonna Die "Richard Riley" wrote in message ... I've just finished machining my instrument panel. It is (I say with no small pride) nice. Milled out of 2024T3 3" thick, reduced to .120 with .120 webs between each instrument and around the perimeter. Now the question is: how should it be finished? Polished? Engine turned? Anodized? Clear powder coat? |
wrote: I've just finished machining my instrument panel. It is (I say with no small pride) nice. Milled out of 2024T3 3" thick, reduced to .120 with .120 webs between each instrument and around the perimeter. Now the question is: how should it be finished? Polished? Engine turned? Anodized? Clear powder coat? it all depends on whether you are building a hangar queen or an aircraft to fly. a matte surface in a medium dark green works pretty well. if you go with polished or a gloss surface try not to fly in bright sun or with the sun behind you. one will have you looking at high quality reflections of your shirt and the other might just blind you. btw crinkle finish black is a traditional crappy looking option :-) Stealth Pilot oz. |
wrote: I've just finished machining my instrument panel. It is (I say with no small pride) nice. Milled out of 2024T3 3" thick, reduced to .120 with .120 webs between each instrument and around the perimeter. Now the question is: how should it be finished? Polished? Engine turned? Anodized? Clear powder coat? A flat finish is helpful for reducing glare on an instrument panel, so I definitely would not go with polished. -Nathan |
3 inches thick down to 0.120 ??!!!
How long did it take to machine? Can you post a link to a photo? thanks Milled out of 2024T3 3" thick, reduced to .120 with .120 webs between each instrument and around the perimeter. |
"Richard Riley" wrote in message ... I've just finished machining my instrument panel. It is (I say with no small pride) nice. Milled out of 2024T3 3" thick, reduced to .120 with .120 webs between each instrument and around the perimeter. Now the question is: how should it be finished? Polished? Engine turned? Anodized? Clear powder coat? Alodine it and then put up a frilly little placard that says 24K. It would be reminiscent of you. |
Richard Riley wrote ...
I've just finished machining my instrument panel. It is (I say with no small pride) nice. Milled out of 2024T3 3" thick, reduced to .120 with .120 webs between each instrument and around the perimeter. Now the question is: how should it be finished? Polished? Engine turned? Anodized? Clear powder coat? After that much effort, why finish it off with the same methods used by every other aircraft on the line? You should go for something unique. Something that really sets your plane apart. Something that says "I just gotta be me!": http://panel.notlong.com Daniel |
| Thread Tools | |
| Display Modes | |
| Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 1 | November 24th 03 03:46 PM |
| Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 2 | November 24th 03 06:23 AM |
| Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 0 | November 24th 03 04:52 AM |
| Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart D. Hull | Home Built | 0 | November 22nd 03 07:24 AM |
| CAD outline of Rans S6S instrument panel? | Rob Turk | Home Built | 2 | October 21st 03 10:27 PM |
