Big John wrote
1. A 'barrel roll' is a roll where (if done properly) you as a passenger, with your eyes closed, can not tell you did a roll. The ball stays centered and if one 'G' is maintained, it feels like straight and level flight. Starting nose position and of course air speed varies between underpoweed GA aircraft and super sonic Fghters. There are also a few fine points the experts use that I have not covered but above are the basics. Been there done that for longer (65 years) than BOb has been flying. ![]() I have e-mailed BigJohn and posted at: alt.binaries.pictures.aviation a scan from William Kershner's book, The Flight Instructor's Manual, in which he describes the barrel roll as an acrobatic maneuver. You probably know that Mr. Kershner is one of the most respected names in the flight training field, having authored several books on the subject. Not as funny as Machado, but he has been around for a much longer period of time. I haven't scanned and OCRed the text because I think that the picture is self-explanitory, but if it would help, I will do the page of text describing the barrel roll. Note that as mentioned in my previous post quoting from: http://acro.harvard.edu that one cannot maintain "one G" in a barrel roll since it involves both a loop and a roll. In order to perform the loop portion, one must pull at least 3-3.5 Gs in the pull-up and a similiar force in the pull-out. While inverted, the g-force drops to .5-1 g as in a normal loop. I readily conceed that Big John as been around a bit longer than I, but by the the time that I flew in the military, we were learning to fly in "airplanes", not "birds". :-) :-) Bob |
Robert
Talk me through a loop doing a Barrel Roll. We must be using different words or maneuvers? First let me try a different set of words for a GA barrel roll. 1. Drop the nose and pick up 20-25 mph. 2. Start a nose low left turn in the shallow dive and turn 20-30 degrees. 3, Start pulling nose up and reversing turn using 1 'G' of acceleration (plus 1 G of gravity). 4. Continue the constant rate of roll and the 2 'G's on aircraft. 5. After passing the inverted position continue roll pulling the 2 G's until bird is back with wings level. 6. Ending nose may be level or down depending on aircraft, starting airspeed and rate of roll. You can make a tight barrel roll pulling more that the 2 G's if you want and using more aileron. If tighter will go around faster of course. Now your turn with the help of the guy who wrote the book you read. Don't know what base you got your Pilot training at and the years. I was at Willie from '49 to '53 and taught Basic. Advanced and Gunnery. The Pilots always used the acronym "Bird". Lots of the paper forms that we filled out used the word 'aircraft' however. On a 172,. I'd do a barrel roll in the bird but not a slow roll or aileron roll .Either would over stress the bird 99 times out of a hundred. Enough. Let the others have the stage now. Big John On Sun, 09 Nov 2003 14:54:09 GMT, Robert Moore wrote: Big John wrote 1. A 'barrel roll' is a roll where (if done properly) you as a passenger, with your eyes closed, can not tell you did a roll. The ball stays centered and if one 'G' is maintained, it feels like straight and level flight. Starting nose position and of course air speed varies between underpoweed GA aircraft and super sonic Fghters. There are also a few fine points the experts use that I have not covered but above are the basics. Been there done that for longer (65 years) than BOb has been flying. ![]() I have e-mailed BigJohn and posted at: alt.binaries.pictures.aviation a scan from William Kershner's book, The Flight Instructor's Manual, in which he describes the barrel roll as an acrobatic maneuver. You probably know that Mr. Kershner is one of the most respected names in the flight training field, having authored several books on the subject. Not as funny as Machado, but he has been around for a much longer period of time. I haven't scanned and OCRed the text because I think that the picture is self-explanitory, but if it would help, I will do the page of text describing the barrel roll. Note that as mentioned in my previous post quoting from: http://acro.harvard.edu that one cannot maintain "one G" in a barrel roll since it involves both a loop and a roll. In order to perform the loop portion, one must pull at least 3-3.5 Gs in the pull-up and a similiar force in the pull-out. While inverted, the g-force drops to .5-1 g as in a normal loop. I readily conceed that Big John as been around a bit longer than I, but by the the time that I flew in the military, we were learning to fly in "airplanes", not "birds". :-) :-) Bob |
Big John wrote
Talk me through a loop doing a Barrel Roll. We must be using different words or maneuvers? John, have you looked at the barrel roll picture that I e-mailed you and posted on alt.binaries.pictures.aviation? If not, further discussion will be of no use. Have you checked the "Willian Kershner" web site and read the author's credentials? If not, you just leave us wondering "who-the-hell" is Big John, and what credence should we give to his unsupported assertions? Mr. Kershner owns and operates an Aerobatic Flight School and has authored the book, "The Basic Aerobatic Manual" which as he points out, was an offshoot (with permission) of the manual he helped write for Cessna Aircraft in 1969. First let me try a different set of words for a GA barrel roll. Here are William Kershner's words that accompanied the diagram of the barrel roll in his The Flight Instructor's Manual in which he devotes all of chapter 5 (66 pages) to aerobatic instruction. Quote..............or should I say OCR'ed THE BARREL ROLL • Preparation. It's almost impossible to draw a barrel roll on the chalkboard, but a model will give the desired results. Have the trainee study the references. •Explanation. The barrel roll is a precise maneuver in which the airplane is rolled around an imaginary point 45° to the original flight path. A positive-g level is maintained throughout the maneuver, and the ball in the turn indicator should stay in the middle. You may wonder why the barrel roll is taught this late, since it appears to be so simple. Well, it is a precise maneuver requiring particular airplane attitudes at particular reference points, which is difficult for the average trainee to do properly at first. This maneuver might be considered an exaggeration of the wingover, but instead of starting to shallow the bank at the 90° position, the pilot must steepen it continually until the airplane has rolled 360° and is back on the original heading. The rate of roll must be much greater than that used for the wingover because the airplane must be in a vertical bank at 45° of turn, and it must be inverted at 90° of turn. The roll and turn is continued until the airplane is headed in the original direction with the wings level. Compare the barrel roll in Fig. 23-12 with the same view of the wingover in Fig. 20-7. From behind the maneuver looks as though the airplane is being flown around the outside of a barrel. This is a very good maneuver for gaining confidence and keeping oriented while flying inverted in balanced flight. Good coordination is required to do the barrel roll properly and the trainee will show an improvement in that area after a session of barrel rolls. The barrel roll is generally more difficult and precise than the aileron roll, and he may have to work on this one awhile. Why- The barrel roll is one of the best maneuvers for improving orientation. Unlike the other acrobatic maneuvers covered thus far, the barrel roll requires a constantly changing bank and pitch (with attendant changing airspeed) and a radical change in heading (90°) while the airplane is rolling. The average trainee probably will be looking at the wing tip at a time when he should be checking the nose, or vice versa. When he is able to stay well oriented in the barrel roll, he is ready to move on to the reverse Cuban eight or reverse cloverleaf. How- You might use the following explanation, or develop your own: (1) Make sure the area is clear, then pick a reference on the horizon off the wing tip as in the wingover and lazy eight. (2) Set the throttle to low cruise rpm and ease the nose over to pick-up about 10 K more than used for the wingover or set up the airspeed used for a loop, whichever is higher. Power adjustment should not be necessary during the maneuver. You might have some of your sharper trainees apply full power as the airplane approaches inverted and then remind them to throttle back as the airspeed picks up in the last part of the maneuver. (3) Smoothly pull the nose up and start a coordinated climbing turn (note that it will have to be at a much faster rate than was used for the wingover) toward the reference point. (Assume that at first the roll will be to the left.) (4) When the nose is 45° from the original heading, it should be at its highest pitch attitude and the left bank should be vertical. (5) When the nose is at 90° from the original heading, you should be looking directly at the reference point that was originally off the wing tipfrom a completely inverted position (momentarily). (6) When the airplane heading is again 45° from the original, the bank is vertical but you will be in a right bank as far as the ground is concerned; that is, the right wing is pointing straight down at this instant of roll. The nose will be at its lowest pitch attitude at this point. (7) The roll is continued to wings-level flight as the nose is raised back to the cruise attitude. The maneuver must be symmetrical; the nose must go as far above the horizon as below. The barrel roll requires definite checkpoints to ensure that the airplane is at the correct attitude throughout. It is interesting to note that if the barrel roll is to the left, all of the airplane's path is to the left of the original line of flight and the airplane's nose is always pointed to the left of the original flight line (until it merges again at the completion of the maneuver). The opposite occurs, naturally, for the barrel roll to the right. Another method of doing a barrel roll is to pick a reference on the horizon, turn the airplane 45° to the reference point, and proceed to make a wide roll around this real point. One disadvantage of this method for the newcomer is that it depends on the pilot's own judgment of how large the orbit around the point should be. For an introduction to the maneuver, the first method is usually better, but you may prefer the second and work out your own techniques of instructing it. Demonstration. Try not to lose the reference point yourself while demonstrating this one. You may find your explanation is not keeping up with the airplane, which usually results in sputtering and stuttering while the maneuver proceeds to its foregone conclusion -and then you have to do a new demonstration. Don't worry, this will happen plenty of times during your career of instructing aerobatics -when your mouth can't keep up with your brain or the maneuver-and it can ease tension if you react to it with humor. Usually the trainee is surprised to see the same wing tip back on the reference point and may confess that, like the first snap roll, the earth and sky were blurred and he had no idea where the reference was during the maneuver. Practice. You may rest assured the trainee will "lose" the reference point during the first couple of barrel rolls. He'll usually stare over the nose, seeingnothing but blue sky or ground and not really seeing the point at all. Common errors during barrel rolls include these: 1. Not pulling the nose high enough in the first 45° of the maneuver, which means that the highest and lowest nose positions are not symmetrical to the horizon. 2. Not maintaining a constant rate of roll. Usually things are fine at the 45° position; the nose is at its highest pitch and the bank is vertical. As you approach the position of 90° of turn you will probably find that he is not going to be completely inverted at that point and will have to rush things a bit to make it. The usual reason is that he did not maintain a constant rate of roll. Remember that the nose is up and the airspeed is slower in this segment of the maneuver, so the controls must be deflected more to get the same rate. This is where coordination comes in. Watch for it in particular. 3. Letting the nose drop after passing the 90° point; losing too much altitude and gaining excess airspeed. 4. Failure to roll out on the original heading; having the wing tip well ahead, or well behind, the reference when the maneuver is completed. Evaluation and Review. Review each barrel roll briefly in the air, and have the trainee use the model on the ground. This one can be hard to "see," so go over it again as necessary after getting on the ground. By the time a half-dozen barrel rolls have been practiced, the average trainee should be oriented throughout the maneuver even though he may still have minor problems of heading and symmetry. After a dozen rolls he should be starting to work on a constant roll rate and starting to ease his heading problems. After several hundred, he may begin to be satisfied with his barrel rolls but will realize that constant practice is required. Unquote................. But John...you really should look at that picture. Bob |
On Mon, 10 Nov 2003 02:02:01 GMT, Robert Moore
wrote: ----clip---- But John...you really should look at that picture. ----clip---- OK. I reconfigured my computer and subscribed to "alt.binaries.pictures.avation" and down loaded the last 50 posts and don't find anything from you. I'll go back and download everything from day one to look for your picture and then blow away the other thousands I down loaded. Since I know what a barrel roll is and how to do same and have done then for many many years, why should l look at a picture you drew and if done as described by your expert I seriously doubt if anyone could fly ??? I think I'll let you experts have the floor to do with as you choose. I'm scheduled for a kidney x-ray tomorrow and need to go in refreshed. (No muzzle loaders tonight - we used to call them booze berries G) Big John |
Bob
Found and subscribed to alt.binaries.pictures.avation and down loaded all the postings in that Group. About 500 or so. Sat down and went through them untiL I found your posting. Drilled down and finally got the picture you are so hot about. My comments, No one could do a barrel roll as depicted in your picture. You show a single plane (not airplane) picture and maneuver is done along an extended length of airspace. You don't enter at 90 degrees to the desired direction of flight. Your picture looks more like a single leaf of a four leaf clover. Maybe this is what you call a barrel roll today but sure isn't the classic maneuver. On your query on my credentials in this post. I have answered that in another posting. However to follow along that line since you won't let it go, who are you to question my credentials? You sound like some 'want a be' that's never spent time on his back maybe not even a pilot?. I may well have more inverted time than your total time????. I can do a double emmelman in a F-80/T-33 and a slow roll in aT-6/SNJ without the engine cutting out when inverted. Also I can do a loop in a T-6/SNJ starting from zero indicated airspeed. Want to try any of those maneuvers? Lets see your buddy Kershner do those.He's got T-33 time so ask him if he ever did a double emmelman in it and if so how he did it (airspeed, altitude, G's, etc)? I've got thousands of hours of tail wheel time and never ground looped or let one of my students ground loop on any kind of a field and in any type of weather/wind. BOb and I may well have the highest tail wheel time of any on this group and he's got a lot??? Among others I have instructed both Chinese and Norwegian Air Force students and was awarded wings from both countries, which I am authorized by our government to wear (you need permission you know). I am a member of the caterpillar club ![]() When do you want me to quit?????? The more we talk the more I disagree with you so need to shut things down before we get violent G If you want, take the last shot (some people just have to) and that's it. And the best to thee from the wee ones. Big John On Mon, 10 Nov 2003 02:02:01 GMT, Robert Moore wrote: Big John wrote Talk me through a loop doing a Barrel Roll. We must be using different words or maneuvers? John, have you looked at the barrel roll picture that I e-mailed you and posted on alt.binaries.pictures.aviation? If not, further discussion will be of no use. Have you checked the "Willian Kershner" web site and read the author's credentials? If not, you just leave us wondering "who-the-hell" is Big John, and what credence should we give to his unsupported assertions? Mr. Kershner owns and operates an Aerobatic Flight School and has authored the book, "The Basic Aerobatic Manual" which as he points out, was an offshoot (with permission) of the manual he helped write for Cessna Aircraft in 1969. First let me try a different set of words for a GA barrel roll. Here are William Kershner's words that accompanied the diagram of the barrel roll in his The Flight Instructor's Manual in which he devotes all of chapter 5 (66 pages) to aerobatic instruction. Quote..............or should I say OCR'ed THE BARREL ROLL • Preparation. It's almost impossible to draw a barrel roll on the chalkboard, but a model will give the desired results. Have the trainee study the references. •Explanation. The barrel roll is a precise maneuver in which the airplane is rolled around an imaginary point 45° to the original flight path. A positive-g level is maintained throughout the maneuver, and the ball in the turn indicator should stay in the middle. You may wonder why the barrel roll is taught this late, since it appears to be so simple. Well, it is a precise maneuver requiring particular airplane attitudes at particular reference points, which is difficult for the average trainee to do properly at first. This maneuver might be considered an exaggeration of the wingover, but instead of starting to shallow the bank at the 90° position, the pilot must steepen it continually until the airplane has rolled 360° and is back on the original heading. The rate of roll must be much greater than that used for the wingover because the airplane must be in a vertical bank at 45° of turn, and it must be inverted at 90° of turn. The roll and turn is continued until the airplane is headed in the original direction with the wings level. Compare the barrel roll in Fig. 23-12 with the same view of the wingover in Fig. 20-7. From behind the maneuver looks as though the airplane is being flown around the outside of a barrel. This is a very good maneuver for gaining confidence and keeping oriented while flying inverted in balanced flight. Good coordination is required to do the barrel roll properly and the trainee will show an improvement in that area after a session of barrel rolls. The barrel roll is generally more difficult and precise than the aileron roll, and he may have to work on this one awhile. Why- The barrel roll is one of the best maneuvers for improving orientation. Unlike the other acrobatic maneuvers covered thus far, the barrel roll requires a constantly changing bank and pitch (with attendant changing airspeed) and a radical change in heading (90°) while the airplane is rolling. The average trainee probably will be looking at the wing tip at a time when he should be checking the nose, or vice versa. When he is able to stay well oriented in the barrel roll, he is ready to move on to the reverse Cuban eight or reverse cloverleaf. How- You might use the following explanation, or develop your own: (1) Make sure the area is clear, then pick a reference on the horizon off the wing tip as in the wingover and lazy eight. (2) Set the throttle to low cruise rpm and ease the nose over to pick-up about 10 K more than used for the wingover or set up the airspeed used for a loop, whichever is higher. Power adjustment should not be necessary during the maneuver. You might have some of your sharper trainees apply full power as the airplane approaches inverted and then remind them to throttle back as the airspeed picks up in the last part of the maneuver. (3) Smoothly pull the nose up and start a coordinated climbing turn (note that it will have to be at a much faster rate than was used for the wingover) toward the reference point. (Assume that at first the roll will be to the left.) (4) When the nose is 45° from the original heading, it should be at its highest pitch attitude and the left bank should be vertical. (5) When the nose is at 90° from the original heading, you should be looking directly at the reference point that was originally off the wing tipfrom a completely inverted position (momentarily). (6) When the airplane heading is again 45° from the original, the bank is vertical but you will be in a right bank as far as the ground is concerned; that is, the right wing is pointing straight down at this instant of roll. The nose will be at its lowest pitch attitude at this point. (7) The roll is continued to wings-level flight as the nose is raised back to the cruise attitude. The maneuver must be symmetrical; the nose must go as far above the horizon as below. The barrel roll requires definite checkpoints to ensure that the airplane is at the correct attitude throughout. It is interesting to note that if the barrel roll is to the left, all of the airplane's path is to the left of the original line of flight and the airplane's nose is always pointed to the left of the original flight line (until it merges again at the completion of the maneuver). The opposite occurs, naturally, for the barrel roll to the right. Another method of doing a barrel roll is to pick a reference on the horizon, turn the airplane 45° to the reference point, and proceed to make a wide roll around this real point. One disadvantage of this method for the newcomer is that it depends on the pilot's own judgment of how large the orbit around the point should be. For an introduction to the maneuver, the first method is usually better, but you may prefer the second and work out your own techniques of instructing it. Demonstration. Try not to lose the reference point yourself while demonstrating this one. You may find your explanation is not keeping up with the airplane, which usually results in sputtering and stuttering while the maneuver proceeds to its foregone conclusion -and then you have to do a new demonstration. Don't worry, this will happen plenty of times during your career of instructing aerobatics -when your mouth can't keep up with your brain or the maneuver-and it can ease tension if you react to it with humor. Usually the trainee is surprised to see the same wing tip back on the reference point and may confess that, like the first snap roll, the earth and sky were blurred and he had no idea where the reference was during the maneuver. Practice. You may rest assured the trainee will "lose" the reference point during the first couple of barrel rolls. He'll usually stare over the nose, seeingnothing but blue sky or ground and not really seeing the point at all. Common errors during barrel rolls include these: 1. Not pulling the nose high enough in the first 45° of the maneuver, which means that the highest and lowest nose positions are not symmetrical to the horizon. 2. Not maintaining a constant rate of roll. Usually things are fine at the 45° position; the nose is at its highest pitch and the bank is vertical. As you approach the position of 90° of turn you will probably find that he is not going to be completely inverted at that point and will have to rush things a bit to make it. The usual reason is that he did not maintain a constant rate of roll. Remember that the nose is up and the airspeed is slower in this segment of the maneuver, so the controls must be deflected more to get the same rate. This is where coordination comes in. Watch for it in particular. 3. Letting the nose drop after passing the 90° point; losing too much altitude and gaining excess airspeed. 4. Failure to roll out on the original heading; having the wing tip well ahead, or well behind, the reference when the maneuver is completed. Evaluation and Review. Review each barrel roll briefly in the air, and have the trainee use the model on the ground. This one can be hard to "see," so go over it again as necessary after getting on the ground. By the time a half-dozen barrel rolls have been practiced, the average trainee should be oriented throughout the maneuver even though he may still have minor problems of heading and symmetry. After a dozen rolls he should be starting to work on a constant roll rate and starting to ease his heading problems. After several hundred, he may begin to be satisfied with his barrel rolls but will realize that constant practice is required. Unquote................. But John...you really should look at that picture. Bob |
In article , Big John wrote:
On a 172,. I'd do a barrel roll in the bird but not a slow roll or aileron roll .Either would over stress the bird 99 times out of a hundred. Really? All the eileron rolls I've ever done have been distinctly low-G manoevres. Dive a little to gain entry speed, pull the nose up to about 30 degrees above the horizon, then full aileron until the world comes the right way up again, at which point you'll be about 20 degrees nose down. The G-meter has never shown more than 1.5G after an aileron roll for me, and that was done in the initial pull-up. I thought a C172 in the utility category was good for 4.2G, not 1.5G! -- Dylan Smith, Castletown, Isle of Man Flying: http://www.dylansmith.net Frontier Elite Universe: http://www.alioth.net "Maintain thine airspeed, lest the ground come up and smite thee" |
Dylan
From my good book (Owners Manual Model 172 and Skyhawk) Normal category Gross weight --- 2300# Flaps up +3.8 G -1.52 G Normal category is non acrobatic You can do stalls (not whip stalls) and are limited to a max angle of bank of 60 degrees. Utility Category Max gross weight --- 2000# Flaps up +4.4 G -1.76 G No aerobatic maneuvers are approved except those listed. Chandelles Lazy Eights Steep Turns Spins Stall (Except Whip Stalls) From these figures you can see that it would be touch and go if you rolled the bird inverted. Of course the figures given are not ultimate so might only bend things a little ![]() Big John * Added note. "In the execution of all maneuvers, avoid abrupt use of controls." On Mon, 10 Nov 2003 08:13:29 -0000, Dylan Smith wrote: In article , Big John wrote: On a 172,. I'd do a barrel roll in the bird but not a slow roll or aileron roll .Either would over stress the bird 99 times out of a hundred. Really? All the eileron rolls I've ever done have been distinctly low-G manoevres. Dive a little to gain entry speed, pull the nose up to about 30 degrees above the horizon, then full aileron until the world comes the right way up again, at which point you'll be about 20 degrees nose down. The G-meter has never shown more than 1.5G after an aileron roll for me, and that was done in the initial pull-up. I thought a C172 in the utility category was good for 4.2G, not 1.5G! |
Big John wrote: [...] 3. An aileron roll is just laying the aileron over (normally full aileron) and letting bird roll. Depending on type of aircraft (fighter or GA) the nose makes a circle around a point. Fighters can do at cruise with little or no nose above the horizon. GA requires a start with the nose above the horizon due to slower rate of roll and bird ending up nose low because no other control input to hold nose up while inverted is used The question for me -- and what prompted my earlier posting(s) -- is whether it's possible to do a standard aileron roll and get negative G's (or non-positive G's, to be precise). The puny GA planes I fly all have positive G forces all the way around an aileron roll (unless you do something funny with elevator and / or rudder), but is that true of all aircraft? Hamish |
passenger, with your eyes closed, can not tell you did a roll. The ball stays centered and if one 'G' is maintained, I suspect there is more than one definition of a "barrel roll." The ex-Air Force P-47 pilot I've flown with does a peculiar corkscrew barrel roll that bears virtually no resemblance to the one I was taught at Pensacola. The barrel roll I was taught, and like to do, cannot be done at a constant 1 G. There is positive acceleration all the way around (see my post just above), that is, the stick is back, and the nose keeps coming "up," all the way around. (The ball is in the center all the way around, too, and a glass of water will not spill.) That positive acceleration means that more than 1 G is experienced during those parts of the roll in which the airplane is essentially upright. vince norris |
Scott Lowrey wrote:
If I'm crusing along at 100 KIAS in a 172 in clear air and I roll left while maintaining neutral rudder, what will happen if I don't neutralize the ailerons? WOW. I was away for several days and I think I'd see two replies to my post before I left. Thanks for all the replies - you guys are easy to get going but never boring... well, usually never. :+) Anyway, I thought about Vne being a problem later. Seems like the right thing to do (after drinking my cup of water, tying a string to the panel, plugging the fuel vents, and hoping I have enough oil) would be to nose up a bit prior to the roll and push forward while inverted. I know this isn't the plane for this kind of maneuver and I have no intention of trying it. Sure would like to do some acro someday, though. Maybe when I save enough to by that Stearman I've always wanted. -Scott |
??Build rolling tool chest? | Michael Horowitz | Owning | 15 | January 27th 05 04:56 AM |
Rolling Thunder | Mortimer Schnerd, RN | Military Aviation | 10 | June 14th 04 12:49 AM |
B-52 crew blamed for friendly fire death | Paul Hirose | Military Aviation | 0 | March 16th 04 12:49 AM |
Defensive circle | Dave Eadsforth | Military Aviation | 23 | October 9th 03 06:13 PM |
Talk about runway incursions... | Dave Russell | Piloting | 7 | August 13th 03 02:09 AM |
