Thomas,
There are some smaller turboprops but the economics just aren't there to put them into mass production. The market is quite small and the specific fuel consumption of a turbine versus a piston means that if you put it on your Cessna 210, for example, you can't carry enough fuel to get anywhere and still put people in the cabin. Plus, the simple cost of the technology and the metals to handle the heat in a turbine engine makes it almost impossible to compete with other types of engines in that horsepower range. There was an article on the subject of specific fuel consumption and load carrying ability of turbines in little airplanes in Aviation Consumer a couple of years back. For the 100-300 hp range it looks as if going back to diesels, as was explored in the 1930s, may be appropriate. All the best, Rick "Thomas J. Paladino Jr." wrote in message .. . I have always wondered why there are no small GA turboprops. It seems like most of the major problems & maintenance issues associated with GA aircraft are related to the piston motor, and as far as I can tell, turboprops are much more reliable, fuel efficient, smoother running and easier to maintain. So it begs the question, why are there no small turboprops in the 100-300hp range for use on GA aircraft? I would think that turbine engines of this size would be relatively easy to produce, and would be ideal for GA applications. The smoother operation and lower vibration levels would also ease wear and tear on the entire airframe and avionics components. So what's the deal? Does turbine technology not translate downwards very well? Would it be cost prohibitive? Am I entirely missing something? |
I have always wondered why there are no small GA turboprops. It seems like most of the major problems & maintenance issues associated with GA aircraft are related to the piston motor, and as far as I can tell, turboprops are much more reliable, fuel efficient, smoother running and easier to maintain. So it begs the question, why are there no small turboprops in the 100-300hp range for use on GA aircraft? I would think that turbine engines of this size would be relatively easy to produce, and would be ideal for GA applications. The smoother operation and lower vibration levels would also ease wear and tear on the entire airframe and avionics components. So what's the deal? Does turbine technology not translate downwards very well? Would it be cost prohibitive? Am I entirely missing something? Cessna 210's and Bonanza's can be found with turbo prop retrofits. These engines run a long time but when its time for a hot overhaul, its going to cost you an arm and a leg. |
Cost and effficiency. Small turbines are very expensive fuel guzzlers.
Large turbines (airliner size) are efficient but small ones aren't. The 1000hp engines on my MU-2 have a bsfc of .52 and smaller engines would be even worse. Piston engines are in the .40 area. Diesels are more promising. Mike MU-2 "Thomas J. Paladino Jr." wrote in message ... I have always wondered why there are no small GA turboprops. It seems like most of the major problems & maintenance issues associated with GA aircraft are related to the piston motor, and as far as I can tell, turboprops are much more reliable, fuel efficient, smoother running and easier to maintain. So it begs the question, why are there no small turboprops in the 100-300hp range for use on GA aircraft? I would think that turbine engines of this size would be relatively easy to produce, and would be ideal for GA applications. The smoother operation and lower vibration levels would also ease wear and tear on the entire airframe and avionics components. So what's the deal? Does turbine technology not translate downwards very well? Would it be cost prohibitive? Am I entirely missing something? |
"Mike Rapoport" wrote in message link.net...
Diesels are more promising. And can run on the same gas. |
"Robert M. Gary" wrote in message om... "Mike Rapoport" wrote in message link.net... Diesels are more promising. And can run on the same gas. Only some can run on jet fuel. Jet fuel has almost no lubrication qualities, while diesel does. Jet fuel will eat up some things, like fuel pumps. -- Jim in NC --- Outgoing mail is certified Virus Free. Checked by AVG anti-virus system (http://www.grisoft.com). Version: 6.0.688 / Virus Database: 449 - Release Date: 5/18/2004 |
Morgans wrote: Only some can run on jet fuel. Jet fuel has almost no lubrication qualities, while diesel does. Jet fuel will eat up some things, like fuel pumps. Any diesel designed for aircraft will be designed to run on jet fuel. Doesn't make any sense to do it any other way. George Patterson I childproofed my house, but they *still* get in. |
"G.R. Patterson III" wrote Any diesel designed for aircraft will be designed to run on jet fuel. Doesn't make any sense to do it any other way. George Patterson Right. I was commenting on the fact that not all diesels will run on jet fuel, not airplane diesels. Did I mis-read? Won't be the last time. -- Jim in NC --- Outgoing mail is certified Virus Free. Checked by AVG anti-virus system (http://www.grisoft.com). Version: 6.0.688 / Virus Database: 449 - Release Date: 5/18/2004 |
"Robert M. Gary" wrote in message om... "Mike Rapoport" wrote in message link.net... Diesels are more promising. And can run on the same gas. And there's other sources for diesel...and maybe you can smoke it, too. http://www.artistictreasure.com/learnmorecleanair.html |
On Tue, 25 May 2004, Tom Sixkiller wrote:
"Robert M. Gary" wrote in message om... "Mike Rapoport" wrote in message link.net... Diesels are more promising. And can run on the same gas. And there's other sources for diesel...and maybe you can smoke it, too. http://www.artistictreasure.com/learnmorecleanair.html Smoke my fuel! grin Actually, industrial hemp - the stuff they make/will make biodiesel, t-shirts, etc out of - has practically NO THC content. THC is the stuff in pot that actually makes you high. Industrial hemp is THC-free to the point where you'd have to smoke pounds and pounds of the stuff to get enough THC into your blood - and the smoke would kill you dead first! Brian. |
| Thread Tools | |
| Display Modes | |
| Small Aircraft Transportation System (SATS) first practical trial | Larry Dighera | Piloting | 0 | November 27th 03 04:11 PM |
| Order your FREE Small Blue Planet Toys Christmas Catalog before Oct 20th! | Small Blue Planet Toys | Aviation Marketplace | 0 | October 15th 03 06:26 PM |
| Air Force announces winner in Small Diameter Bomb competition | Otis Willie | Military Aviation | 0 | August 30th 03 04:06 AM |
| Small Blue Planet Toys goes Postal !! Economy Shipping Options now availalble | Small Blue Planet Toys | Aviation Marketplace | 0 | July 11th 03 05:00 PM |
| HUGE Summer SALE + Free Shipping @ Small Blue Planet Toys | Small Blue Planet Toys | Aviation Marketplace | 0 | July 9th 03 12:53 AM |
