Real stats on engine failures?
Old December 1st 03, 12:45 AM
Snowbird
(Michael) wrote in message . com...
(Snowbird) wrote
One observation from the recent ASF/FAA vacuum failure study
was that pilots who lost only their AI (electric HSI did not
fail) did not lose control of the airplane, while a significant
number of pilots (same aircraft) lost control when they lost
both. There was no correlation to time in type or total time.
This result suggests to me that it might be a mistake to
extrapolate from "lose AI no problem" to "lose gyros no
problem".
That's somewhat valid. I don't worry about this situation for two
reasons: First, I have dual vacuum pumps, so loss of both gyros
simultaneously is very, very unlikely.
I wasn't so much concerned about your personal setup but about
your posting history, which is to pipe up whenever the subject
of gyro failure (and bad outcomes thereof) are discussed and
say something to the effect of well, I've had a gyro failure in
actual and it was no big deal so contrary to popular opinion I
don't think it's something a proficient pilot needs to sweat
about. (I paraphrase here, and perhaps that wasn't the message
you intended to convey, but it's the message I and, I think,
others, have garnered from your posts)
That's why I think the distinction between a single instrument
failure, and vacuum failure (loss of two instruments) may be
relevant to point out.
I've already made my feelings about flying IMC with a single
dry pump and no backups well known, but in case anyone missed it -
it's stooopid.
Actually, I'm glad to hear you say this. The impression that
I've received from your previous posts is that you believed a
vacuum failure should be no big deal at all to a proficient pilot.
Not a reason to abort the flight, declare an emergency, and
request no-gyro vectors to the nearest ILS, for example (which
is my notion).
If that's not the case, I'm at a bit of a loss as to how to
interpret some of what you've previously posted.
If that is the case, I'm at a bit of a loss as to why you
feel lack of backup is so stupid -- if it's no big deal and any
proficient pilot should be able to cope without breaking a
sweat, why is backup important? If the cause of accidents
following vacuum or gyro failure is lack of proper, recurrant
training, why not just invest in training instead of redundant
instrumentation or vacuum sources--isn't that what you've
suggested in the past when the point has been raised?
The reason I say it's somewhat valid is this - my (admittedly somewhat
limited) experience as an instrument instructor is that most people
miss having the DG a lot more than they miss having the AI.
That's certainly true for me.
[nb this originally referred to "ugly outcomes" to gyro failures
in IMC]
There are currently no "real stats" which prove or disprove
the contention that this ugliness is entirely due to improper
training.
No, but that's the way to bet. It's certainly how my insurance
company is betting - I'm now required to take a full IPC with engine
cuts every year in make and model, regardless of recency of
experience, if I want to keep my relatively low rates.
Apples and oranges to the topic under discussion here, which was
whether the "ugly outcomes" of vacuum failure are entirely due
to improper training.
Unless I'm missing something, there is no requirement that an
IPC necessarily include partial panel work, so it's not clear
to me how your insurance company votes on this topic. The
principle cause of accidents in light twins is not related to
vacuum failure due to redundant systems.
Cheers,
Sydney
Old December 1st 03, 05:35 PM
Michael
No, that's basically the message. I don't think it's something a
proficient pilot needs to really sweat. Sure, it could get you - but
it probably won't. I consider it comparable to an engine failure in a
twin after reaching blue line and gear up - it's something you train
for, and if you've trained for it it's not going to be a big deal when
it happens. BTW, I've had that as well, and it wasn't a big deal
either.
Yes, I think it's VERY important. An analogous situation might be a
stuck valve vs. a total engine failure. In your average light single,
a stuck valve means you're not going to make enough power to climb -
but you will have enough to flatten your glideslope and increase the
options. Therefore, the situation is easier than a total failure. By
the same token, a vacuum failure when established in level cruise is
going to be easier to handle than one on climbout while getting an
amended clearance. No two situations are ever the same - we normally
practice for the worst case.
What makes vacuum failure (as opposed to single gyro failure) ugly is
that two out of three gyros fail (in a typical setup). Of course
that's going to make the situation more difficult. Essentially you're
set up so that a single point failure takes out two important
instruments. I used to fly a TriPacer where it was worse - all three
gyros were vacuum powered. Believe it or not, this is legal - but I
doubt too many pilots could survive a vacuum failure in IMC in that
airplane. Of course it was a wet pump, which is, if my experience and
the experience of the people I know is any guide, more reliable than
the engine that drives it. That airplane, early in its history, was
IFR equipped (to 1950's standards) and was used as a cargo hauler. I
wonder if the pilot knew all his gyros were on one pump.
Anyway, my point is that dual simultaneous failures are more difficult
to handle than individual failures and a proper design won't allow
them to occur with any regularity. Two gyros driven by a single dry
pump does not constitute proper design. That doesn't make it
unflyable, even in IMC, but given the ready availability of wet pumps
for all the popular engines in use on light singles, it's pretty
stupid. Kind of like flying IFR without a handheld GPS - it's doable,
and it was done for years, but given how useful they are and how
little they cost, it's pretty dumb not to have one.
My gyro failure situation included only the AI, but on the other hand
it happened during the highest workload phase of flight. Would it
have been more difficult had I lost the DG as well? Certainly.
Dangerous? I doubt it. Handling the AI loss was just too easy, and
doing night hood work with both out isn't all that difficult either.
it's stooopid.
An engine failure over an airport should also be no big deal at all to
a proficient pilot. That doesn't mean I'm willing to take off when
the oil pressure at idle is well above top redline - even if I'm never
going to be out of glide range of the field (and yes, this was a real
situation).
Well, in my opinion the sensible thing to do is to replace the dry
pump with a wet one - given that it's probably more reliable than the
engine that drives it, that's certainly the reasonable and
cost-effective solution in a single engine airplane. But over and
above that - yes, I think recurrent training is preferable to
redundant instrumentation for this.
And that has a lot to do with the kind of airplanes you've flown and
the way they were equipped. In my airplane, I miss the AI more than I
miss the DG. My understanding is that in a jet, loss of all attitude
indicators in IMC is certain death.
You're missing something. What you say used to be true, but no longer
is. These days, an ICC must consist of "a representative number of
tasks required by the instrument rating practical test" and when you
look at the instrument rating PTS, those tasks are spelled out.
Partial panel approaches (and single engine approaches for twins) are
required.
Michael
V-8 powered Seabee Corky Scott Home Built 212 October 2nd 04 11:45 PM
Dennis Fetters Mini 500 EmailMe Home Built 70 June 21st 04 09:36 PM
My Engine Fire!! [email protected] Owning 1 March 31st 04 01:41 PM
Engine... Overhaul? / Replace? advice please text news Owning 11 February 17th 04 04:44 PM
Gasflow of VW engine Veeduber Home Built 4 July 14th 03 08:06 AM
