Earnest,
For what it's worth, I just got back from day 1 at SWRFI and there IS a Dyke on display! I have to admit, it is a cool plane. Very different. But it took 26 years to build??? (Somebody was goofing off!) Richard |
Richard Lamb wrote:
Earnest, For what it's worth, I just got back from day 1 at SWRFI and there IS a Dyke on display! I have to admit, it is a cool plane. Very different. But it took 26 years to build??? (Somebody was goofing off!) Richard That sounds like N78BS, Bernie Schnanowski's bird (just look at me name dropping like I know people). Are you sure they didn't say that it's been flying 26years, which is right about the age of N78BS I believe. I'm about halfway through (quit laughing). 1500 of a 3000 hour project, and I've only been at it two years. -- http://www.ernest.isa-geek.org/ "Ignorance is mankinds normal state, alleviated by information and experience." Veeduber |
On Sat, 15 May 2004 04:11:28 GMT, Ernest Christley
wrote: That sounds like N78BS, Bernie Schnanowski's bird (just look at me name dropping like I know people). Are you sure they didn't say that it's been flying 26years, which is right about the age of N78BS I believe. Bernie was a member of a Seattle-area EAA Chapter when I joined about twenty years ago. His plane was flying then, and he'd originally completed it in New York before he moved to Seattle. The FAA lists the plane as a 1980 model. The current owner is the builder's son...I think he's named Bernie, as well. Ron Wanttaja |
Ron Wanttaja wrote:
On Sat, 15 May 2004 04:11:28 GMT, Ernest Christley wrote: That sounds like N78BS, Bernie Schnanowski's bird (just look at me name dropping like I know people). Are you sure they didn't say that it's been flying 26years, which is right about the age of N78BS I believe. Bernie was a member of a Seattle-area EAA Chapter when I joined about twenty years ago. His plane was flying then, and he'd originally completed it in New York before he moved to Seattle. The FAA lists the plane as a 1980 model. The current owner is the builder's son...I think he's named Bernie, as well. Ron Wanttaja Bernie senior is building a Sonex (I think) right now. Bernie junior now flies N78BS down around Atlanta. -- http://www.ernest.isa-geek.org/ "Ignorance is mankinds normal state, alleviated by information and experience." Veeduber |
Richard Lamb wrote: Earnest, For what it's worth, I just got back from day 1 at SWRFI and there IS a Dyke on display! I have to admit, it is a cool plane. Very different. But it took 26 years to build??? (Somebody was goofing off!) Richard That sounds like N78BS, Bernie Schnanowski's bird (just look at me name dropping like I know people). Are you sure they didn't say that it's been flying 26years, which is right about the age of N78BS I believe. I'm about halfway through (quit laughing). 1500 of a 3000 hour project, and I've only been at it two years. -- http://www.ernest.isa-geek.org/ Yep - Bernie was the guy I talked to. Nope - he said it only had 12 flying hours on it. Richard |
Richard Lamb wrote:
Ernest Christley wrote: Richard Lamb wrote: Earnest, For what it's worth, I just got back from day 1 at SWRFI and there IS a Dyke on display! I have to admit, it is a cool plane. Very different. But it took 26 years to build??? (Somebody was goofing off!) Richard That sounds like N78BS, Bernie Schnanowski's bird (just look at me name dropping like I know people). Are you sure they didn't say that it's been flying 26years, which is right about the age of N78BS I believe. I'm about halfway through (quit laughing). 1500 of a 3000 hour project, and I've only been at it two years. -- http://www.ernest.isa-geek.org/ Yep - Bernie was the guy I talked to. Nope - he said it only had 12 flying hours on it. Richard Must admit that I haven't a clue as to which bird you saw. Did you get a tail number? It's definitely not N78BS, though. -- http://www.ernest.isa-geek.org/ "Ignorance is mankinds normal state, alleviated by information and experience." Veeduber |
On Sat, 15 May 2004 01:45:03 +1200, "Cam" wrote:
What a crock of ****! I know most auto manufactures prohibit gas welding the stuff. MIG or TIG is OK and brass should not be a problem as long as the temp stays low enough. Some of the HSLA's apparantly are highly corrosion resistant as well. Brazing high strength alloy steel components of automotive bodies is STRICTLY FORBIDDEN. Mig and tig are acceptable if done to specifications - spot welding is most common. Simply because the slopeheads haven't built a robot to do it for them yet! Q' What part of an aircraft would you want to use 4130 sheet steel for? Ps I'd love to see a production car that has any TIG welding as part of its constuction. Cam................. By the same token, any torch brazed components, or any O/A welded? MIG and spot welding are almost exclusively used in automotive manufacturing, under VERY strictly controlled process. The weld spacings, weld heat, and weld positions are all ENGINEERED, and no deviations are permitted. This is to make sure the body is SAFE, and failure in case of collision damage etc is predictable. 4140 plate is used for gussets, finger straps, brackets, control bellcranks, landing gear fittings, float fittings, strut attatchments, spar mounting points, flap and aelerin controls, to mention a few. Something like 6 square feet overall in a Pegazair. |
Why 4130 tube? | Leon McAtee | Home Built | 31 | March 28th 04 03:04 PM |
Sport Pilot Leaves DOT for OMB, Latest News | Fitzair4 | Home Built | 3 | December 25th 03 02:49 AM |
Test..sorry, please ignore, just trying a new isp, news server, and newsreader. | Doug Sowder | Aerobatics | 0 | November 9th 03 06:04 PM |
It's all about the credibility you don't have, ChuckZZZ | Juan.Jimenez | Home Built | 8 | November 4th 03 01:03 PM |
News server problems on just this group | Chris W | Home Built | 9 | August 9th 03 02:32 AM |
