I think there is something wrong with your unit. You should be able to dim
it all the way to barely visible. |
I wrote that I can't dim my GPSMAP 295 sufficiently and Rod Madsen said he
can dim his to black. "Hudson Valley Amusement" agreed, and Chris Campbell said he can dim his to barely visible and suggested something might be wrong with my unit. Very interesting! I hadn't thought that it might be defective. My 295, S/N 98802510, is one of the first. I received it on 4 Feb 2000. I'm running the latest firmware, ver 2.50. Rod also said he'd like his to be brighter. Mine is plenty bright when running on external power. I wonder if a production change was made that lowered both the maximum and minimum brightness. I'll ask Garmin. Thanks for the responses. Jon |
I found that the contrast seemed to have an overly significant effect too
"Jon Woellhaf" wrote in message news:MFfZb.81462$jk2.424947@attbi_s53... I wrote that I can't dim my GPSMAP 295 sufficiently and Rod Madsen said he can dim his to black. "Hudson Valley Amusement" agreed, and Chris Campbell said he can dim his to barely visible and suggested something might be wrong with my unit. Very interesting! I hadn't thought that it might be defective. My 295, S/N 98802510, is one of the first. I received it on 4 Feb 2000. I'm running the latest firmware, ver 2.50. Rod also said he'd like his to be brighter. Mine is plenty bright when running on external power. I wonder if a production change was made that lowered both the maximum and minimum brightness. I'll ask Garmin. Thanks for the responses. Jon |
My 295 is also an early model S/N 98802855 which was sent back to the
factory for warranty repair 2/06/01. It has firmware from the latter date. My lack of brightness may be a defect or maybe the LCD is just getting old and tired. It's got a lot of hours on it. Rod "Jon Woellhaf" wrote in message news:MFfZb.81462$jk2.424947@attbi_s53... I wrote that I can't dim my GPSMAP 295 sufficiently and Rod Madsen said he can dim his to black. "Hudson Valley Amusement" agreed, and Chris Campbell said he can dim his to barely visible and suggested something might be wrong with my unit. Very interesting! I hadn't thought that it might be defective. My 295, S/N 98802510, is one of the first. I received it on 4 Feb 2000. I'm running the latest firmware, ver 2.50. Rod also said he'd like his to be brighter. Mine is plenty bright when running on external power. I wonder if a production change was made that lowered both the maximum and minimum brightness. I'll ask Garmin. Thanks for the responses. Jon |
Rod,
Why did you need to return your 295 for repair? Jon |
Bad connection inside. Couldn't see ship's power...only internal batteries.
Rod "Jon Woellhaf" wrote in message news:WjvZb.88591$jk2.435208@attbi_s53... Rod, Why did you need to return your 295 for repair? Jon |
I Rod also said he'd like his to be brighter. Mine is plenty bright when running on external power. I wonder if a production change was made that lowered both the maximum and minimum brightness. I have a GPS that is too bright too. Mine will go black but when you turn it up just a bit, its bright. I'm extra sensitive and like my lights very, very dim when flying at night (especially in the clouds where things reflect). My partner hasn't noticed. I assumed it was just me. One option is to put photo filter paper over it. |
I find mine way too dim in daylight with my shades on. Wish there was
an easy fix for that. Jon Woellhaf wrote: On several flights at night, I found my Garmin GPSMAP 295's display didn't dim enough to suite me, so I finally decided to try to fix the problem. I went to a local professional photographer's store and bought a packet of neutral density filter material for a few bucks. It had 0.3, 0.6 and 0.9 densities. The sheets are paper thin plastic. I cut pieces the size of my GPS's display and found 0.9 ND worked perfectly. Jon |
an easy fix for that. Gradient sunglasses. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
I'll keep that in mind next time I get glasses. But, these are
prescription shades and only half a year old. Jay Honeck wrote: I find mine way too dim in daylight with my shades on. Wish there was an easy fix for that. Gradient sunglasses. |
| KX-155 LEDs | Steven Barnes | Owning | 21 | July 11th 13 10:04 AM |
| A-6 Redar Display? | Mike Kanze | Naval Aviation | 0 | September 28th 04 02:34 AM |
| Airplane / space vehicle display models wanted | Aleta Jackson | General Aviation | 0 | May 19th 04 03:17 AM |
| Japanese Whine Over Enola Gay Display | [email protected] | Military Aviation | 42 | December 20th 03 12:32 AM |
| F-15C countermeasures display. | Gene | Military Aviation | 0 | August 5th 03 06:38 PM |
