"Peter Duniho" wrote in message ...
For experimentals, it sounds like (from one of George's earlier posts) that people ARE looking to incorporate small turbines into light airplanes, but I doubt it's cost effective. As near as I can tell, for a given horsepower, turbines are simply more expensive and for sure it's harder to find someone qualified to work on them. Maybe one day they'll be ubiquitous in a wide variety of applications, and they'll start showing up in light airplanes too. But it seems to me that until there's a huge market for certificated low-horsepower turbine engines, no one's going to bother working on them. Pete I know there's been an RV-4T - they grafted a turboprop onto the front of an RV-4. I think the biggest problem they had (besides fuel consumption) was that they didn't mount the exhaust stacks right, and it "backed up" a bit in the engine. |
In article , Thomas J. Paladino Jr. wrote:
So it begs the question, why are there no small turboprops in the 100-300hp range for use on GA aircraft? Cost. I believe even the relatively small turbines are two orders of magnitude more expensive than the piston engine of the same power. Turbines tend to have parts made from exotic metals that aren't straightforward to manufacture. Also, small turbines are markedly less fuel efficient than a piston engine of the same horsepower (especially at the altitudes we fly at). If it wasn't for the exhorbitant cost of a new turbine, I'd far prefer them - easier to operate, cooling issues aren't as problematic, and with modern electronic control I'm sure that operating one can be made damn-foolproof, not just foolproof. -- Dylan Smith, Castletown, Isle of Man Flying: http://www.dylansmith.net Frontier Elite Universe: http://www.alioth.net "Maintain thine airspeed, lest the ground come up and smite thee" |
So it begs the question, why are there no small turboprops in the 100-300hp range for use on GA aircraft? Cost. I believe even the relatively small turbines are two orders of magnitude more expensive than the piston engine of the same power. Turbines tend to have parts made from exotic metals that aren't straightforward to manufacture. Also, small turbines are markedly less fuel efficient than a piston engine of the same horsepower (especially at the altitudes we fly at). If it wasn't for the exhorbitant cost of a new turbine, I'd far prefer them - easier to operate, cooling issues aren't as problematic, and with modern electronic control I'm sure that operating one can be made damn-foolproof, not just foolproof. I'm ignorate of the technology, but seem to remember the airlines went to jets because fuel costs were lower and they were lest costly to keep running. If they scaled down well, I expect we'd see them in hybred cars long before they'd be in general aviation aircraft. You don't need rapid response times in a hybred, but the 'spool-up' time in a small plane could take a lot of getting used to by pilots who need lots of throttle jockeying to land their airplanes. I take that back -- it wouldn't take a lot of time, there'd be aluminum junk that used to be airplanes near the approach end of lots of airports. |
Hi tony,
I'm ignorate of the technology, but seem to remember the airlines went to jets because fuel costs were lower and they were lest costly to keep running. .... and because passengers appreciated not to arrive in a three-engine Connie after departing in a four engine a few hours ago. Enginge failures were a main issue on that. If they scaled down well, I expect we'd see them in hybred cars long before they'd be in general aviation aircraft. You don't need rapid response times in a hybred, but the 'spool-up' time in a small plane could take a lot of getting used to by pilots who need lots of throttle jockeying to land their airplanes. I take that back -- it wouldn't take a lot of time, there'd be aluminum junk that used to be airplanes near the approach end of lots of airports. I don't think so. Spool up time on modern turbines is marginal compared with early turboprop/jet engines. Compared with the workload a high power piston is causing, every turbine would be much safer. I bet on that. Regards, Peter |
Peter
As I have posted before. On the early Jets (F-80A/B) it took 21 seconds to accelerate from idle rpm to full rpm. You made your go around decision on base leg. In actul practive, we only reduced rpm to around 65% (idle was 35%) in the pattern until "we had the runway made", to reduce the spool up time. Since those days, they have decreased the spool up time to a pittance .. On turbo props however, they run the engine at a constant rpm during flight and all you do with the throttle is change the prop pitch. With this you can go from no thrust to full thrust instantly. Fly safe. Big John On Mon, 24 May 2004 14:50:46 +0200, Peter Hovorka wrote: Hi tony, I'm ignorate of the technology, but seem to remember the airlines went to jets because fuel costs were lower and they were lest costly to keep running. ... and because passengers appreciated not to arrive in a three-engine Connie after departing in a four engine a few hours ago. Enginge failures were a main issue on that. If they scaled down well, I expect we'd see them in hybred cars long before they'd be in general aviation aircraft. You don't need rapid response times in a hybred, but the 'spool-up' time in a small plane could take a lot of getting used to by pilots who need lots of throttle jockeying to land their airplanes. I take that back -- it wouldn't take a lot of time, there'd be aluminum junk that used to be airplanes near the approach end of lots of airports. I don't think so. Spool up time on modern turbines is marginal compared with early turboprop/jet engines. Compared with the workload a high power piston is causing, every turbine would be much safer. I bet on that. Regards, Peter |
tony wrote: I'm ignorate of the technology, but seem to remember the airlines went to jets because fuel costs were lower and they were lest costly to keep running. Kerosene is much cheaper than 140 octane avgas, and turbines are easier to maintain than large Pratt & Whitney radials. Neither of these facts is pertinent to light aircraft. George Patterson I childproofed my house, but they *still* get in. |
Slightly off-topic, why has no-on mentioned diesel engines (that run on
Jet-A1)? This has got to be the way to go, better economy, better operation at altitude, simpler mechanicals (less to break) and FADEC/ECU controlled? For the majority of GA this has got to be the long-term answer, even in the US. Europe is leading the way on this topic, oh did I mention gas prices? - BR "G.R. Patterson III" wrote in message ... tony wrote: I'm ignorate of the technology, but seem to remember the airlines went to jets because fuel costs were lower and they were lest costly to keep running. Kerosene is much cheaper than 140 octane avgas, and turbines are easier to maintain than large Pratt & Whitney radials. Neither of these facts is pertinent to light aircraft. George Patterson I childproofed my house, but they *still* get in. |
Barney Rubble wrote: Slightly off-topic, why has no-on mentioned diesel engines (that run on Jet-A1)? This has got to be the way to go, better economy, better operation at altitude, simpler mechanicals (less to break) and FADEC/ECU controlled? Actually, because of the higher compression ratios, the mechanicals are not simpler. For the majority of GA this has got to be the long-term answer, even in the US. I agree. They are more expensive than gas-burners, but it will be nice when it becomes possible to replace my O-320 with a diesel in the 180hp range (IMO). George Patterson I childproofed my house, but they *still* get in. |
Barney
See my post (new thread) on SMA Diesels that are FAA certified and delivery is starting for a 230 HP, 4 cyl version. No price quoted, but best guess is $80K-$90K Big John ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ On Mon, 24 May 2004 08:59:51 -0500, "Barney Rubble" wrote: Slightly off-topic, why has no-on mentioned diesel engines (that run on Jet-A1)? This has got to be the way to go, better economy, better operation at altitude, simpler mechanicals (less to break) and FADEC/ECU controlled? For the majority of GA this has got to be the long-term answer, even in the US. Europe is leading the way on this topic, oh did I mention gas prices? - BR "G.R. Patterson III" wrote in message ... tony wrote: I'm ignorate of the technology, but seem to remember the airlines went to jets because fuel costs were lower and they were lest costly to keep running. Kerosene is much cheaper than 140 octane avgas, and turbines are easier to maintain than large Pratt & Whitney radials. Neither of these facts is pertinent to light aircraft. George Patterson I childproofed my house, but they *still* get in. |
"tony" wrote in message I'm ignorate of the technology, but seem to remember the airlines went to jets because fuel costs were lower and they were lest costly to keep running. 'Tis true that kerosene was substantially cheaper than very high octane gasoline (typically 140+, iirc) then, but the main reasons were 1) maint cost -- those high powered turbo-supercharged radials on the Connies and DC-7s were tweaked to within an inch of their lives, and would fail regularly. (My brother-in-law's father worked for AA in BOS in that era, and the standing joke was that they put four engines on those things so they could arrive with at least two or three); and 2) cruise speed/payload -- the transition to jet transports allowed schedulers to carry many more passengers at about 50% more speed. The implications of this change on system capacity and operation, particularly trans-continental and trans-oceanic flights, were astounding and very far reaching. |
| Thread Tools | |
| Display Modes | |
| Small Aircraft Transportation System (SATS) first practical trial | Larry Dighera | Piloting | 0 | November 27th 03 04:11 PM |
| Order your FREE Small Blue Planet Toys Christmas Catalog before Oct 20th! | Small Blue Planet Toys | Aviation Marketplace | 0 | October 15th 03 06:26 PM |
| Air Force announces winner in Small Diameter Bomb competition | Otis Willie | Military Aviation | 0 | August 30th 03 04:06 AM |
| Small Blue Planet Toys goes Postal !! Economy Shipping Options now availalble | Small Blue Planet Toys | Aviation Marketplace | 0 | July 11th 03 05:00 PM |
| HUGE Summer SALE + Free Shipping @ Small Blue Planet Toys | Small Blue Planet Toys | Aviation Marketplace | 0 | July 9th 03 12:53 AM |
