Building the Po' Boy Bending Brake
Old February 28th 04, 07:59 PM
Veeduber
Why not visit your local scrap yard & pick up a couple of
large-dimension steel angles in the length you need. At under 20 cents a
pound, you probably won't spend much more money & the strength would be
a lot higher.
Dear Charlie (and the Group),
In fact, most guys probably do, as I alluded to in the original article. Of
course, this assumes they can weld (and cut) steel, have access to suitable
hinge(s) and so forth.
The result is a more or less permanent part of your shop. Which can get a bit
silly if you're only building one airplane and only need to brake a couple of
bends.
-R.S.Hoover
Sheet metal shear/press brake VideoFlyer Home Built 7 October 7th 03 07:08 PM
?s about building a gyrocopter John Normile Home Built 2 September 14th 03 02:01 AM
Brake caliper flange Stealth Pilot Home Built 5 July 7th 03 04:19 PM
Brake line design question Charlie Smith Home Built 0 July 2nd 03 12:31 PM
