Mike Rhodes wrote: As for Lycoming recommending against LOP, there was an article in Flying magazine (p. 74-75, 7/02, inset article, J.Mac) , where there was some sort of lead crystalline deposit (lead oxybromide) forming in _turbo_ engines only in LOP operations. I've snipped the rest since it is full of old wives tales. The theory of lead oxybromide came from a poorly investigated accident in Austrailia. John Deakin analyzes the accident, and Flying's coverage of it. Accident: http://www.avweb.com/news/columns/182152-1.html Flying's coverage: http://www.avweb.com/news/columns/182153-1.html Deakin also covers LOP in alot of his articles, specifically the ones titled 'Where should I run my engine?' He goes into the science of how an engine actually works, and examines how the 'your engine will burn up if you do that' OWTs relate to reality. All of Deakin's articles: http://www.avweb.com/news/columns/182146-1.html John -- John Clear - http://www.panix.com/~jac |
"John Clear" wrote in message
... I've snipped the rest since it is full of old wives tales. The theory of lead oxybromide came from a poorly investigated accident in Austrailia. John Deakin analyzes the accident, and Flying's coverage of it. Accident: http://www.avweb.com/news/columns/182152-1.html Flying's coverage: http://www.avweb.com/news/columns/182153-1.html You missed the best bit, where the coroner slates the ATSB investigation. :-) http://www.airsafety.com.au/whyalla/default.htm has the chronology. Julian Scarfe |
Mike Rhodes wrote: Deakin also covers LOP in alot of his articles, specifically the ones titled 'Where should I run my engine?' He goes into the science of how an engine actually works, and examines how the 'your engine will burn up if you do that' OWTs relate to reality. All of Deakin's articles: http://www.avweb.com/news/columns/182146-1.html So I can ignore all the hysterics and lean to roughness, then enrichen it to smoothness. And we all should do so in any piston engine, as long as the power is markedly below 75%. Without an engine analyzer, you have know way of knowing how bad the fuel/air mixture is in each cylinder. Running at the standard 50F rich of peak EGT puts you right in the 'Red Zone'. Running 100-150F ROP is a better place to run the engine if you can't run LOP smoothly. Most non-fuel injected engines have such large differences in fuel/air mixture between cylinders that they can't be run LOP smoothly. At lower power settings, it doesn't matter much where you run your engine since lower power means lower heat and pressure. Deakin does a much better job of explaining all this. John -- John Clear - http://www.panix.com/~jac |
"John Clear" wrote in message ... In article , Mike Rhodes wrote: Deakin also covers LOP in alot of his articles, specifically the ones titled 'Where should I run my engine?' He goes into the science of how an engine actually works, and examines how the 'your engine will burn up if you do that' OWTs relate to reality. All of Deakin's articles: http://www.avweb.com/news/columns/182146-1.html So I can ignore all the hysterics and lean to roughness, then enrichen it to smoothness. And we all should do so in any piston engine, as long as the power is markedly below 75%. Without an engine analyzer, you have know way of knowing how bad the fuel/air mixture is in each cylinder. Running at the standard 50F rich of peak EGT puts you right in the 'Red Zone'. Running 100-150F ROP is a better place to run the engine if you can't run LOP smoothly. Most non-fuel injected engines have such large differences in fuel/air mixture between cylinders that they can't be run LOP smoothly. At lower power settings, it doesn't matter much where you run your engine since lower power means lower heat and pressure. Deakin does a much better job of explaining all this. Save your breath. Numerous people have pointed out the articles. Evidently Rhodes is unwilling to read them or cannot comprehend them. |
On Wed, 30 Jun 2004 13:16:14 -0500, Mike Rhodes
wrote: So I can ignore all the hysterics and lean to roughness, then enrichen it to smoothness. And we all should do so in any piston engine, as long as the power is markedly below 75%. Mike What Deakin suggests is that you get yourself a multi cylinder EGT guage that can tell you what the temperatures are for the EGT and CHT for ALL the cylinders. Without that instrument and even with a single point EGT guage, you have no idea where the CHT's are when you lean by that method. He frequently characterized the typical Lycoming/Continental engine as a group of cylinders flying along loosely in formation because the temperature readings from one cylinder to the other can vary so much you'd think they were from some other engine. Maybe you've leaned to a safe settng but maybe not. Deakin advocates knowing for sure. Seems like good, albeit expensive advice. Corky Scott |
"Mike Rhodes" wrote in message ... On 29 Jun 2004 22:13:49 -0700, (John Clear) wrote: In article , Mike Rhodes wrote: As for Lycoming recommending against LOP, there was an article in Flying magazine (p. 74-75, 7/02, inset article, J.Mac) , where there was some sort of lead crystalline deposit (lead oxybromide) forming in _turbo_ engines only in LOP operations. I've snipped the rest since it is full of old wives tales. The theory of lead oxybromide came from a poorly investigated accident in Austrailia. John Deakin analyzes the accident, and Flying's coverage of it. Accident: http://www.avweb.com/news/columns/182152-1.html Flying's coverage: http://www.avweb.com/news/columns/182153-1.html Deakin also covers LOP in alot of his articles, specifically the ones titled 'Where should I run my engine?' He goes into the science of how an engine actually works, and examines how the 'your engine will burn up if you do that' OWTs relate to reality. All of Deakin's articles: http://www.avweb.com/news/columns/182146-1.html John So I can ignore all the hysterics and lean to roughness, then enrichen it to smoothness. And we all should do so in any piston engine, as long as the power is markedly below 75%. No...you can read the articles and try to LEARN something instead of shooting your mouth off with your foot still in it. |
On Thu, 1 Jul 2004 10:45:43 -0700, "Tom Sixkiller"
wrote: "Mike Rhodes" wrote in message .. . All of Deakin's articles: http://www.avweb.com/news/columns/182146-1.html John So I can ignore all the hysterics and lean to roughness, then enrichen it to smoothness. And we all should do so in any piston engine, as long as the power is markedly below 75%. No...you can read the articles and try to LEARN something instead of shooting your mouth off with your foot still in it. I glanced at one page of Deakin and thought the writing entertaining, & therefore also distracting. That was not intended as a critique of his understanding, though there appears to be a bit of desparation in that regard. Deakin's kind of wordy, especially if its expected to be used as reference material -- like from this news group. I think it unusual to be dissed for not reading something, and I got that feeling even before the above. So I chose not to pour over the material, which is not written as if it were intended to be used for reference. If you have a specific page I'd be glad to check it out; but not all of his articles. If I like that then I may read more, but on my time. Otherwise, quoting the header post by Mr. Scott, (and this is general info as I know/knew it)... Remember, when you are cruising at 60% power, you cannot hurt the engine no matter where you set the mixture control. You can't burn valves or cook the cylinderheads or cause detonation, it just isn't producing enough power to do that. Therefore I think I can assume (for I always have), that no 'red zone' actually exists in cruise throttle, as was mentioned someplace else in the thread. My 2nd reply, which is stated on top of this post (leaning to roughness), is therefore allowed, and without qualification, by the 'can't hurt engine at 60%'. The words "best economy" are in the title of this thread. Mr. Scott's polite reply (thank-you) to my lean-to-roughness said I "may have leaned to a safe setting, maybe not." But this is in conflict with his own statement above, for which he then gave no explanation, except to suggest the engine analyzer. But if the engine is below 75% power then what difference does it make what mixture is in any particular cylinder? If I need economy I go to roughness. If I need speed then I enrichen it to gain power. And I would expect more wear-and-tear at the higher power of richer mixture settings -- _IF_ I get higher power at richer mixture and don't begin to waste fuel. I can monitor my airspeed to see where an another optimum mixture setting exists. (Apologies for putting all my replies into this post, for my first, semi-uneducated post. It was an honest question on my part.) --Mike |
things to tend to) invites catastrophic trouble in any engine. And for the pilot to get in that habit in normally-aspirated engines can, after the pilot upgrades, apparently inflict harm on turbo engines. snip I've never bought the argument of "don't get in the habit of this, because if you move to X type of different aircraft, it's bad". Operating one engine sub-optimally because it's not done in another type seems a bit silly to me - surely pilots should fly each different type appropriately, instead of by habit? If someone tells me "don't operate your C140/Auster/Champ [...] like this because if you move to a turbo Bonanza, doing that will be harmful", I tend to ignore them and continue to operate each aircraft appropriately. -- Dylan Smith, Castletown, Isle of Man Flying: http://www.dylansmith.net Frontier Elite Universe: http://www.alioth.net "Maintain thine airspeed, lest the ground come up and smite thee" |
Mike,
there was an article in Flying magazine (p. 74-75, 7/02, inset article, J.Mac) , where there was some sort of lead crystalline deposit (lead oxybromide) forming in _turbo_ engines only in LOP operations. Complete, total poppycock, as many sources available on the web show. Running lean, by a moment of carelessness (pilots have lots of things to tend to) invites catastrophic trouble in any engine. Yes? Says who? -- Thomas Borchert (EDDH) |
| Thread Tools | |
| Display Modes | |
| What's Wrong with Economics and how can it be Fixed | What's Wrong with Economics and how can it be Fixe | Naval Aviation | 5 | August 21st 04 01:50 AM |
| What's Wrong with Economics and how can it be Fixed | What's Wrong with Economics and how can it be Fixe | Military Aviation | 3 | August 21st 04 01:40 AM |
| Power settings for 182RG | Andrew Gideon | Piloting | 19 | March 3rd 04 08:41 PM |
| Cessna 404 Cruise settings | Katia | General Aviation | 0 | December 19th 03 06:04 PM |
| Small Blue Planet Toys goes Postal !! Economy Shipping Options now availalble | Small Blue Planet Toys | Aviation Marketplace | 0 | July 11th 03 05:00 PM |
