At OSH last year, I used 3/4" iron water pipe. I bought 4' sections
(threaded at each end) and sawed them in half at an angle (to make ground penetration easier). Screwed a "T" connector on the end (for the rope), and that was it. You need a hatchet or small ax to put it in (carried anyway as part of my survival kit), but, when pounded in at an angle, they do not come out. I probably spent a total of $15 on everything. A bit heavy, but I don't use them much, so that's not a big problem for me. You could probably use a smaller diameter, but I tend to over-engineer things. (This was for a C172.) jerry Wass wrote: I used 7/16" rod, drilled out 1/2" nuts(to 7/16") & welded the h**l out of 'em-- actually got some 7/16" Spring steel from a spring mfg. co--nearly impossible to bend!! for a Stinson 108. Jim Weir wrote: Sport Aviation (EAA Magazine), April issue, pages 110-112. The article shows a system of metal rod-stakes and the 3-part chain with the repair link in the middle. The article goes into some detail on how to make a 3-part chain with a repair link (pretty trivial to figure that out) but says absolutely nothing about how the hex head (nut?) and locking nut get onto the rod. Now, my suspicion is that the top inch or so of the rod is threaded, a nut run down to the bottom of the thread, a lockwasher, then another nut. That's my SUSPICION. The article is silent on how this is done. Anybody wanna confirm my suspicions. If so, tell me how the guy, by his own admission with a minimal shop, can thread a 5/16 rod. That's a pretty hefty (and rather unusual) die/thread size. ¼-20 is pretty common, but I'm not a good enough machinist to say whether or not 5/16 is a garden variety tool. It is also true that if you pound a lot on that hex nut at the top (if that is what it is) there is no chance in hell that you will ever be able to separate the nut from the rod without a torch. I mean, I think it is a great idea, and I'd like nothing more than to get rid of those stupid corkscrews I've been using for thirty years, but I'd like some of your comments on how we might make it better. Thoughts? Jim Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com -- Remove "2PLANES" to reply. |
Suggestion for tieing down in loose sand:
Start with a 24" x24" x 3/4" chunk of pressure-treated plywood. Drill a hole in the center just large enough to pass through a 24" - 36" length of rope. Pass the rope through the hole, and tie it off to a 3/8" x 6" bolt. Tie the other end of the rope to a good (steel) caribeiner (sp?). Dig a hole in the sand using a camp shovel, sand shovel stolen from that kid in the beach, ice bucket from Holiday Inn, BigGulp cup, tablespoon, or whatever else ya have handy. Plant your anchor. Cover with sand. For very winds conditions, increase the size of your plywood to 36" sq. Suggestion for tieing down inside a large hangar with frequently open doors: (ok, so my plane only has a wing loading of 6oz. per sq. foot) 8 bags of cement, one Rubbermaid plastic tote bin, 4 24" sections of 3/8" rebar, and 8 6" sections of 2" pvc pipe. Dump 1 bag of cement into tote bin. Add water and mix. Tape over one end of a pvc section using duct tape. Insert into center of wet cement. Wait one day. Remove cement from tote bin and knock out tape. The result will be a nice neat 80lb weight block. Repeat 7 more times. While you're waiting, bend a loop into one end of each rebar, small enough to fit into the pvc pipe. Bend the other end 90 degrees. Stack your weight blocks on top of your rebar and tie down. Oh yea, this method works best when you trailer your aircraft to your flying site with dually pickup truck. Harry |
An Article on Unrecoverable Spins | Dave Swartz | Aerobatics | 0 | August 16th 03 06:49 AM |
