Off I go to help with my first annual tell you all how today goes later this
evening. Lets hope for the best |
Brace for impact! ;-) (Bring money...lots of money...) -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
"Jay Honeck" wrote in message news:4iied.298956$D%.72910@attbi_s51... Off I go to help with my first annual Brace for impact! ;-) (Bring money...lots of money...) -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" Inspection is done it was not that bad only a few squawks total parts outlay so far $285.00 and $180.00 of that was in spark plugs Compression Cyl #1 78/80 Cyl #2 79/80 Cyl #3 78/80 Cyl #4 77/80 Tomorrow is a day of rest Sunday estimating another 5 hours to fix squawks. 1 Bad Spark Plug Totally Dead Not Firing On #3 Lower Also A 41 not a 40 2 EM-41's Replace With REM-40 Starter Bolts Not Safety Tied I Don't know how that was Missed on Pre Purchase and last Annual? Froze up pulley on elevator cable guide roller "barring was clogged with dirt/lint and grit cleaned lubed functions OK!" Front Strut & Shimmy Damper Needs Oil And Or Air Its a Little Low Fuel Cap Seals cracking need replacing. Gasulator drain tube broken & needs replaced Nut Plate & Seat Rail AD complied with. 4 cowling shock mounts need replacing. 2 have cracks 2 totally broken This was the forth set of eyes on this bird in 1 year she is getting a lot of attention. |
On Fri, 22 Oct 2004 20:38:48 -0700, "NW_PILOT"
wrote: 1 Bad Spark Plug Totally Dead Not Firing On #3 Lower Also A 41 not a 40 How'd you isolate this one? Were the plugs worn badly? z |
"NW_PILOT"
shared these priceless pearls of wisdom: - -Inspection is done it was not that bad only a few squawks total parts outlay -so far $285.00 and $180.00 of that was in spark plugs Didn't nobody never tell you about Aircraft Spark Plug Service in Van Nuys? $75 would have gotten you a complete set of overhauled plugs for a 4-banger. The drill is to send them your old plugs immediately after the annual and for about $50 a set they will overhaul YOUR plugs and send them back yellow-tagged. You then put them on the shelf for NEXT year's annual. -Starter Bolts Not Safety Tied I Don't know how that was Missed on Pre -Purchase and last Annual? I'd let the IA put the words in the logbook. It appears that English is not your primary language. See comment later about safety wire. -Froze up pulley on elevator cable guide roller "barring was clogged with -dirt/lint and grit cleaned lubed functions OK!" Too many words. "Elevator cable guide roller bearing (sta 132) frozen. Cleaned and lubricated bearing. Functional test OK. Nobody really cares what the bearing was clogged with. - - -This was the forth set of eyes on this bird in 1 year she is getting a lot -of attention. And three of them missed the starter safety wire? Without pulling the manual, I can't remember whether the starter bolts have lockwashers or whether they REQUIRE safety wire. Why do you think that safety wire is required? Jim Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com |
I didn't want to belabor the obvious. However, one certainly would have
suspected this, would one not? Jim "Jim Burns" shared these priceless pearls of wisdom: - 1 Bad Spark Plug Totally Dead Not Firing On #3 Lower Also A 41 not a 40 - -I haven't flown a 150 in over 18 years, but didn't you notice the dead plug -doing a mag check? Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com |
I haven't flown a 150 in over 18 years, but didn't you notice the dead plug doing a mag check? Jim --- Outgoing mail is certified Virus Free. Checked by AVG anti-virus system (http://www.grisoft.com). Version: 6.0.775 / Virus Database: 522 - Release Date: 10/8/2004 |
Jim Weir wrote:
Didn't nobody never tell you about Aircraft Spark Plug Service in Van Nuys? $75 would have gotten you a complete set of overhauled plugs for a 4-banger. The drill is to send them your old plugs immediately after the annual and for about $50 a set they will overhaul YOUR plugs and send them back yellow-tagged. You then put them on the shelf for NEXT year's annual. Paid alittle more than half that ($8 ea.) for a six banger from another. Will get the contact info if anyone is interested. Can't report on how well they perform (ordered 12) until they arrive, should be here this coming week... |
On Sat, 23 Oct 2004 12:09:04 -0500, Darrel Toepfer
wrote: Will get the contact info if anyone is interested Yes please. z |
No, you paid almost exactly the same. A four-banger is eight plugs, times $8 a
plug, plus postage on ten pounds comes up to about $75. Jim Darrel Toepfer shared these priceless pearls of wisdom: -Jim Weir wrote: - - Didn't nobody never tell you about Aircraft Spark Plug Service in Van Nuys? $75 - would have gotten you a complete set of overhauled plugs for a 4-banger. The - drill is to send them your old plugs immediately after the annual and for about - $50 a set they will overhaul YOUR plugs and send them back yellow-tagged. You - then put them on the shelf for NEXT year's annual. - -Paid alittle more than half that ($8 ea.) for a six banger from another. -Will get the contact info if anyone is interested. Can't report on how -well they perform (ordered 12) until they arrive, should be here this -coming week... Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com |
| Thread Tools | |
| Display Modes | |
| Annual Coronary | Jay Honeck | Owning | 19 | May 24th 04 04:47 AM |
| 1st Annual Sky Pup Litter Meet | Edwin | Home Built | 0 | May 23rd 04 06:16 PM |
| Annual Costs - Take the Pledge | Roger Long | Owning | 25 | February 1st 04 04:41 PM |
| Another Almost Annual Christmas Poem!!! | David Pincus | Home Built | 4 | December 28th 03 01:47 PM |
| Pre-Purchase Annual? | Paul Millner | Owning | 1 | July 4th 03 11:11 PM |
