Corky Scott wrote:
Are you trying to save money or weight, or both? When you wet out the fiberglass fabric, it sometimes takes a lot of primer to fill the weave, depending on the weight of the cloth. That could make for a looonnnnggggg time of finishing to make it look good. Doubt it would be any cheaper. Thought it could be a little lighter. I guess a benefit would be a simplification in this project. I'm already having to do a lot of fiberglass work with the wings and turtleback. The fabric is a whole 'nuther skill set, tool set, and chemical set. The fabric entails, gluing, shrinking, fabric-riveting (which I understand is slightly different than metal riveting) then filling the weave. While maybe all minor skills, they are all something to be learned and all have their set of pitfalls. For instance, I've been warned that when sanding the primer, the abrasive pad can easily slice through the fabric at the edges of ribs or other hard supports. I'm already doing the FG thing, so I'd get to amortize the learning curve a little more. As I understand it, a 2oz fine-weave cloth doesn't need much filling and if you wet it out on plastic, it won't need any. It will come out as smooth as the plastic. The process would boil down to wet out the glass between 2 sheets of plastic, pull of the top sheet and wrap the rest around the part to be covered. Scuff sand and and it's ready for paint. I'm really not that concerned about strength, other than the FG is so much stronger that you should be able to size it down accordingly. Whichever type you choose, the resulting coverings weight will be determined in large part by how thick the fabric was to begin with. It seems that a thinner fabric wouldn't need as much filler to get 'full'. And 2oz FG has got to be thinner than 4oz polyester. The comments have been that the Razorback system is heavy, and I don't understand why that should be. Why not use a thinner fabric since it has the strength to spare? -- http://www.ernest.isa-geek.org/ "Ignorance is mankinds normal state, alleviated by information and experience." Veeduber |
Ernest Christley wrote:
Corky Scott wrote: Are you trying to save money or weight, or both? When you wet out the fiberglass fabric, it sometimes takes a lot of primer to fill the weave, depending on the weight of the cloth. That could make for a looonnnnggggg time of finishing to make it look good. Doubt it would be any cheaper. Thought it could be a little lighter. I guess a benefit would be a simplification in this project. I'm already having to do a lot of fiberglass work with the wings and turtleback. The fabric is a whole 'nuther skill set, tool set, and chemical set. The fabric entails, gluing, shrinking, fabric-riveting (which I understand is slightly different than metal riveting) then filling the weave. While maybe all minor skills, they are all something to be learned and all have their set of pitfalls. For instance, I've been warned that when sanding the primer, the abrasive pad can easily slice through the fabric at the edges of ribs or other hard supports. I'm already doing the FG thing, so I'd get to amortize the learning curve a little more. As I understand it, a 2oz fine-weave cloth doesn't need much filling and if you wet it out on plastic, it won't need any. It will come out as smooth as the plastic. The process would boil down to wet out the glass between 2 sheets of plastic, pull of the top sheet and wrap the rest around the part to be covered. Scuff sand and and it's ready for paint. I'm really not that concerned about strength, other than the FG is so much stronger that you should be able to size it down accordingly. Whichever type you choose, the resulting coverings weight will be determined in large part by how thick the fabric was to begin with. It seems that a thinner fabric wouldn't need as much filler to get 'full'. And 2oz FG has got to be thinner than 4oz polyester. The comments have been that the Razorback system is heavy, and I don't understand why that should be. Why not use a thinner fabric since it has the strength to spare? -- http://www.ernest.isa-geek.org/ "Ignorance is mankinds normal state, alleviated by information and experience." Veeduber Glass is a highly frangible material compared to polyester. It is strong, yes, but brittle. While tensile strength is a good thing, it is not the only thing we need to consider. My new plane is covered with 1.7 ounce dacron and Poly Fiber finish. For a lightly loaded, low speed plane, this is quite adequite. 3.2 ounce fabric is twice as strong. Why _not_ use it? (trick question!) Because it's FOUR times heavier when finished? Richard |
On Thu, 08 Apr 2004 19:01:51 GMT, Ernest Christley
wrote: Most of the fabric covered aiplanes I've seen didn't seem that hard. That is, you could walk up to them and push the fabric in with your hand. The way I understand the fabric process, it is basically a composite structure. You have a nylon cloth with a paint "epoxy". Could a much stronger and lighter covering be made by wetting out some 2.5oz glass cloth on plastic, waiting till it's tacky and then wrapping it around the airframe? The epoxy would be much lighter than paint, and fiberglass cloth is MUCH stronger than nylon. I've seen some places where builders used composites in place of fabric, and it seemed that they all aimed for a multlayer, stiff panel, putting the weight far above the original. I just don't understand why? Not sure that the fiberglass cloth plus the resin would be lighter than the cloth plus the paint. For one thing, you left out the paint on the fiberglass, or were you going to leave it the opaque look that the fiberglass gets after wetting out and curing? The other thing is that the fabric covered wing was designed for a fabric covering. In some cases where a wing was "metalized" the airplane ended up with a performance that was not as good as the fabric covered wing. Finally, as was pointed out already, there is no benefit to putting a stiff panel around the wing. You don't save weight because the wing is structurally designed for a fabric covering so it's internally braced. If you wanted to use a stiff skin to cover the wing, you should redesign the wing such that it gets it's stiffness from the covering, not the internal bracing, and save weight. For instance, the wing I built is fabric covered. The spars are wood, and the ribs are wood. The wing is braced with drag and anti drag wires that are actually 1/4" drill rod. Because they tend to try to draw the spars together, the spars need to be held apart with steel tubes called compression tubes. There are around six of them. There's also a diagonal brace at the wing root to prevent the wing from swaying back and forth, or in my case, a plate of sheet aluminum instead. All this is to make sure the wing is stiff enough to withstand the forces it's expected to encounter in flight. It's the result of many years of aviation experience and engineering. If I were to cover the wing with metal instead of fabric, I could do away with all of the braces mentioned above. Corky Scott |
Many of you have some ideas about glass fabric that may or may not be valid.
First of all, I own the RAZORBACK FABRIC Company. The company started in 50's and the FAA signed a letter in 60's that deemed our glass covering as a permanent covering that no longer needed testing as all other fabrics do on certified airframes do. This is due to the fact that all hydrocarbon based material deteriorate in the presents of UV radiation. It is true that our fabric is heavier than the choices that are now available. It was originally designed for agricultural aircraft, Stearmen to be exact. It weighs 3.6 oz. and uses less dope than Grade A cotton that weighs 4 oz. So technically, it weighs 17% less than the original fabric on J-3s, BC-12s, and etc. So with 35 yards for a average project, the total weight difference from a temporary dacron fabric of 2.4 oz per yard and the less expensive, but 200% stronger, permanent glass fabric system doesn't add up to all the negative talk about weight to the economists. As in a poorly installed rivet, I supposed our glass could frett. Our shop is dedicated to repairing and recovering frieght aircraft and so far, I have never seen this ocurrance. I have seen poorly installed fabric wear away the aluminum, though. It is much harder than aluminum and steel and care should be taken to protect the rivet and etc. with anti-shafing tape, as with any fabric installation. Once installed correctly, it has a much stiffer surface than the more flexible and stretchy dacron. I have seen many pictures on the covers of aviation magazines that show the top of the wing with pillows deforming between the ribs as the fabric stretches under the aerodynamic load of flight. Properly installed glass fabric does not stretch and will remain closer to the profile of the ribs than any other covering short of metal. Many of our customers comment that our fabric has gained them real increases in airspeed beyond the fact of being covered with a fresh finish. This also allows your paints to last longer as the flexing really stresses the surface coatings. Plus, you don't have the worry of falling through it if you should mis-step on a low wing. You can walk on it as long as the rib underneath it can handle the weight. By the way, since our fabric does not rot, deteriorate in acid rain and sunlight or even burns and is easily applied and repaired, it is still the only synthetic fabric that is authorized for use by our and other militaries. It is FAA-PMA'd, FAA-STC'd, MIL SPEC and ISO 9002 rated. Our biggest sales are still the military. Yes, C-130s and C-141 still have fabric on them and in them. We don't own chemical companies and we are not trying to corner the fabric market. But if you want a permanent awning, aircraft covering, or a firewall, you might want to find out more about RAZORBACK FABRICS, INC. Thank you for your time. Robert Little "Ernest Christley" wrote in message m... Most of the fabric covered aiplanes I've seen didn't seem that hard. That is, you could walk up to them and push the fabric in with your hand. The way I understand the fabric process, it is basically a composite structure. You have a nylon cloth with a paint "epoxy". Could a much stronger and lighter covering be made by wetting out some 2.5oz glass cloth on plastic, waiting till it's tacky and then wrapping it around the airframe? The epoxy would be much lighter than paint, and fiberglass cloth is MUCH stronger than nylon. I've seen some places where builders used composites in place of fabric, and it seemed that they all aimed for a multlayer, stiff panel, putting the weight far above the original. I just don't understand why? -- http://www.ernest.isa-geek.org/ "Ignorance is mankinds normal state, alleviated by information and experience." Veeduber |
![]() We don't own chemical companies and we are not trying to corner the fabric market. But if you want a permanent awning, aircraft covering, or a firewall, you might want to find out more about RAZORBACK FABRICS, INC. Thank you for your time. Robert Little ----------------------------------------------------------- To All: Listen to the man. Common Sense has become such uncommon stuff in the aviation community that the antique phreaks give each other extra points for using heavier and less durable (but All Original) Irish linen, while across the field the fabric experts are happily selling Polly Needles for rib-stitching Polly Thread thru Polly Holes in Polly Fabric, knowing they can charge the same inflated prices to the next Polly Idiot to own the thing. Razorback has the potential to put all the Polly People out of business, which is probably the reason it is always damned with faint praise. ----------------------------------------------------- Fabric is not always stitched. Most homebuilders are aware that it is sometimes glued to the structure but most are not familiar with the many other time-tested methods. On some airframes it is attached with canes & nails (!) and for metal ribs, with spring clips, wire, sheet metal screws and even rivets. When Razorback is attached with these methods you end up with a virtually permanent skin. -R.S.Hoover |
Veeduber wrote:
Fabric is not always stitched. Most homebuilders are aware that it is sometimes glued to the structure but most are not familiar with the many other time-tested methods. On some airframes it is attached with canes & nails (!) and for metal ribs, with spring clips, wire, sheet metal screws and even rivets. When Razorback is attached with these methods you end up with a virtually permanent skin. -R.S.Hoover John Dyke's prototype, N555A (I hope I got that right), has the fabric riveted to the elevon ribs, rudder and tailfin. It is glued to the belly. -- http://www.ernest.isa-geek.org/ "Ignorance is mankinds normal state, alleviated by information and experience." Veeduber |
Robert Little wrote:
It is true that our fabric is heavier than the choices that are now available. It was originally designed for agricultural aircraft, Stearmen to be exact. It weighs 3.6 oz. and uses less dope than Grade A cotton that weighs 4 oz. So technically, it weighs 17% less than the original fabric on J-3s, BC-12s, and etc. So with 35 yards for a average project, the total weight difference from a temporary dacron fabric of 2.4 oz per yard and the less expensive, but 200% stronger, permanent glass fabric system doesn't add up to all the negative talk about weight to the economists. So, why do you not offer the process in a lighter fabric? The application that I'm looking at is an elevon that is hinged from its leading edge. The top speed is limited by the possibility of speed induced flutter in the elevon. A lighter elevon corresponds to a higher top speed, so this is one of the few places on this airplane where I'm actually concerned about ounces ('cause flutter stories scare me more than all the others). It's late, and way past my bedtime, but 3.6oz FG sounds like a lot more strength than is needed and way stronger that the specified fabric. I'll do the math tomorrow. But is there a reason that a lighter fabric can't be used? Since the fabric is 200% stronger, why couldn't you replace the 2.4oz Dacron with 1.2oz Razorback? BTW, I haven't seen any prices listed, but LESS expensive than Dacron? Dacron is fairly cheap as far as coverings go. -- http://www.ernest.isa-geek.org/ "Ignorance is mankinds normal state, alleviated by information and experience." Veeduber |
With the superior strength of glass cloth, why not offer it in a litter
weight? A very good question that I asked the president of the Ultra Light Aircraft Association. Because of the very expensive process of getting a new product "certified" by the FAA, I had that organization do a survey for interest in a permanent fabric. There was no interest at all. After many years of instructing rib stitiching and fabric installation at the Oshkosh EAAFly-In, the survey was not too surprizing. We realize that we don't have to get the blessings of the FAA to sell to the home builder and can sell "uncertified" fabric as the other companies do. But unfortunately, that light-weight uncertifed fabric usually shows up on certified aircraft, regardless of the regulations and recommendations. And yes, wing loading, speed and flight regimen does mandate the different weights of fabric. A good reference is the A.C. 43-13.1B. So, until I think that I can sell enough of our 1.5 oz that test in at 92 lbs/ inch that will break even with the cost of certification, we will not offer it to the public. (New Grade A cotton only tests at 80 lbs/inch) The cost difference of glass fabric is 80% greater than polyester. But it is glued with butyrate dope (no nitrate-laced glue), taunten with butyrate dope, filled with non-tauntening butyrate dope and should be topped with butyrate dope, although, the top coat is the installer's choice. We still buy MIL SPEC butyrate dope for less than $16 a gal. I'll let you figure the total cost of a cover job from these figures. I hope that this has answered some of your questions. All things are based on economics. As I've said before, I wish all fabric was permanent so that we didn't have to hide our beautiful airplanes deep in dark hangers. It doesn't make very much sense that the owners of the most economical and most fun to fly aircraft are afraid to come out into the sun and fly. The temporary fabrics that are on the market today have stolen a great heritage from us. Most of these airplanes are so rare in flight that insurance ratios are astronomical. and training is getting quite rare. there are tens of thousands of ragwings hiden away in hangers that are afraid to come out and stay current. It is sad. "Ernest Christley" wrote in message .. . Robert Little wrote: It is true that our fabric is heavier than the choices that are now available. It was originally designed for agricultural aircraft, Stearmen to be exact. It weighs 3.6 oz. and uses less dope than Grade A cotton that weighs 4 oz. So technically, it weighs 17% less than the original fabric on J-3s, BC-12s, and etc. So with 35 yards for a average project, the total weight difference from a temporary dacron fabric of 2.4 oz per yard and the less expensive, but 200% stronger, permanent glass fabric system doesn't add up to all the negative talk about weight to the economists. So, why do you not offer the process in a lighter fabric? The application that I'm looking at is an elevon that is hinged from its leading edge. The top speed is limited by the possibility of speed induced flutter in the elevon. A lighter elevon corresponds to a higher top speed, so this is one of the few places on this airplane where I'm actually concerned about ounces ('cause flutter stories scare me more than all the others). It's late, and way past my bedtime, but 3.6oz FG sounds like a lot more strength than is needed and way stronger that the specified fabric. I'll do the math tomorrow. But is there a reason that a lighter fabric can't be used? Since the fabric is 200% stronger, why couldn't you replace the 2.4oz Dacron with 1.2oz Razorback? BTW, I haven't seen any prices listed, but LESS expensive than Dacron? Dacron is fairly cheap as far as coverings go. -- http://www.ernest.isa-geek.org/ "Ignorance is mankinds normal state, alleviated by information and experience." Veeduber |
On Wed, 14 Apr 2004 00:17:15 -0500, "Robert Little"
wrote: I hope that this has answered some of your questions. All things are based on economics. As I've said before, I wish all fabric was permanent so that we didn't have to hide our beautiful airplanes deep in dark hangers. It doesn't make very much sense that the owners of the most economical and most fun to fly aircraft are afraid to come out into the sun and fly. The temporary fabrics that are on the market today have stolen a great heritage from us. Most of these airplanes are so rare in flight that insurance ratios are astronomical. and training is getting quite rare. there are tens of thousands of ragwings hiden away in hangers that are afraid to come out and stay current. It is sad. owner of the company or not you do write some bull**** robert. if you have never seen the fiberglass fretted away so that only the finish remained then you need to get out more. expletive deleted my tailwind has a 19year old polyfiber finish that just will not die. I will eventually rip it off in airworthy condition so that I can check for cracks and recoat the steel tubes. btw the problem with these modern fabrics is that they are so permanent that the underlying structures are not getting the regular maintenance attention that they would have in the days of cotton. that is the problem. not the BS you write. obviously ymmv Stealth Pilot Australia |
With the superior strength of glass cloth, why not offer it in a litter weight? A very good question that I asked the president of the Ultra Light Aircraft Association. Because of the very expensive process of getting a new product "certified" by the FAA, I had that organization do a survey for interest in a permanent fabric. There was no interest at all. After many years of instructing rib stitiching and fabric installation at the Oshkosh EAAFly-In, the survey was not too surprizing. We realize that we don't have to get the blessings of the FAA to sell to the home builder and can sell "uncertified" fabric as the other companies do. But unfortunately, that light-weight uncertifed fabric usually shows up on certified aircraft, regardless of the regulations and recommendations. And yes, wing loading, speed and flight regimen does mandate the different weights of fabric. A good reference is the A.C. 43-13.1B. So, until I think that I can sell enough of our 1.5 oz that test in at 92 lbs/ inch that will break even with the cost of certification, we will not offer it to the public. (New Grade A cotton only tests at 80 lbs/inch) The cost difference of glass fabric is 80% greater than polyester. But it is glued with butyrate dope (no nitrate-laced glue), taunten with butyrate dope, filled with non-tauntening butyrate dope and should be topped with butyrate dope, although, the top coat is the installer's choice. We still buy MIL SPEC butyrate dope for less than $16 a gal. I'll let you figure the total cost of a cover job from these figures. I hope that this has answered some of your questions. All things are based You answered the questions, very good answers, in fact; however, it doesn't help me. I hear you paraphrasing Ford. "You can have anything you want, as long as it is what we sell." Which is OK, it just doesn't help me any. What I'm after is a 1) lighter elevon and 2) simpler to build elevon. If it is stronger or cheaper, we can party on those points, too, but they are secondary. Your process, while excellent, helps on neither point. I don't mean to tell you your job here, but did you ever consider asking the Ultralight Association if they would be interested in a LIGHTER fabric. My impression of the ultralighters I know is that they look at their planes as dirt bikes. They are not serious modes of transportation, they're toys. Why would you EVER worry about a permanent fabric on a toy! But if those guys think they can cruise 1mph faster or climb 1fpm quicker they'll ransom their children for pixie dust. I guess it is equally true for the GA crowd, and especially for the tube'n'rag crowd. For the most part, tube'n'rag crafts are not serious transportation; therefore, PERMANENT COVERING means zilch. Now if you'd like to sell some 1.5oz cloth, I'd like to do some test with substituting a standard epoxy for butyrate dope. -- http://www.ernest.isa-geek.org/ "Ignorance is mankinds normal state, alleviated by information and experience." Veeduber |
Fabric covering processes | Jerry Guy | Home Built | 2 | January 29th 04 06:49 PM |
Fabric Work | Doug | Home Built | 9 | January 26th 04 03:31 AM |
fabric and tube by the ocean. | Ed Bryant | Home Built | 5 | December 6th 03 07:00 PM |
Soliciting Testimonials on Covering Systems | Larry Smith | Home Built | 5 | August 18th 03 09:24 AM |
Glass Goose | Dr Bach | Home Built | 1 | August 3rd 03 05:51 AM |
