BINGO!! Understanding the QFE question requires the understanding that all
anticipated destinations are below the limit parameters of the Kollsman window....which is correct enough....but like most regulations, the way it's written is just plain nuts!!!! Why the hell the powers that be would put in a QFE option without explaining that it's tied directly to the Kollsman parameters on the altimeters is beyond me. I must know a hundred pilots who think it's an available option anywhere!!! :-)) It's funny about things like this. I've been reading everything I can find on the use of QFE, even that American Airlines had tried having their first officers monitoring a QFE altimeter with the Captain using a standard altimeter setting on final approaches, (which I understand is no longer the case BTW) and there is absolutely nothing out there that specifies the limiting parameter for QFE due to Kollsman range limits on the instrument for airports outside the instrument parameters. It's amazing that the governing agencies who write this stuff just assume that sooner or later all of us will just figure out that only airports under 3K feet are eligible for the QFE option. Interesting!!! I have to admit, it's basic enough, but for someone reading the regulations, the assumption is that a QFE setting is available at all anticipated destinations. I haven't found a reference anywhere that explains QFE as available only within the Kollsman range. Understanding the regulation seems to require a prior knowledge of the Kollsman limits to understand the situation completely, which in many cases causes much misinterpretation of the QFE options. Dudley "Todd Pattist" wrote in message ... "Dudley Henriques" wrote: how can a QFE setting be used at airports with elevations above our limits here in the U.S? I bet it can't. The highest point in England is 3210' and Scotland only goes to 4400'. Todd Pattist (Remove DONTSPAMME from address to email reply.) ___ Make a commitment to learn something from every flight. Share what you learn. |
Dudley Henriques wrote:
It's amazing that the governing agencies who write this stuff just assume that sooner or later all of us will just figure out that only airports under 3K feet are eligible for the QFE option. Interesting!!! Don't you have this backwards? Shouldn't it read: Just because QFE isn't common in the USA, the manufactorers assume that it's not common elsewhere either, and sell unsuitable instruments? Stefan |
![]() Dudley Henriques wrote: It's amazing that the governing agencies who write this stuff just assume that sooner or later all of us will just figure out that only airports under 3K feet are eligible for the QFE option. Interesting!!! If the Feds had to explain everything in the AIM, it would be the size of the Encyclopedia Brittanica. George Patterson Battle, n; A method of untying with the teeth a political knot that would not yield to the tongue. |
Dudley,
Another thing that's missing here is the British attitude to the rest of the world. They're an island in size but a continent in approach to life. And they don't like foreigners even more than Americans don't. They don't like things that weren't invented here and, in fact, have an entire organization, the Civil Aviation Authority, who enforce that idea whenever possible. The number of aircraft that are certified for aerobatics in the US, but not in the UK is staggering. I dunno, maybe physics really IS different here. They do things the way they want to, sod the rest of the world. The issue of the range of the Kollman window just isn't a concern over here as explained above, so I can see why no one would take that into account (unless Brit Kollman windows have a greater range, I don't know) Shawn "Dudley Henriques" wrote in message link.net... BINGO!! Understanding the QFE question requires the understanding that all anticipated destinations are below the limit parameters of the Kollsman window....which is correct enough....but like most regulations, the way it's written is just plain nuts!!!! Why the hell the powers that be would put in a QFE option without explaining that it's tied directly to the Kollsman parameters on the altimeters is beyond me. I must know a hundred pilots who think it's an available option anywhere!!! :-)) It's funny about things like this. I've been reading everything I can find on the use of QFE, even that American Airlines had tried having their first officers monitoring a QFE altimeter with the Captain using a standard altimeter setting on final approaches, (which I understand is no longer the case BTW) and there is absolutely nothing out there that specifies the limiting parameter for QFE due to Kollsman range limits on the instrument for airports outside the instrument parameters. It's amazing that the governing agencies who write this stuff just assume that sooner or later all of us will just figure out that only airports under 3K feet are eligible for the QFE option. Interesting!!! I have to admit, it's basic enough, but for someone reading the regulations, the assumption is that a QFE setting is available at all anticipated destinations. I haven't found a reference anywhere that explains QFE as available only within the Kollsman range. Understanding the regulation seems to require a prior knowledge of the Kollsman limits to understand the situation completely, which in many cases causes much misinterpretation of the QFE options. Dudley "Todd Pattist" wrote in message ... "Dudley Henriques" wrote: how can a QFE setting be used at airports with elevations above our limits here in the U.S? I bet it can't. The highest point in England is 3210' and Scotland only goes to 4400'. Todd Pattist (Remove DONTSPAMME from address to email reply.) ___ Make a commitment to learn something from every flight. Share what you learn. |
On Tue, 9 Mar 2004 at 16:19:25 in message
, Todd Pattist wrote: I bet it can't. The highest point in England is 3210' and Scotland only goes to 4400'. Correct but don't forget Snowdon in Wales at 3590' Snowdon in particular is quite formidable to look at as a pedestrian! I have walked up an easy route three times in my life and it frightened me! -- David CL Francis |
![]() "David CL Francis" wrote in message ... On Tue, 9 Mar 2004 at 16:19:25 in message , Todd Pattist wrote: I bet it can't. The highest point in England is 3210' and Scotland only goes to 4400'. Correct but don't forget Snowdon in Wales at 3590' Snowdon in particular is quite formidable to look at as a pedestrian! I have walked up an easy route three times in my life and it frightened me! -- David CL Francis Is there any one place in particular that you are talking about. I googled, and it is really pretty. -- Jim in NC --- Outgoing mail is certified Virus Free. Checked by AVG anti-virus system (http://www.grisoft.com). Version: 6.0.608 / Virus Database: 388 - Release Date: 3/3/2004 |
Nope, you're not missing anything, Dudley. Except maybe topography. I
don't think there ARE any airports higher than 2,000 feet in the UK, and there's very little terrain that high, even in the Highlands. The practice may have grown up here in Britain because high terrain isn't an issue. Most alitimeters over here these days are US manufacture anyways because most of the fleet were built in the US. Your understanding of QFE is correct, it's the station elevation such that the altimeter reads 0 at some point on the ground. It can lead to the odd problem now and again, but normally isn't an issue. My airport is at about 500 ft MSL, so if someone hasn't set their altimeter to QFE, but flies that pattern altitude as it reads on the instrument (without doing the mental arithmetic to ADD 1,000 ft), he'll come across the field at 500' AGL. Add to this that the Brits join the field at 2000 AGL on the side opposite downwind (known as "The Dead side"), descend to 1,000' AGL as they pass crosswind over the far end of the runway, then turn downwind and start their descent. This means you get clowns passing the far end of the runway at 500 ' AGL, just as you're passing through the same airspace in a climb in the Pitts. Normally not a problem as not many GA airplanes can be at 500' by the end of our runway, but it's happened to me once and is just something I have to keep an eye out for when flying the Pitts. As I say, in 300 hours flying in the UK, that's only happened to me once, so it's not common. Different way of "approaching" the same issue (sorry for the pun). Shawn "Dudley Henriques" wrote in message ink.net... "ShawnD2112" wrote in message ... Dudley, Interesting that the "right or wrongness" of the issue is of such a concern. Isn't it funny how different cultures view the same problem with different perspectives? Here in the UK, no motorcycle rider would even think of getting on a bike without a full set of leathers, helmet, and gloves. In the States, guys ride in shorts, sneakers, and no helmets where they can. On the other side of the coin, Brits "filter" through traffic on motorcycles, riding between lanes just to get through traffic faster, whether it be in the city or the highway. Most Americans think that's too dangerous to think about. Here in the UK, setting the altimeter to field elevation, QFE, before takeoff is not only allowed, it's taught and expected. Likewise, when approaching the airfield, you're expected to reset the altimeter to that airfield's QFE in the pattern. In the States, we would think that would lead to all kinds of altitude-related accidents. Different perspectives, but who's to say what's right and wrong? Shawn Hi Shawn; Your comment on using QFE in the UK brings up an interesting point that I'm researching right now and perhaps you can answer for me possibly. Here in the U.S., our altimeters have a Kollsman range of about 27.5 and 32.0. This, considering an average atmosphere, denies you setting an altimeter to 0 on any airport runway above about 2500 to 3000 feet MSL!!! I'm wondering, since QFE is common in the UK, and by definition QFE is a station pressure setting that will produce a 0 reading on the altimeter when on the ground at that station; are your altimeters in the UK equipped with a wider Kollsman range in the setting windows perhaps, and if not, how can a QFE setting be used at airports with elevations above our limits here in the U.S? It's an interesting point....or I must be missing something in my old age :-)) Dudley |
Sounds like a nightmare to me. I've zeroed the needle on occasion for
demonstration work, but I just don't get the logic behind the QFE lobby. It's just one more thing to worry about changing, and that can lead to serious problems in the air. I'm a standardization buff. Making as much a constant as opposed to a variable when it comes to flying has always seemed to me the best way to go with things. Having several MORE ways to use an altimeter just adds to normal altimeter confusion; it;s just one more thing that someone can forget to set or change or figure out. :-)) Dudley "ShawnD2112" wrote in message news:GPy3c.2813$m56.1401@newsfe1-win... Nope, you're not missing anything, Dudley. Except maybe topography. I don't think there ARE any airports higher than 2,000 feet in the UK, and there's very little terrain that high, even in the Highlands. The practice may have grown up here in Britain because high terrain isn't an issue. Most alitimeters over here these days are US manufacture anyways because most of the fleet were built in the US. Your understanding of QFE is correct, it's the station elevation such that the altimeter reads 0 at some point on the ground. It can lead to the odd problem now and again, but normally isn't an issue. My airport is at about 500 ft MSL, so if someone hasn't set their altimeter to QFE, but flies that pattern altitude as it reads on the instrument (without doing the mental arithmetic to ADD 1,000 ft), he'll come across the field at 500' AGL. Add to this that the Brits join the field at 2000 AGL on the side opposite downwind (known as "The Dead side"), descend to 1,000' AGL as they pass crosswind over the far end of the runway, then turn downwind and start their descent. This means you get clowns passing the far end of the runway at 500 ' AGL, just as you're passing through the same airspace in a climb in the Pitts. Normally not a problem as not many GA airplanes can be at 500' by the end of our runway, but it's happened to me once and is just something I have to keep an eye out for when flying the Pitts. As I say, in 300 hours flying in the UK, that's only happened to me once, so it's not common. Different way of "approaching" the same issue (sorry for the pun). Shawn "Dudley Henriques" wrote in message ink.net... "ShawnD2112" wrote in message ... Dudley, Interesting that the "right or wrongness" of the issue is of such a concern. Isn't it funny how different cultures view the same problem with different perspectives? Here in the UK, no motorcycle rider would even think of getting on a bike without a full set of leathers, helmet, and gloves. In the States, guys ride in shorts, sneakers, and no helmets where they can. On the other side of the coin, Brits "filter" through traffic on motorcycles, riding between lanes just to get through traffic faster, whether it be in the city or the highway. Most Americans think that's too dangerous to think about. Here in the UK, setting the altimeter to field elevation, QFE, before takeoff is not only allowed, it's taught and expected. Likewise, when approaching the airfield, you're expected to reset the altimeter to that airfield's QFE in the pattern. In the States, we would think that would lead to all kinds of altitude-related accidents. Different perspectives, but who's to say what's right and wrong? Shawn Hi Shawn; Your comment on using QFE in the UK brings up an interesting point that I'm researching right now and perhaps you can answer for me possibly. Here in the U.S., our altimeters have a Kollsman range of about 27.5 and 32.0. This, considering an average atmosphere, denies you setting an altimeter to 0 on any airport runway above about 2500 to 3000 feet MSL!!! I'm wondering, since QFE is common in the UK, and by definition QFE is a station pressure setting that will produce a 0 reading on the altimeter when on the ground at that station; are your altimeters in the UK equipped with a wider Kollsman range in the setting windows perhaps, and if not, how can a QFE setting be used at airports with elevations above our limits here in the U.S? It's an interesting point....or I must be missing something in my old age :-)) Dudley |
On Wed, 10 Mar 2004 15:27:22 GMT, "Dudley Henriques"
wrote: Sounds like a nightmare to me. I've zeroed the needle on occasion for demonstration work, but I just don't get the logic behind the QFE lobby. It's just one more thing to worry about changing, and that can lead to serious problems in the air. I'm a standardization buff. Making as much a constant as opposed to a variable when it comes to flying has always seemed to me the best way to go with things. Having several MORE ways to use an altimeter just adds to normal altimeter confusion; it;s just one more thing that someone can forget to set or change or figure out. :-)) Dudley As for confusion, I'm from the UK but learned in USA and don't find a problem with QNH or QFE but add to that Flight Levels and Regional Pressure then you can really have fun. VFR is usually flown (enroute) using Regional Pressure which is valid for 1 hour for a specific area. It's equivalent to the estimated lowest QHN for the next hour. I doubt it's ever more than a few millibars different to QNH so the error is likely to be small therefore why bother? What is a really odd is that IFR is flown on flight levels and in the UK that's frequently from 3000ft upwards. If you're flying VFR at any height you can choose to use either QNH (Regional) or FL. (Note the UK transition altitude is usually 3000ft.) In the aircraft I fly, in the UK, I have the luxury of being able to set the lower altimeter on QHN and the upper one on whatever I'm flying at the time (QNH, QFE, Regional or FL). Additionally the transponder reads FL. It was rather nice in January to land at Death Valley (-200ft) then back to Las Vegas at 2005ft. Made the Wife wonder why the altimeter did not read zero when we landed! David Piper Warrior G-BHJO Scotland, UK E-mail (Remove Space after pilot): pilot |
Dudley,
I agree with your statement about keeping things standardized. I like to keep everything that way so I can save what little brain capacity I have for handling the deviations from standard. Likewise, I apply that same logic to trimming. I trim for nearly any condition I'll be in for more than about 30 seconds, especially on landing. Nothing to do with stick forces, per se, but then I'm only flying the airplane away from the trim. The airplane's flying the basic line all by itself, I'm just flying the bits that are away from that line. Keeps life less exciting but a bit longer lasting, I reckon. Funnily enough, though, this QFE thing is one that you soon get used to and find that it seldom causes a problem. A person is just as likely to get the mental arithmetic wrong on entering the pattern as they are to forget to set QFE/QNH. Nearly all airfields here have a manned radio most of the time. It's standard procedure to give arriving aircraft the active runway and the QFE, so you get the information and a reminder. Most airfields have a standard 1,000 foot pattern, 2,000 foot overhead join (now, if you want to talk about a stupid procedure, let's get started on THAT one!), unless otherwise noted, so you reset QFE, shoot for 2,000 feet and Bob's your uncle. Interesting your input in the other thread about spinning the Mustang. When I was volunteering at The Fighter Collection, I was assigned to Moose, a D model, and used to spend a bit of time reading the pilot's handbook and the maintenance manual. (Never got to fly in her, though) I seem to remember the Mustang required something like 10,000 feet to recover from a spin. True in your experience? Shawn "Dudley Henriques" wrote in message link.net... Sounds like a nightmare to me. I've zeroed the needle on occasion for demonstration work, but I just don't get the logic behind the QFE lobby. It's just one more thing to worry about changing, and that can lead to serious problems in the air. I'm a standardization buff. Making as much a constant as opposed to a variable when it comes to flying has always seemed to me the best way to go with things. Having several MORE ways to use an altimeter just adds to normal altimeter confusion; it;s just one more thing that someone can forget to set or change or figure out. :-)) Dudley "ShawnD2112" wrote in message news:GPy3c.2813$m56.1401@newsfe1-win... Nope, you're not missing anything, Dudley. Except maybe topography. I don't think there ARE any airports higher than 2,000 feet in the UK, and there's very little terrain that high, even in the Highlands. The practice may have grown up here in Britain because high terrain isn't an issue. Most alitimeters over here these days are US manufacture anyways because most of the fleet were built in the US. Your understanding of QFE is correct, it's the station elevation such that the altimeter reads 0 at some point on the ground. It can lead to the odd problem now and again, but normally isn't an issue. My airport is at about 500 ft MSL, so if someone hasn't set their altimeter to QFE, but flies that pattern altitude as it reads on the instrument (without doing the mental arithmetic to ADD 1,000 ft), he'll come across the field at 500' AGL. Add to this that the Brits join the field at 2000 AGL on the side opposite downwind (known as "The Dead side"), descend to 1,000' AGL as they pass crosswind over the far end of the runway, then turn downwind and start their descent. This means you get clowns passing the far end of the runway at 500 ' AGL, just as you're passing through the same airspace in a climb in the Pitts. Normally not a problem as not many GA airplanes can be at 500' by the end of our runway, but it's happened to me once and is just something I have to keep an eye out for when flying the Pitts. As I say, in 300 hours flying in the UK, that's only happened to me once, so it's not common. Different way of "approaching" the same issue (sorry for the pun). Shawn "Dudley Henriques" wrote in message ink.net... "ShawnD2112" wrote in message ... Dudley, Interesting that the "right or wrongness" of the issue is of such a concern. Isn't it funny how different cultures view the same problem with different perspectives? Here in the UK, no motorcycle rider would even think of getting on a bike without a full set of leathers, helmet, and gloves. In the States, guys ride in shorts, sneakers, and no helmets where they can. On the other side of the coin, Brits "filter" through traffic on motorcycles, riding between lanes just to get through traffic faster, whether it be in the city or the highway. Most Americans think that's too dangerous to think about. Here in the UK, setting the altimeter to field elevation, QFE, before takeoff is not only allowed, it's taught and expected. Likewise, when approaching the airfield, you're expected to reset the altimeter to that airfield's QFE in the pattern. In the States, we would think that would lead to all kinds of altitude-related accidents. Different perspectives, but who's to say what's right and wrong? Shawn Hi Shawn; Your comment on using QFE in the UK brings up an interesting point that I'm researching right now and perhaps you can answer for me possibly. Here in the U.S., our altimeters have a Kollsman range of about 27.5 and 32.0. This, considering an average atmosphere, denies you setting an altimeter to 0 on any airport runway above about 2500 to 3000 feet MSL!!! I'm wondering, since QFE is common in the UK, and by definition QFE is a station pressure setting that will produce a 0 reading on the altimeter when on the ground at that station; are your altimeters in the UK equipped with a wider Kollsman range in the setting windows perhaps, and if not, how can a QFE setting be used at airports with elevations above our limits here in the U.S? It's an interesting point....or I must be missing something in my old age :-)) Dudley |
Instrument Rating Checkride PASSED (Very Long) | Alan Pendley | Instrument Flight Rules | 24 | December 16th 04 02:16 PM |
Please help -- It's down to the wire | Jay Honeck | Home Built | 12 | July 14th 04 06:05 PM |
FA: WEATHER FLYING: A PRACTICAL BOOK ON FLYING | The Ink Company | Aviation Marketplace | 0 | November 5th 03 12:07 AM |
How I got to Oshkosh (long) | Doug | Owning | 2 | August 18th 03 12:05 AM |
Airport Manager position, Fitchburg, MA | David Reinhart | Piloting | 6 | August 12th 03 11:46 PM |
