In article , Michael wrote:
The reality is that we have a dumb way of dealing with fuel. We use the clock. It's dumb because it assumes we know the fuel burn and that nothing is leaking. Too many assumptions, too easy to go wrong. What we need are accurate fuel gauges that are cheap enough to make retrofits sensible. As long as they have to be FAA certified, that won't happen. Fuel gauges in many planes *are* good enough, though. There are some that are terrible (I've never flown a C172 with a fuel gauge that was in any way useful), but many are fine. The trouble is (especially with old planes) you have to fly them a few times and check the fuel gauges to get any idea of whether they are any good. My old C140 had mechanical fuel gauges. They were very accurate. Other planes I've found good fuel gauges in - Grumman Tigers/Cheetas, the old 1960 C182 we had in the flying club, Beechcraft (both the Bonanza and Musketeer I've got to fly had fuel gauges that were worth something). The fuel gauge in the Auster I tow gliders with is very good. It's a cork with a little stick indicator on which protrudes out of the top of the fuel tank! I don't just use time, I also monitor the fuel gauges. A good job too - when I was new to our club's old C182, I *thought* it was full of fuel (visual inspection showed less than an inch between the liquid and the filler, which was full for my plane). Since it only had 55 gallon tanks, it's not hard for a cross country to be the full IFR range. My usual practise is to time AND check the gauges. If the fuel gauges show less fuel than I think I should have, it's a cause for concern. On this particular flight, I noted that at the point I should have had half a tank, I had 2/3rds of a tank indicated on the fuel gauge. Either the gauges were wrong, or I didn't have as much fuel as I should. I elected to land at the next airfield to check it out. Good job too - I had about 45 minutes less fuel than I thought I really had when I left. If I had pressed onto my desired destination just using my stopwatch as a fuel gauge, I would have arrived with about 10 minutes of fuel remaining. Diversions, holding, go arounds etc. could have easily eaten that in its entirety. Of course, before takeoff, the gauges were on the 'F' marking, but I discovered after topping off the tanks at my diversion field that 'F' isn't really quite full - it's full when the gauge points well past full (like many car fuel gauges). That last inch was in fact about 10 gallons! -- Dylan Smith, Castletown, Isle of Man Flying: http://www.dylansmith.net Frontier Elite Universe: http://www.alioth.net "Maintain thine airspeed, lest the ground come up and smite thee" |
Dylan Smith wrote in message ...
snip My usual practise is to time AND check the gauges. If the fuel gauges show less fuel than I think I should have, it's a cause for concern. snip I use a triple redundant method. I use time to measure fuel burnt and burn from 1 tank at a time, but I also cross check the gauges. If a gauge reads substantially less than it should at any point, that calls for a landing to verify it manually. As a backup to all this, I burn 1 tank for an hour, switch and burn the other tank until it's nearly dry. If my calculations are correct, the second tank should be empty right on schedule. If I have a leak or increased fuel burn for any reason, the second tank will run out early and I still have plenty of fuel in tank #1 to find an airport, land and check it out. John Galban=====N4BQ (PA28-180) |
"Malcolm Teas" wrote in message
om... Hm. An FAA certified fuel gauge has to be right on two conditions: full and empty. No assurances of correctness anywhere else. Illegal cell phones, and now this old wives tale? It's retread week! |
"Peter Duniho" wrote in message ...
"Malcolm Teas" wrote in message om... Hm. An FAA certified fuel gauge has to be right on two conditions: full and empty. No assurances of correctness anywhere else. Illegal cell phones, and now this old wives tale? It's retread week! I dunno about that. I'm repeating what I learned from an instructor of mine who's also an A&P. At your kind suggestion above ![]() to track it down on the FAA website. TSO-C55 is titled "FUEL AND OIL QUANTITY INSTRUMENTS (RECIPROCATING ENGINE AIRCRAFT)", so that looked good. But it just refers me to SAE Aeronautical Standard AS-405B, "Fuel and Oil Quantity Instruments," dated July 15, 1958 for the details. It refers to older standards as well. Aeronautical standards are downloadable for $59 each from the SAE site www.sae.org. AS-405B was updated in July 2001 to AS-405C and now handles both float-type and capacitive instruments. (Capacative instruments were also covered in an earlier standard from 1989.) Also there's TSO-C47 from 1997 that covers "PRESSURE INSTRUMENTS - FUEL, OIL, AND HYDRAULIC". Unfortunately it also deadends into a SAE document. There's nothing in either TSO that answers this question. I'd expect that at least some of the difference of opinion we're finding are from older vs newer standards. Like we say in the computer biz, the nice thing about standards is that there's so many of them to choose from. Anyone got a extra $59 or so and want to resolve this? I'm curious, but not $59 curious. In any case, regardless of the standard, we all know about planes with fuel gauges that are at best a hint to your fuel condition. Seems best to track time as well as gauges like someone suggested. -Malcolm Teas |
om... Hm. An FAA certified fuel gauge has to be right on two conditions: full and empty. No assurances of correctness anywhere else. Illegal cell phones, and now this old wives tale? It's retread week! I dunno about that. I'm repeating what I learned from an instructor of mine who's also an A&P. Certification rules require at least two things of fuel gauges: that they read "empty" when there is 0 usable fuel left (as opposed to dry tanks), and that they indicate the quantity of fuel in the tank. People commonly misinterpret the "0 usable fuel" clause to mean that's all a fuel gauge is required to do, but it's simply not true. I can't speak to the certification rules prior to the current Part 23, but I would be very surprised if they also only required an indication of empty or not. After all, that could satisfied with a simple on/off light, and I've never heard of an airplane so-equipped. See FAR 23.1337 for more details. Pete |
Malcolm Teas wrote:
] Hm. An FAA certified fuel gauge has to be right on two conditions: full and empty, Actually, an FAA certified fuel guage doesn't have any accuracy requirements at all. The only thing that the regs say is that the empty mark is supposed to correspond to no usuable fuel (rather than bone dry). My "certified" gauge doesn't even read "full". The guage (it has a disclaimer on it) gives "no indication above 36 gallons". (39.5 usable). |
![]() Malcolm Teas wrote: Hm. An FAA certified fuel gauge has to be right on two conditions: full and empty. No assurances of correctness anywhere else. Not true. It has to display the quantity of fuel in each tank. If it's off by very much, it is not doing that. George Patterson If a man gets into a fight 3,000 miles away from home, he *had* to have been looking for it. |
There can be plenty of reasons for this besides pilot error. A while
back one of my fuel drains developed a slow leak, and there are probably a dozen other possibilities. |
Experienced avionics tech needed | Skypilot | General Aviation | 0 | January 5th 05 06:07 AM |
Dr.Curtiss runs out of his medicine | Toly | Piloting | 11 | August 24th 04 09:41 PM |
Wanted: Experienced CFIIs to Teach 10-day IFR Rating Courses near Pittsburgh | Richard Kaplan | Instrument Flight Rules | 2 | October 1st 03 01:50 AM |
Ever experienced panic in flight? | PWK | Home Built | 0 | August 27th 03 06:16 PM |
FORMATIONS, BOMB RUNS AND RADIUS OF ACTION | ArtKramr | Military Aviation | 0 | August 10th 03 02:22 AM |
