The wet compass in my Cessna 150 has suddenly decided to indicate way off.
I took it off the dash mount and it reads nearly correctly when moved about 12" away from the instrument panel, and even better when out in the open by itself. I got another wet compass from a friend, and as I moved it near the instrument panel got the same effects. It's at least 40 degrees off and in some places like when held over the firewall its over 90 degress off. Nothing else has been done to the plane recently. Is is possible that something in the plane that has become magnetized and is affecting the compass ? Is there anything that can be done ? I pulled the nav-com out of the panel and it didn't seem to make any difference. All this is happening when the master switch is on or off, doesn't make any difference. |
Try this:
http://www.sacskyranch.com/degauss.htm Jim wrote: The wet compass in my Cessna 150 has suddenly decided to indicate way off. I took it off the dash mount and it reads nearly correctly when moved about 12" away from the instrument panel, and even better when out in the open by itself. I got another wet compass from a friend, and as I moved it near the instrument panel got the same effects. It's at least 40 degrees off and in some places like when held over the firewall its over 90 degress off. Nothing else has been done to the plane recently. Is is possible that something in the plane that has become magnetized and is affecting the compass ? Is there anything that can be done ? I pulled the nav-com out of the panel and it didn't seem to make any difference. All this is happening when the master switch is on or off, doesn't make any difference. |
I inherited/found/got a nice yellow, sturdy flashlight. Only problem was
the nice magnet in it somewhere that made random changes to the aforementioned whiskey compass. The nice yellow, sturdy flashlight is now on my work bench at home. Thx, {|;-) Victor J. (Jim) Osborne, Jr. take off my shoes to reply |
"Jim" wrote in message ...
The wet compass in my Cessna 150 has suddenly decided to indicate way off. I took it off the dash mount and it reads nearly correctly when moved about 12" away from the instrument panel, and even better when out in the open by itself. I got another wet compass from a friend, and as I moved it near the instrument panel got the same effects. It's at least 40 degrees off and in some places like when held over the firewall its over 90 degress off. Nothing else has been done to the plane recently. Is is possible that something in the plane that has become magnetized and is affecting the compass ? Is there anything that can be done ? I pulled the nav-com out of the panel and it didn't seem to make any difference. All this is happening when the master switch is on or off, doesn't make any difference. Sounds like you may need to have the aircraft demagnitized. A good shop should be able to do this for you. |
You have something in the aircraft that has become magnetized.
Look for magnetic flashlights or magnets added to oil filters or chip detectors on the oil pan. Got any head sets next to the compass? Have you changed the speaker for the radio? If the plane got struck by lighting it most likely is magnetized especially the crankshaft. Use the compass to find the source of the field. Move the compass around. Where you get the most deviation is the strongest field. This is very near the source of the problem. If you have a poor ground connection for the starter the current can flow some where else and magnetize some steel object that the current is flowing through. John On Fri, 09 Jul 2004 22:48:17 GMT, "Jim" wrote: The wet compass in my Cessna 150 has suddenly decided to indicate way off. I took it off the dash mount and it reads nearly correctly when moved about 12" away from the instrument panel, and even better when out in the open by itself. I got another wet compass from a friend, and as I moved it near the instrument panel got the same effects. It's at least 40 degrees off and in some places like when held over the firewall its over 90 degress off. Nothing else has been done to the plane recently. Is is possible that something in the plane that has become magnetized and is affecting the compass ? Is there anything that can be done ? I pulled the nav-com out of the panel and it didn't seem to make any difference. All this is happening when the master switch is on or off, doesn't make any difference. |
The compass in our Archer suddenly began reading 30 degrees off. A lot of
investigation eventually revealed that a small magnet that someone had riveted by means of a thin aluminum bracket to the center windshield bow in front of the compass, presumably to get it to read correctly, had become dislodged. Because of "springback" in the mounting plate, it was not possible to reposition it without first drilling out the rivet, so it was taped back in place. We will fix it properly when we get a chance, but for now, the small piece of duct tape is working fine. -- Bob (Chief Pilot, White Knuckle Airways) I don't have to like Bush and Cheney (Or Kerry, for that matter) to love America "Jim" wrote in message ... The wet compass in my Cessna 150 has suddenly decided to indicate way off. I took it off the dash mount and it reads nearly correctly when moved about 12" away from the instrument panel, and even better when out in the open by itself. I got another wet compass from a friend, and as I moved it near the instrument panel got the same effects. It's at least 40 degrees off and in some places like when held over the firewall its over 90 degress off. Nothing else has been done to the plane recently. Is is possible that something in the plane that has become magnetized and is affecting the compass ? Is there anything that can be done ? I pulled the nav-com out of the panel and it didn't seem to make any difference. All this is happening when the master switch is on or off, doesn't make any difference. |
| Thread Tools | |
| Display Modes | |
| Reading the whiskey compass | Ben Jackson | Instrument Flight Rules | 20 | February 28th 04 09:09 AM |
| How can a compass suddenly go out by 20 degrees? | Bob Chilcoat | Owning | 25 | February 21st 04 11:58 PM |
| Strange compass behavior | me | Owning | 10 | February 14th 04 05:24 AM |
| "Whiskey" for compass? | dale | Home Built | 10 | December 18th 03 12:16 AM |
| Vertical-card vs whiskey compass | Henry Bibb | Owning | 4 | August 18th 03 02:00 PM |
