Airspeed of military planes
Old January 24th 04, 11:39 PM
Darkwing Duck
"Tetsuji Rai" wrote in message
s.com...
Airspeed limitation below 10000ft is usually 250kts unless you have been
authorized by the Administrator. However I guess it's a bit slow for
military fighters. So I am curious how fast military fighters fly in the
real world. I guess it's very dangerous military aircraft fly much fast
among civilian planes.
So how fast is short final in a F-14 or whatever? Always wanted to know.
Old January 25th 04, 02:28 AM
John R Weiss
"Darkwing Duck" wrote...
125 to 140 knots, depending on airplane and landing weight.
Old January 25th 04, 07:00 AM
Jim Baker
"Darkwing Duck" wrote in message
s.com...
fast
B-1B final is approx 155 +/- depending on weight.
JB
Old January 25th 04, 02:53 PM
Frijoles
Nozzles aft, Harrier approach speed will be in the 155kt +/-range. At 20
nozzles and auto flaps(normal for IFR final), you're somewhat slower but to
be honest I don't recall the airspeed because my primary reference was
always AoA. Depending on the type of landing you intend to make, once
you're in the visual environment, you transition to a higher nozzle angle
(60-75 depending...), and in some instances, STOL flaps where the flaps
program automatically as a function of nozzle angle. "On speed" for a
fixed-nozzle slow landing is around 110kts. The *very* slow rolling
landings you occasionaly see are called rolling vertical landings -- 60 kts
ground speed is the target but the transition to that speed will usually be
over the runway, not on approach final.
s.com...
fast
Old January 25th 04, 05:10 PM
Jim Baker
You're right Frijoles, in the Bone the correct answer for "What airspeed do
you fly on final" is "I don't know/care. I'm flying 7 AoA as required by
the Dash One". There is however, a chart of airspeed and gross weights that
every pilot has and, IAW the Landing Checklist, every final must have an
airspeed computed.
JB
"Frijoles" wrote in message
ink.net...
to
kts
be
s.com...
been
fast
Old January 25th 04, 06:00 PM
S. Sampson
the Dash One".
Is the AOA indicator a piece of string like Wilbur and Orville had?
airspeed computed.
That's in case the AOA indicator goes T.U. :-)
Old January 25th 04, 06:08 PM
Jim Baker
Yes, kind of. It's such a fast, heavy airplane that we use yarn rather than
string. ;-)
JB
"S. Sampson" wrote in message
news:2DSQb.6653$ce2.804@okepread03...
do
by
the Dash One".
an
airspeed computed.
Old January 25th 04, 11:52 PM
John R Weiss
"S. Sampson" wrote03...
No, but the yaw indicator on the F-14 is!
Old January 26th 04, 01:53 AM
Frijoles
I've known generally what (the string) was for a long time but never
bothered to ask when it was referenced (primarily)? High alpha stuff?
Landing pattern? Single engine would be an obvious case...anything else?
More for "departure prevention," TF 30 "management" or both?
"John R Weiss" wrote in message
news:ZMXQb.146068$I06.1467724@attbi_s01...
Old January 26th 04, 04:20 AM
John R Weiss
"Frijoles" wrote...
I never flew the Turkey, but probably all of the above.
I flew gliders with them, and they replaced the turn balance ball -- "step on
the knot".
Updated List of Military Information-Exchange Forums Otis Willie Naval Aviation 0 November 29th 04 03:16 AM
22 Aug 2004 - Today’s Military, Veteran, War and National Security News Otis Willie Naval Aviation 0 August 24th 04 07:47 AM
22 Aug 2004 - Today’s Military, Veteran, War and National Security News Otis Willie Military Aviation 0 August 24th 04 07:46 AM
bush rules! Be Kind Military Aviation 53 February 14th 04 05:26 PM
12 Dec 2003 - Today’s Military, Veteran, War and National Security News Otis Willie Naval Aviation 0 December 13th 03 12:01 AM
