Bob,
I'm figuring to get a bit more than 300 to 400 hours on my engine. And the cylinder heads? For the higher powered engines we have, a top overhaul after 400 hours is nothing unusual at all. With a 1800 or so hours TBO, if that ain't broken, I don't know what is. -- Thomas Borchert (EDDH) |
Thomas Borchert ) wrote:
And the cylinder heads? For the higher powered engines we have, a top overhaul after 400 hours is nothing unusual at all. With a 1800 or so hours TBO, if that ain't broken, I don't know what is. The IO-520 that was just removed from my Bonanza got somewhere around 2400 hours on it before a small crack in one of the cylinders put the first and last nail in the engine's coffin. Prior to the crack, the cylinders were all still producing excellent compression ratios. As far as I know, no overhaul was ever done on them. BTW, these were Continental cylinders manufactured in the late 80s. I certainly do not expect to have to perform a top overhaul on the new engine's Superior Millennium after 400 hours. -- Peter |
Thomas Borchert wrote: I'm figuring to get a bit more than 300 to 400 hours on my engine. And the cylinder heads? I expect to the cylinders to last to TBO as well. For the higher powered engines we have, a top overhaul after 400 hours is nothing unusual at all. I don't have a high power engine, just the 160hp O-320. With a 1800 or so hours TBO, if that ain't broken, I don't know what is. 1800 hours TBO is broke? Then we have different ideas of broke. note that I figure to reach calender TBO of 12 years before getting 2000 hours on my freshly overhauled engine. -- Bob Noel looking for a sig the lawyers will like |
1. Start at 0 degrees F with no fuss?
Although I have never tried to start my Lycoming 0360 at that temperature, it may very well start just fine. With expensive aircraft engines there is just too much wear with cold starts to do it. Get a preheat. Which leads to installed preheat devices and perhaps a pre-oiler That would satisfy my definition of "fuss". A more "turn key" power plant would do a lot to bring in more buyers. 2. Water cooling for dependable cabin heat? There is actually plenty of heat available from air cooled if they would just deliver it. A FAN would be a terrific new age idea. There would seem to be other ways to get more heat. Water cooling has other advantages and disadvantages. I see this as a solution not a benefit. 3. Automatic mixture control for altitude & power? With automation comes complexity. Personally I see no reason to automate this. How hard is it to lean to a temperature. All you need is a digital EGT. If you can reduce complexity for the pilot with little cost in other areas, its a plus. Less to do is more safety overall. 4. Automatic timing control? Great idea along with electronic ignition making hotter spark (capacitive discharge). Actually available from Unison now as an STC. Would seem to be a good feature. I just want to be confident that my engine is running properly and efficiently without my having to fiddle with it. 5. Jet fuel (availability)? I'll stick with gas, thanks. You can get it at out of the way airports. Availibility will likely solve itself. If the better engine runs on grapefruit juice, then you will start seeing grapefruit juice at the pumps. I just want to get away from 100LL and move to something cheaper which juice isn't likely to be ![]() 6. Piston (for economy)? Piston, Rotary, Nuclear, I don't care. I want it to work, and I want the guy at the airport to be able to fix it. 7. Choice of RPM at cruise for same power? Constant speed prop does just that. Yep I believe that delivering brand new airplanes with 1940s engines makes no sense whatever. Well, it actually does. Well, it do and it don't. Does it make sense for women in Afghanistan to wear Burkhas? We use Lycontinentals because we always have. Its a weird economic/technological hole we are in, and the only way out will likely cost much money. Although water cooling would allow closer tolerences and more power, you would have to have geared engine to prop because you need higher rpm to get the power. Again more complexity and more weight. Probably not worth it. One thing about the existing Lycosaurs and Contibrasaurus engines is they are simple. No emissions stuff, simple mechanical fuel injection or carburetion, simple mechanical magnetos. This all makes for reliability. Um, I have to disagree. I know all the reasons why we settle for the reliability we have, and I am all for simplicity. However, my Toyota is still a lot more reliable even if it is more complex. I know, I know, I know! Its not stressed to the limits like my Lycoming. So what! It has been improved to the point that it exceeds my needs. Those who keep making excuses for the engine industry need to just bite their tongues so they will get off their arses and improve. These engines are really all that bad. And they are light. If you look at car engines, they are heavier for given horsepower. And one thing we definitely don't need is heavier engines. Even though water cooling (or active oil cooling) would make more horsepower, I wonder if after the weight is considered if it would make more horsepower per pound of engine, which really is the key factor. That and reliability. A really good point, and why I don't care about how my engine is cooled, just that I start seeing improvement at greater than glacier speed. A fancy engine that quits or gives trouble with high maintenance is not an improvement. Thats true, but you are implying that anything new and better would be more trouble and maintenance. That is not necessily true. My Lycoming 0-360 has 2150 hours on it and has never needed service. Never even had the valve covers off. I have had to replace accessories. This is actually fairly typical if you do the oil changes and are careful about how you start and run the engine. Accessories are not seperate in my mind. And I think you are in the minority. Every starter, pump, or electrical failure is a power plant failure to me. Also, you have had an exceptional experience with what is the best example of current reliability (the 360). Why you find an engine that could quit due to carb ice as acceptable in the 21st century is beyond me. Much to our modern technology chagrin, the designers of these engines got a lot of things right. They work pretty damn well. I give them their proper and due respect. I thank them. Now, where is the next generation? Why are a bunch of people not content to travel on the ground content to see no progress in engine technology? |
"Dude" wrote in message ... Much to our modern technology chagrin, the designers of these engines got a lot of things right. They work pretty damn well. I give them their proper and due respect. I thank them. Now, where is the next generation? Why are a bunch of people not content to travel on the ground content to see no progress in engine technology? Because the one thing none of these designs are promising yet is the only one that really matters to most of us: cost. The diesels make sense in Europe where 100LL costs more than grand cru Burgundy but to me they look like a gamble wired in to my bank account. This is subject to change as they prove themselves. As for the comparison to auto engines, I used to think it made the Lycosaurs look bad, but if you look at the experimental crowd, they've been playing with auto conversions for years and it's hard to say what it's gotten them other than something to tinker with endlessly while they're not flying. The majority of experimentals that are built for the sake of flying are built with the same 1940s engines the rest of us use. Plenty of these "amateur experimentals" are built by people who know as much about engines as any professional, though they do work with far smaller budgets. About the only serious problem I see with current technology is the dependence on 100LL, which is going to disappear long before most of us do. The rest is just pet peeves. -cwk. |
needed service. Never even had the valve covers off. I BRBR Uhh, then you have NOT been following the maintenance schedule from Lycoming. Lycosaurs and Contibrasaurus engines is they are simple. No emissions stuff, simple mechanical fuel injection or carburetion, simple mechanical magnetos. This all makes for reliability. These engines are really all that bad. And they are light. If you look at car engines, they are heavier for given horsepower. And BRBR I'll agree with simple, but not more reliable. Magneto's are not as reliable as modern day, no moving parts electronic ignition. I would have no objection to adding emmissions control systems to the aircraft engine either. A fully dressed Chevrolet LS1 engine (98-04 Corvette engine) with a constant speed prop, gear reduction unit, radiator, computer, coolant and oil weighs less than 10lbs more than a IO360 with constant speed prop and produces MORE power, less fuel consumption and less maintenance. -- Dr. Nuketopia Sorry, no e-Mail. Spam forgeries have resulted in thousands of faked bounces to my address. |
nuke wrote:
A fully dressed Chevrolet LS1 engine (98-04 Corvette engine) with a constant speed prop, gear reduction unit, radiator, computer, coolant and oil weighs less than 10lbs more than a IO360 with constant speed prop and produces MORE power, less fuel consumption and less maintenance. Grooooaaan. Oh what the hell. Cool. Can you find some use for the 4 on the floor? I bet when it's done, it will go at least 300 knots. Damn aircraft companies. If only they'd put in a 'vette engine. Must be in cahoots with the oil companies. Let us know when you get it flying. Man... a 'vette!! Damn cool. I'm going to put a HARLEY engine in my experimental! Top THAT! |
Doug wrote: 'vette!! Damn cool. I'm going to put a HARLEY engine in my experimental! Top THAT! Hehehe! Of course you probably already know about this, but for the benefit of those readers who haven't yet... http://www.hog-air.com |
the floor? I bet when it's done, it will go at least 300 knots. Damn aircraft companies. If only they'd put in a 'vette engine. Must be in cahoots with the oil companies. Let us know when you get it flying. Man... a 'vette!! Damn cool. I'm going to put a HARLEY engine in my experimental! Top THAT! BRBR http://predatoraviation.com/performance.html Here's a liquid cooled conversion for Lycoming engines. http://www.cooljugs.com/about.shtml We're flying dinosaurs, you have to admit it. Magnetos belong on lawnmowers, not aircraft. -- Dr. Nuketopia Sorry, no e-Mail. Spam forgeries have resulted in thousands of faked bounces to my address. |
| ROP masking of engine problems | Roger Long | Owning | 4 | September 27th 04 08:36 PM |
| Proposals for air breathing hypersonic craft. I | Robert Clark | Military Aviation | 2 | May 26th 04 07:42 PM |
| My Engine Fire!! | [email protected] | Owning | 1 | March 31st 04 02:41 PM |
| Car engine FAA certified for airplane use | Cy Galley | Home Built | 10 | February 6th 04 04:03 PM |
| Corky's engine choice | Corky Scott | Home Built | 39 | August 8th 03 05:29 AM |
