On Mon, 17 May 2004 20:54:38 +0100, anonymous coward
wrote: :On Mon, 17 May 2004 13:29:04 -0400, charles.k.scott wrote: : : On Sat, 15 May 2004 15:09:43 +0100, anonymous coward : wrote: : :The argument, provided I'm not confabulating it, was that there was a :shortage of combat pilots so it was worthwhile building a 'plane that :let them live to crash again. I've never heard of crash-survivability being a factor in WW2 fighers, but I have read that more Navy pilots were lost in training than in combat. |
On Fri, 14 May 2004 22:31:56 +0100, anonymous coward
wrote: I'd be grateful if anyone can direct me towards links about the relative safety of different types of homebuilt aircraft. Not figures I can use to prove to myself that flying a homebuilt is safe, but a discussion of all the factors that affect safety in homebuilt aircraft. I haven't found much through google - perhaps it's a contentious subject? Though I realise that most of the safety equation is down to the pilot, presumably some types have safer flying characteristics than others? And presumably crashes in some types are more survivable than crashes in others in the same way as some car-wreck scenarios that would have been lethal 20 years ago are easily survivable today? AC David Thurston wrote a book called "design for safety" heavens! published by tab books 9 years ago. homebuilts are usually lighter in weight which makes them quicker to move in turbulence. control forces are usually quite light. they arent any weaker. most designs are built to the same "g" range as commercial designs. every homebuilt is a one off constructed aircraft. it has subtle differences from every other homebuilt ever built. as well they are usually lighter built. keep all the switches I took over a hundred hours to get really comfortable in my homebuilt but now I wouldnt want to go back to commercially produced aircraft. persist and you will grow to love the quick responsive flight characteristics. things break occasionally. I've lost the tailwheel 3 times now and I am gradually evolving the design. I think I have it just about right at last. you can do that with a homebuilt because you dont have a certified system to confine you. you also dont have the benefits of the engineering and flight testing that went into sorting out a commercial design. more than any other aircraft type a homebuilt's safety rests squarely on the abilities of the pilot. the upside of that reality is that you will fly an aircraft you own for more hours and you will be a more competent pilot as a result. little things add to survivability. use a lap sash belt or a 5 point aerobatic harness. dont have switches in the panel area just in front of you. dont have a sharp edge to the top of the instrument panel. dont fly the thing if there is a maintenance issue. fix it first. I have never felt endangered in all the time I've flown mine. once you get a real aircraft in your hands I'm sure you'll feel just at ease. Stealth Pilot |
On Fri, 14 May 2004, anonymous coward wrote:
a discussion of all the factors that affect safety in homebuilt aircraft. My homebuilt airplane design has saved my bacon at least twice. It is a canard pusher. First, I landed very hard in high winds. I broke the nose gear linkage and stopped quickly on the runway. A fellow canard builder flew in with epoxy and cloth to patch the road rash, and another fellow mailed me some brake calipers. A few weeks later, two men perished when they landed hard in a tractor engine airplane. Their nose gear failed, the prop hit and started a fire which they did not survive. Second: After one 1,000 mile long, very high flight (I have oxygen now), I turned base to final too tightly, and the canard stalled. I leveled her off and builtup speed, and did an extra trip around the pattern before landing. I often read about stall/spin crashes, and am very glad to fly this bird. It does prefer clean paved runways, it seems much more safe to me. I learned to fly after I turned 50 years old, and do make newbie mistakes. George Graham RX-7 Powered Graham-EZ, N4449E Homepage http://bfn.org/~ca266 |
![]() "George A. Graham" wrote in message ... On Fri, 14 May 2004, anonymous coward wrote: a discussion of all the factors that affect safety in homebuilt aircraft. My homebuilt airplane design has saved my bacon at least twice. It is a canard pusher. First, I landed very hard in high winds. I broke the nose gear linkage and stopped quickly on the runway. A fellow canard builder flew in with epoxy and cloth to patch the road rash, and another fellow mailed me some brake calipers. A few weeks later, two men perished when they landed hard in a tractor engine airplane. Their nose gear failed, the prop hit and started a fire which they did not survive. Second: After one 1,000 mile long, very high flight (I have oxygen now), I turned base to final too tightly, and the canard stalled. I leveled her off and builtup speed, and did an extra trip around the pattern before landing. I often read about stall/spin crashes, and am very glad to fly this bird. It does prefer clean paved runways, it seems much more safe to me. I learned to fly after I turned 50 years old, and do make newbie mistakes. George Graham RX-7 Powered Graham-EZ, N4449E Homepage http://bfn.org/~ca266 I saw a Long-Eze land gear-up at Oshkosh. All the emergency vehicles sped to the downed aircraft. Adrenaline pumped. Not to worry, though. The nose had a little bumper underneath which was barely even scuffed. |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | April 5th 04 03:04 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 2 | February 2nd 04 11:41 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 1 | January 2nd 04 09:02 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | October 2nd 03 03:07 AM |
Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 04:50 PM |
