"John Harlow" wrote in message ...
I'd like to get input on opinions on the "best" VFR altitude for a route. It seems to me it's largely based on distance, winds aloft and comfort level. Do you have a "rule of thumb" trading off altitude (and therefore safety margin) to avoid headwinds? Or, if winds aloft are to your advantage, how high would someone go in a 172 class aircraft before returns diminish? First, I think previous posters have said it well when they pointed out all the variables involved and concluded that "the best altitude" is different for each flight. Second, a minor correction: An earlier poster said he gained about 1 kt TAS per 1000'. The rule of thumb is 2% per 1000' so I'd expect more like 2-4 kt TAS gain per 1000', assuming your cruise speed is between 100 and 200 kts. That can offset a slight increase in head wind. Third, no one so far has pointed out the added safety that higher altitude buys in the event of an engine failure. From 7500' and assuming a 10:1 glide ratio (about right in practice for most small GA planes, with a small safety margin added on), you can glide 75,000' or over 12 nm. From 3000' you can glide only 5 nm. In civilized areas, airports are often close enough that the 7500' cruise would allow an engine out landing at an airport, while the 3000' cruise would probably not. Of course, you'd also have to practice side slips and S-turns in order to dump any excess altitude as you approach the runway. (Altitude becomes your fuel, but unlike a power plane, you have to land with "zero fuel.") I fly a motor glider and, in glider mode, must constantly think in terms of altitude to make an airport. Even though the engine is there and it's always started for me when I've needed it so far, the prudent assumption is that it won't start. That thinking carries over to engine on time too, but I'll admit that with a 50:1 glide ratio and a turbo charged engine, I have it a bit easier than you power guys. Even considering their reduced glide ratios, I think many power pilots don't adquately consider their planes as potential gliders when they lose an engine. From the few stories I've heard, it sounds like, no matter how much the pilot has been taught that the engine doesn't make the plane fly, a gut reaction often takes over when the engine quits and tells the pilot the plane is going to fall like a rock. That's probably why all pilots I know who are rated for both power and gliders say that all pilots should do at least a few landings in a glider. It helps get over that gut reaction. Martin |
John,
Do you have a "rule of thumb" trading off altitude (and therefore safety margin) to avoid headwinds? Two things you forgot: 1. The desire to see stuff on the ground. That often keeps me at 2000 AGL. 2. Weather. For me, flying VFR in northern Europe, that is most often the deciding factor in selecting a cruise altitude. It will keep me below 3000 on many days. -- Thomas Borchert (EDDH) |
Thomas Borchert wrote in message ...
John, Do you have a "rule of thumb" trading off altitude (and therefore safety margin) to avoid headwinds? Two things you forgot: 1. The desire to see stuff on the ground. That often keeps me at 2000 AGL. 2. Weather. For me, flying VFR in northern Europe, that is most often the deciding factor in selecting a cruise altitude. It will keep me below 3000 on many days. Likewise, with Class A Airspace around here with bases from 2500 to 6000 we are all scrunched into a pretty small area. So 2000 ft is pretty common. |
I like to clear the highest obstacle by at least 2000 ft.
On short XC (2 hours) I will stay about 2000 ft over the highest obstacle, on long XC (4-6 hours) I will get high, 12,000 or higher, depending on winds aloft. John Harlow wrote: I'd like to get input on opinions on the "best" VFR altitude for a route. It seems to me it's largely based on distance, winds aloft and comfort level. Do you have a "rule of thumb" trading off altitude (and therefore safety margin) to avoid headwinds? Or, if winds aloft are to your advantage, how high would someone go in a 172 class aircraft before returns diminish? |
Revisiting lapse rates (From: How high is that cloud?) | Icebound | Instrument Flight Rules | 5 | November 26th 04 09:41 PM |
FS: 1988 "Aces High" (Military Airplanes) Hardcover Edition Book | J.R. Sinclair | Aviation Marketplace | 0 | August 23rd 04 05:18 AM |
Fwd: [BD4] Source of HIGH CHTs on O-320 and O-360 FOUND! | Bruce A. Frank | Home Built | 1 | July 4th 04 07:28 PM |
MT. DIABLO HIGH SCHOOL CONCORD, CA PHOTOS | MT. DIABLO HIGH SCHOOL PHOTOS | Home Built | 1 | October 13th 03 03:35 AM |
High Flight NOTAM | Kirk Stant | Military Aviation | 1 | September 10th 03 03:31 AM |
