Don't worry about it, just go. The valleys are big and wide. Fly early or
fly late but avoid the middle of the day. "NW_PILOT" wrote in message ... Hello, everyone I am wanting to take a flight from "COE" Coeur D'Alene, ID to "GTF" Great Falls, MT I was wanting to do this in my Cessna 150 Any advice or helpful hints from some one thats done the trip over the Rockies in a 150 I know I will have to be at really high altitudes just wondering on how well the 150 will perform. |
"NW_PILOT" wrote in message ... Hello, everyone I am wanting to take a flight from "COE" Coeur D'Alene, ID to "GTF" Great Falls, MT I was wanting to do this in my Cessna 150 Any advice or helpful hints from some one thats done the trip over the Rockies in a 150 I know I will have to be at really high altitudes just wondering on how well the 150 will perform. I believe your C150 is only marginal for that part of the world. You can certainly do it, but be sure to take precautions about wind, to NOT be at max gross weight, to circle for altitude BEFORE coming to a high ridge, and to lean/enrichen properly on climbs/descents. Good luck. |
"John T Lowry" wrote in message .net...
"NW_PILOT" wrote in message ... Hello, everyone I am wanting to take a flight from "COE" Coeur D'Alene, ID to "GTF" Great Falls, MT I was wanting to do this in my Cessna 150 Any advice or helpful hints from some one thats done the trip over the Rockies in a 150 I know I will have to be at really high altitudes just wondering on how well the 150 will perform. I believe your C150 is only marginal for that part of the world. You can certainly do it, but be sure to take precautions about wind, to NOT be at max gross weight, to circle for altitude BEFORE coming to a high ridge, and to lean/enrichen properly on climbs/descents. Good luck. All the comments are very good advice. I fly into and out of the "Hole" every day and early morning is the best time to fly for sure. It takes 11,000 msl just to leave the Jackson area altho in N801BH with that oversized V-8 Ford it is not a problem. Mountian flying is a beautiful way to see the scenery and the one comment about winds aloft is the most pertinant. Now, if you observe lenticular clouds then tie that sucker down, get an adult beverage, and plan for another day to fly. Ben Haas N801BH Jackson Hole WY |
Learn how to quickly get best power during the takeoff roll, using
your mixture control for any higher altitude takeoffs. Expect the engine smoothness range to get narrower in response to mixture adjustments at very high altitudes. Do not run full rich on the ground, or even on takeoff. Some use a full power runup to adjust for max RPM before starting the roll but I always hesitated to do that to an engine just before takeoff. Is this your personal airplane? You want to know its flight and engine operating characteristics pretty well to minimize the pucker factor. Having an EGT gage really helps. I think it should be mandatory on any carburated engine but that is just the engineer in me showing I guess.... I flew a 125 HP Tripacer with two of us in it thru that region amost 35 years ago. No problem Now we go in comparative regal splendor in a 150 HP 172M! |
om... Learn how to quickly get best power during the takeoff roll, using your mixture control for any higher altitude takeoffs[...] Some use a full power runup to adjust for max RPM before starting the roll but I always hesitated to do that to an engine just before takeoff. There's a good reason for doing it BEFORE starting your takeoff roll, and frankly, adding "fiddling with the mixture" to the things a pilot has to deal with DURING the takeoff roll seems unwise to me. Never mind the fact that once the airplane is moving, you will have a much harder time identifying the point at which the engine is developing maximum power, since RPM will be increasing as the airplane accelerates. I have no idea why you'd hesitate to do something proven to be safe, and which is much less hazardous than your personal procedure, but I hope that no one else applies your advice to their flights. [...] Having an EGT gage really helps. I think it should be mandatory on any carburated engine but that is just the engineer in me showing I guess.... The EGT gauge is not necessary, nor useful, for the purpose of obtaining maximum power for takeoff. Your RPM gauge will give you a 100% reliable indication of maximum power, since maximum power will result in maximum RPM every time. Using the EGT gauge adds an additional layer of indirection, and you may or may not wind up with the actual maximum power mixture setting using it. Pete |
To each his own I guess.
I have gotten used to glancing at the EGT on my takeoff rolls just to make sure things are feeding fuel and air, and also running right. I look for something about 50 to 100 deg F on the rich side of peak. EGT also tells me if I have loaded up the things with carb ice while waiting for takeoff. It is the only cross-check that I have to figure out if the air/fuel metering system is behaving right, and that the engine is properly extracting energy from the combustion process. Personally I feel that any new engine installation (such as in a homebuilt) should have at least a temporary EGT until the idiosyncracies (sp?) of the air intake system are proven out. I've seen/heard of several aircraft that have been excessively lean (especially in the winter) or rich to the point of stumbling when carb heat is added. The technique of getting a badly iced engine back requires aggressive leaning, but I don't see that taught anywhere. How do you lean a constant speed prop aircraft without EGT? I agree that leaning a fixed pitch prop on the run without an EGT is not good practice unless you know the engine. Maybe I am more into this because I am using autofuel. |
Around here (Western Canada) most of the neophytes who get into
trouble in the mountains crash because of weather considerations or by entering an upsloping valley that the airplane can't outclimb and the pilot waits too long before turning around. Mountain weather is treacherous and can change very rapidly. Pay attention to the weather briefers. Mountain clouds usually have rocks in them. Mountain valleys can be confusing, especially if there's no highway to follow, and it's easy to turn into a wrong canyon and get lost real quick. The route should be marked on the map, with compass headings penciled in on each leg. For anemic airplanes like the 150, wind direction over the hills can make the difference between climbing and sinking, as can lift or sink generated by solar heating or shade on the slopes. Dan |
In article , NW_PILOT wrote:
Hello, everyone I am wanting to take a flight from "COE" Coeur D'Alene, ID to "GTF" Great Falls, MT I was wanting to do this in my Cessna 150 Any advice or helpful hints from some one thats done the trip over the Rockies in a 150 I know I will have to be at really high altitudes just wondering on how well the 150 will perform. Some good advice on this thread already. By coincidence, you posted this the day I was making a similar trip in the opposite direction in an Arrow. On Thursday, we overflew Billings, MT and overnighted in Bozeman. Next day (Friday), our first leg was BZN to COE (destination was Seattle, which we made on the second leg). We did it at 8500', well above the valley floor. Flew along the I-90, you can't miss it. Occasionally cut corners since we were high enough. Don't have performance charts handy, but I'm sure you can get up to 8.5 in a 150. Remember your D.A., the airplane may think it's at 9000 or 10,000. Climb rate may not be the best. It's better to climb while circling (or shuttling back and forth) than to try to outclimb rising terrain. Once you get to that altitude, as Sydney points out, you're not really flying in the mountains, you're flying over the mountains. Best to do it in good VFR conditions. Weather can be iffy. Do the trip. The scenery is awesome. Morris |
| Thread Tools | |
| Display Modes | |
| 4800nm trip complete! | SeeAndAvoid | Piloting | 2 | June 19th 04 06:58 PM |
| Coast to coast trip finished :-) | Filip Zawadiak | Piloting | 6 | May 5th 04 09:45 PM |
| Planning a trip | S Green | Piloting | 30 | January 14th 04 01:17 AM |
| Crossing the Rockies in a 172 | Peter von Tresckow | Piloting | 14 | December 20th 03 06:27 AM |
| First long-distance trip | Marc | Piloting | 2 | December 16th 03 05:03 AM |
