An F-18 Naval Strike Fighter crashed at RDU today. It appears it was taxing
or in the process of taking off, but never lifted off. Might have been wake turbulance from another F-18 that had just departed. http://www.wral.com/news/2953163/detail.html |
Tom Hyslip wrote: Might have been wake turbulance from another F-18 that had just departed. Aircraft on the ground do not burst into flames due to wake turbulence. George Patterson Battle, n; A method of untying with the teeth a political knot that would not yield to the tongue. |
Just reading from the reports. The controllers said it never left the
ground. Doesn't sound right to me either. Maybe it started to climb, then had problems. "G.R. Patterson III" wrote in message ... Tom Hyslip wrote: Might have been wake turbulance from another F-18 that had just departed. Aircraft on the ground do not burst into flames due to wake turbulence. George Patterson Battle, n; A method of untying with the teeth a political knot that would not yield to the tongue. |
Wake turbulence with teeth, I'd say.
Maybe P factor took it off the runway hee hee hee mac
George,
an uncontained failure of one of the engine would cause swerving and can puncture a fuel tank with hot metal and start a fire.... Michelle G.R. Patterson III wrote: Tom Hyslip wrote: Might have been wake turbulance from another F-18 that had just departed. Aircraft on the ground do not burst into flames due to wake turbulence. George Patterson Battle, n; A method of untying with the teeth a political knot that would not yield to the tongue. -- Michelle P ATP-ASEL, CP-AMEL, and AMT-A&P "Elisabeth" a Maule M-7-235B (no two are alike) Volunteer Pilot, Angel Flight Mid-Atlantic Volunteer Builder, Habitat for Humanity |
Might have been wake turbulance from another F-18 that had just departed. Aircraft on the ground do not burst into flames due to wake turbulence. George Patterson Ain't speculation fun? I'm with you, George, wake turbulence, not. Section (one plus playmate) and even flight (of four) takeoffs are done without mishap. That aircraft is too heavy and the engines produce too much thrust. How come nobody has speculated on (1) blowing a tire, (2) collapsing a gear, (3) combination of 1+2, (4) because of 1 or 2 or 3, rupturing a drop tank or wing tank [nah, skip the wing tank -- bullet proof fuel cell there], (5) rotor burst, (6) Al Queda attack. Having some familiarity with military mishap investigation, unless some kind soul in the CHINFO office wants to release the information or some good journalist [been there, done that] can weasel it out, it will be months before any kind of preliminary finding will come out of the Navy. Meanwhile, y'all keep on spekleatin', y'hear. |
possible situations... pure speculation...
blown tire on take off.. causing problems... directional control, FOD into the engine.. engine gauges spike.. engine starts tearing itself apart.. or some other FOD on the runway thrown up by the preceding jet.. ingested into engine.. scenario continues.. pilot realizing engine is about to come apart and aircraft is not responding to braking decides to use his e-ticket ride coupon.. as an instructor once said to me... never try to save an airplane that is trying to kill you.. do not hesitate to give it back to the tax payers for another one.. planes can be replaced .... combat warriors are harder to come by.. BT "Tom Hyslip" wrote in message . com... An F-18 Naval Strike Fighter crashed at RDU today. It appears it was taxing or in the process of taking off, but never lifted off. Might have been wake turbulance from another F-18 that had just departed. http://www.wral.com/news/2953163/detail.html |
Casey
I also have experience with USAF/Navy accident investigations. For some reason the flight of 2 did not make a formation take off. Sq policy at Civilian Fields. Runway to narrow. #2 experience level, etc. To continue, when I was flying heavy iron and we landed at a Civilian Field for fuel, I always pulled the gear ASAP on takeoff R/W a foot off the ground with burner flame hitting the R/W and looking like you were riding on the flame. In the case in question, if he had pulled the gear as he broke ground and then hit jet wash from the leader and it slapped the bird back against the R/W the pilot not knowing how much damage was caused punched. The bird then continued skidding down the R/W and catching fire. They don't normally report the cause of an accident unless it causes some civilian damage which this one didn't. The basic accident report is 'restricted data' and will not be released to the public. If things warrant and/or if the public is screaming then they hold a formal accident board with everyone sworn and all have the ability to not answer/testfy like in a civilian court. So to end, as Casey said, have at it. BJ Shame to waste a multi million dollar aircraft for any reason. Big John On Sat, 27 Mar 2004 05:13:48 GMT, "Casey Wilson" wrote: Might have been wake turbulance from another F-18 that had just departed. Aircraft on the ground do not burst into flames due to wake turbulence. George Patterson Ain't speculation fun? I'm with you, George, wake turbulence, not. Section (one plus playmate) and even flight (of four) takeoffs are done without mishap. That aircraft is too heavy and the engines produce too much thrust. How come nobody has speculated on (1) blowing a tire, (2) collapsing a gear, (3) combination of 1+2, (4) because of 1 or 2 or 3, rupturing a drop tank or wing tank [nah, skip the wing tank -- bullet proof fuel cell there], (5) rotor burst, (6) Al Queda attack. Having some familiarity with military mishap investigation, unless some kind soul in the CHINFO office wants to release the information or some good journalist [been there, done that] can weasel it out, it will be months before any kind of preliminary finding will come out of the Navy. Meanwhile, y'all keep on spekleatin', y'hear. |
Big John wrote: They don't normally report the cause of an accident unless it causes some civilian damage which this one didn't. No damage, but a close call. The plane ended up about 250 feet from a passenger terminal, having passed near passenger jets on the ramp along the way. The newspaper had a diagram that showed the airplane beginning along runway 23L, the pilot ejecting as he passed taxiway charlie, and the plane skidding across taxiway alpha and a corner of the terminal A ramp before ending up past the end of the ramp. Kind of a busy area. Most GA traffic uses that side of the airport, too. It's a little higher profile than the typical military mishap. Not too many airline passengers get to watch unmanned tactical jets roll/bounce/tumble (whatever it in fact did) by as they wait for departure. I guess we'll see if that leads the Navy to release any information from the investigation. Here are a couple more local media links: Jet crashes at RDU (Saturday 3/27) http://www.newsobserver.com/news/sto...-3071734c.html Cause of crash at RDU unclear (Sunday 3/28) http://www.newsandobserver.com/front...-3073838c.html - Nathan |
| Bizzare findings of Flight 93 crash in PA on 9-11 | Laura Bush murdered her boy friend | Military Aviation | 38 | April 12th 04 09:10 PM |
| F/A-18 Crash at RDU - 3/26 | Mike Kopack | Military Aviation | 0 | March 26th 04 09:48 PM |
| AF investigators cite pilot error in fighter crash | Otis Willie | Military Aviation | 0 | January 9th 04 10:55 PM |
| Sunday's Crash in LI Sound | Marco Leon | Piloting | 0 | November 5th 03 05:34 PM |
| Homemade plane crash | Big John | Home Built | 9 | October 17th 03 07:45 PM |
