How do I generate smoke "sky writing" from a SEL airplane and is it legal?
Cliff |
You would be amazed at the sheer lack of information available on this
topic, Cliff. :-] As far as I know, there are no regulations against skywriting (I checked the FAR/SFAR with no mention of the subject), obviously following the guidelines about safe operation distances from populated areas. Here in South Bend, Indiana, we have a cat locally who owns a 300 with a smoke device. I've never seen any skywriting done with it, however, but I don't think it has anything to do with rules against it. Also, it seems important to note that skywriting seems to be a "dying" art. You just don't see much of it at all these days. I'm really hoping by bumping this thread a bit someone with a little bit more knowledge on the matter will speak up for you. -- Robert M. Miller ) -- wrote in message ... How do I generate smoke "sky writing" from a SEL airplane and is it legal? Cliff |
In article d_0Jc.85385$Oq2.63545@attbi_s52,
"Robert M. Miller" wrote: Also, it seems important to note that skywriting seems to be a "dying" art. Most likely due to its high visibility to those who would question it. One group would protest it as destroying the sky's natural beauty, and another grouyp would say your company needs to pay for an environmental impact study to acertain the effects of the burned oil on the ozone layer, fowl life, etc. Oh, and another who would protest the noise factor since you would have to remain over a small area for a time. And one more, who upon seeing you, would think you were a terrorist and the smoke was some kind of nerve gas. Edward |
"Robert M. Miller" wrote: Also, it seems important to note that skywriting seems to be a "dying" art. check this page: http://www.sky-writing.com/ |
"Edward Todd" wrote in message
... In article d_0Jc.85385$Oq2.63545@attbi_s52, "Robert M. Miller" wrote: Also, it seems important to note that skywriting seems to be a "dying" art. Most likely due to its high visibility to those who would question it. And make sure your spelling is good. Everybody can see your mstaikes... ;-) |
It's actually quite amusing when you see a spelling error. As to the equipment, there are several smoke systems avialable...you can check out Aircraft Spruce and Specialty (http://www.aircraft-spruce.com/) for starters. It generally runs off of a lightweight oil that is injected into your exhaust. As for any other requirement, you will probably need a 337 for the airplane once the system is installed. Once that is done, just click it on and let it billow away. -John *You are nothing until you have flown a Douglas, Lockheed, Grumman or North American* |
you may want to look in to aerobatic aircraft supply I think most aerobatic
aircraft trail some sort of smoke for judges to see. wrote in message ... How do I generate smoke "sky writing" from a SEL airplane and is it legal? Cliff |
In competitions aerobatic planes do not use smoke- it is generally used for
airshows only. Even though I don't do airshows, I have it installed on my Extra. Another handy use is to help other pilots find you in the pattern. It obviously makes the plane much more visible and easy to find. A smoke system includes a tank, pump, and orifice in the exhaust manifold. This system allows the smoke oil to get vaporized. Smoke oil is generally low viscosity, and makes a slimy mess on the belly of the plane as well as the hangar floor. It is also expensive, and puts out around a gallon a minute in my plane. The EAA magazine will list several smoke systems for aerobatic aircraft, while the oil itself can be purchased from a local oil distributor. |
"Viperdoc" wrote in message
A smoke system includes a tank, pump, and orifice in the exhaust manifold. This system allows the smoke oil to get vaporized. So is the oil is injected directly into the manifold through this orifice or is there some more complicated, separate mechanism for heating up the oil? -- Jim Fisher |
is there some more complicated, separate mechanism for heating up the oil? It is injected directly. You have to experiemnt a bit to find the sweet spot....not too hot and not too cold.... where the oil will completely vaporize and not burn. Plus the right size orifice is needed and this varies with each airplane installation. VL (Mopar electric fuel pumps were great smoke oil pumps......cheap and usually reliable) |
Murray Smith (Pro Pilot)-Squeezing Together a Love of Writing and Aviation | Mergatroide | Aviation Marketplace | 0 | January 18th 05 07:09 AM |
Murray Smith (Pro Pilot)-Squeezing Together a Love of Writing and Aviation | Mergatroide | Owning | 0 | January 18th 05 07:09 AM |
Funny story about naval | [email protected] | Naval Aviation | 0 | December 20th 04 03:37 AM |
Kerry, in 1971, Admitted Writing Combat Reports | Fred the Red Shirt | Military Aviation | 0 | September 1st 04 08:57 PM |
Flight planning spreadsheet | Roger Long | Piloting | 22 | August 11th 03 03:03 AM |
