On Mon, 19 Jul 2004 18:50:06 -0700, "BTIZ"
wrote: yes... actually that resurfacing would have been about that time.. I left ASH in 1982 and the new tower was not open then.. I was at NEAI/DWC from 1974-1977, earned my Private ASEL through NEAI in 1974 Well we overlapped a bit. I moved to the area in 1976 and left in 2000. We still go back to visit from time to time, though. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
![]() Dave Russell wrote: 2. We all know about the minimum fuel requirement for take-off. If one were to land with less fuel in the tanks than the required reserve (and without a good reason for using part of the reserve), can the FAA violate you for negligence? The regulations require that you have sufficient fuel on takeoff. They do not require that you have the required reserve when you land. If checked, you might be required to demonstrate how you calculated the reserve. You might be violated if they think you did not do a good job of that. I've never heard of such a case in non-commercial flights, but it's certainly possible. George Patterson In Idaho, tossing a rattlesnake into a crowded room is felony assault. In Tennessee, it's evangelism. |
Hi George,
2. We all know about the minimum fuel requirement for take-off. If one were to land with less fuel in the tanks than the required reserve (and without a good reason for using part of the reserve), can the FAA violate you for negligence? The regulations require that you have sufficient fuel on takeoff. They do not require that you have the required reserve when you land. If checked, you might be required to demonstrate how you calculated the reserve. You might be violated if they think you did not do a good job of that. I've never heard of such a case in non-commercial flights, but it's certainly possible. To my knowledge, airliner pilots quite regularly file flight plans to closer airports than their real destinations in order to be allowed to take of with less fuel than what would be required including reserve for the full distance. At some point during the flight, they re-file a new flight plan the the real destination, by which time the remaining fuel is sufficient for the rest of the flight including required reserve. consequently, they land with less fuel than what would have been required reserve for the whole distance. Can anyone confirm this practice? regards, Friedrich -- for personal email please remove "entfernen" from my adress |
"Friedrich Ostertag" wrote
To my knowledge, airliner pilots quite regularly file flight plans to closer airports than their real destinations in order to be allowed to take of with less fuel than what would be required including reserve for the full distance. At some point during the flight, they re-file a new flight plan the the real destination, by which time the remaining fuel is sufficient for the rest of the flight including required reserve. consequently, they land with less fuel than what would have been required reserve for the whole distance. Can anyone confirm this practice? This was common practice when I flew for PanAm. The procedure was acceptable because of the 10% fuel factor for international flights. The procedure was called "redispatch". The procedure was not applicable to domestic flights because of the fixed 45 minute reserve fuel requirement. International flights require 30 minutes of fuel plus fuel for 10% of the total flight time, which for a 10 hour flight would amount to one and one-half hours of reserve fuel while a domestic flight arriving at the same time at the same airport would only require 45 minutes of reserve fuel. It was a paper-work and communications drill which required the co-operation of the dispatcher with an updated flight release and weather. However, the flight plan with ATC was filed to the "real" destination, they never knew that you might have to land short if the destination wx or enroute fuel burn didn't work-out as desired. Bob Moore ATP B-707 B-727 PanAm (retired) |
Dave... How's it going???
"Dave Russell" wrote in message m... A friend of mine is curious: 1. If a runway is closed by NOTAM at a non-towered airport, does that mean that the adjacent *taxiway* can't be used to legally take-off and land? (I know the insurance company would have an opinion about this, also, but let's ignore that aspect for the moment.) I routinely take off and land the L3 on the grass next to the runway... Airport manager hasn't yelled at me... Nothing in my insurance says I can't... 2. We all know about the minimum fuel requirement for take-off. If one were to land with less fuel in the tanks than the required reserve (and without a good reason for using part of the reserve), can the FAA violate you for negligence? Rule is have to have required reserves on takeoff... John Price CFII/AGI/IGI http://home.att.net/~jm.price |
FAA won't fine erratic drunk pilot - Philadelphia | Jeff | Piloting | 0 | April 1st 04 01:14 AM |
Fine example of Tarver Engineering release for service | running with scissors | Military Aviation | 79 | March 3rd 04 01:48 PM |
Fine example of Tarver Engineering release for service | running with scissors | Military Aviation | 7 | February 28th 04 05:07 PM |
Piper Cub: "A Reflection in Time"... fine art print | highdesertexplorer | Aviation Marketplace | 0 | January 13th 04 03:47 AM |
FS: Aviation History Books | Neil Cournoyer | Military Aviation | 0 | August 26th 03 08:32 PM |
