I've heard that there is a way to get the "as shipped" parts list off
the web (or somewhere other than Lycoming). I am looking to get the list of parts contained within my engine when it left Lycoming's factory. Does anyone know how to get this, or do I need to work with Lycoming directly? TIA for any response. z |
On Mon, 23 Aug 2004 21:49:28 GMT, zatatime
wrote: I've heard that there is a way to get the "as shipped" parts list off the web (or somewhere other than Lycoming). I am looking to get the list of parts contained within my engine when it left Lycoming's factory. Does anyone know how to get this, or do I need to work with Lycoming directly? Unsure exactly what you mean. External accesories and configuration vary with dash number and airframe application. Internal parts are a real bitch. Part numbers (generic) you can get out of a parts manual (plan on some of them being superseded a couple of times). If it's a "factory" engine, you MIGHT be able to get a build sheet from Lycoming, you sure as heck ain't going to be able to get one anywhere else that I'm aware of. I've had to take apart waaaay too many engines to verify installed parts for AD's and SB's. It sucks. TC |
Essco sells "Parts Catalogs" for about $20.
http://esscoaircraft.com/level.itml/icOid/6983 I don't know if these are what you're looking for. Julian "zatatime" wrote in message ... I've heard that there is a way to get the "as shipped" parts list off the web (or somewhere other than Lycoming). I am looking to get the list of parts contained within my engine when it left Lycoming's factory. |
On Tue, 24 Aug 2004 15:17:43 +0000 (UTC), Aaron Coolidge
wrote: I thought that as a rule overhaulers listed exactly which parts went into each engine. Mind, my experience is limited to one overhauler (Pacific Continental Engines) and one engine (mine: O-360-A4A). I did not have the engine overhauled, but the build sheet came with the airplane when I bought it. It listed by manufacturer (Lyc, Superior, etc) and part number just about every component in the engine. With this I have been able to avoid AD notes on piston pins, con rod bolts, fuel pumps, etc. -- Aaron Coolidge (N9376J) I've got a list of parts that were replaced at overhaul, which is what I understand is required. The component in question was not changed at overhaul so I need to go back to the original build list from Lycoming. z |
Aaron Coolidge wrote in message ...
I thought that as a rule overhaulers listed exactly which parts went into each engine. Mind, my experience is limited to one overhauler (Pacific Continental Engines) and one engine (mine: O-360-A4A). I did not have the engine overhauled, but the build sheet came with the airplane when I bought it. It listed by manufacturer (Lyc, Superior, etc) and part number just about every component in the engine. With this I have been able to avoid AD notes on piston pins, con rod bolts, fuel pumps, etc. It's been a couple years since I've been exposed to a set of genuine Lycoming engine logs/docs. Hopefully they've gotten better, they used to be about the worst for not listing what you really want to see. The custom guys do a much better job. Lycoming does list specific SB compliance, but that doesn't do ya much good when new ones are issued. It's a sad fact that there are really no life-limited (and a lot of no s/n) items inside their engines, so technically there is no requirement for them to be listed. There are some mandatory replace-at-overhaul parts, but that's a little bit different. Essentially, if Lycoming makes a log entry with M/N, S/N, TT, TSOH, a "legal" description of the work performed, that's all they have to do. It hasn't been that many years ago that they provided no documentation for installed external accessories. Seriously. Once had a conference call with tech support at Lycoming with my principal FAA inspector listening in. He bounced me on a Pt 135 records check on a "factory" overhaul for no specific records for the magnetos, carb, and alternator. Lycoming's response was "as the OEM, we're not required to provide them". Not too long after, they started providing a build sheet with the status/detailed description of the externals. TC |
zatatime wrote in message . ..
TC - You hit the nail on the head. Trying to avoid needless (and expensive) work on my plane. The build sheet is what I'm after. I'll call Lycoming tomorrow. Thanks for the reply. You're welcome. About the worst one I've been exposed to was a specific s/n range bulletin. Had to yank all 12 jugs off of a customer's Navajo at 85 hrs SOH (not to mention 85 hrs after selling him the engines-about $75k) to verify that Lycoming put the right pocking piston pins in when they assembled them. Luckily, I've missed out on their more recent "problems". TC |
On Thu, 26 Aug 2004 04:49:20 GMT, zatatime
wrote: snip You stated in your other post that Lycoming "started producing build sheets" for their engines. This is what I need. I have asked for it from Lycoming and the tech rep said he needed to ask permission to send it to me This is 3 days ago. Do you have any ideas as to how to convince them they should/have to send it to me so I can verify compliance with an AD? In the AD text it specifically states to obtain a build sheet from Lycoming If you do I'd really appreciate the help. If not thanks for chiming in in the first place. Been out of touch for a couple days, hopefully you've resolved this with Lycoming. "ask permission" gag choke puke. I guess I would have told them that I own or operate the engine, and if the build sheet is not forthcoming via e-mail, fax, or express freight, I was planning to charter a Skyvan and drop the pocking thing through their durn roof. But then again, I've used that one once or twice during hostile warranty negotiation (pre-IX XI), so you might need to come up with a new method. TC |
| Thread Tools | |
| Display Modes | |
| rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | November 9th 04 04:47 PM |
| Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | October 2nd 03 04:07 AM |
| Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 4 | August 7th 03 06:12 AM |
| rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | August 1st 03 08:27 AM |
| Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 05:50 PM |
