"Shin Gou" wrote in message om... Looking at RV-9A's specification (weight, engine, etc.), I think a Rotax 914 can power it very well, may give a better performance than O-235. However, the problem is Rotax is far to light to be installed on RV-9A. So I just can't help thinking, well, why not a new design around RV-9A's wing and Rotax 914. The design will be pretty much on fuselage. The benefits of this designe of new fuselage+RV-9A wing+Rotax 914 should be: 1) the basic empty weight should be 100-150 lbs lighter than RV-9A. Rotax 914's wet installation weight is about 80 lbs lighter than O-235. There should be more or less some structural weight saving from the lighter engine installation and lighter gross weight. 2)Rotax 914 has constant 100 hp output up to 12,000 feet so it gives more horsepower at 8000 feet than O-235. 3)The fuselage, if built in composite, can be sleeker(not necessarily much lighter though) Overall, lighter weight+more horsepower at altitude+sleeker fuselage should make this new fuselage+RV-9A wing+Rotax 914 design at least as good as RV-9A with O-235. Prove me wrong please. Shin Gou I've had similar thoughts along the lines of sticking a 914 in either an RV-3 or an RV-9. Why not just extend the forward fuselage to get the w/b correct? You'd also want to verify your stability margins because the longer forward fuselage will tend to be destabilizing. Lengthening the fuselage will cost you some weight in additional structure, but you should still end up with a lighter airframe that uses less fuel. On the other hand, why not build it with the 0-235 and go flying a year or two sooner? KB |
| Thread Tools | |
| Display Modes | |
| Wing in Ground Effect? | BllFs6 | Home Built | 10 | December 18th 03 06:11 AM |
| wing root strakes (not canard A/C) | Wallace Berry | Home Built | 0 | October 2nd 03 09:47 PM |
| Props and Wing Warping... was soaring vs. flaping | Wright1902Glider | Home Built | 0 | September 29th 03 04:40 PM |
| Can someone explain wing loading? | Frederick Wilson | Home Built | 4 | September 10th 03 03:33 AM |
| Wing Extensions | Jay | Home Built | 22 | July 27th 03 01:23 PM |
