Backup AI (using solid state gyro) for portable
Old November 23rd 04, 05:33 PM
Andrew Gideon
Default Backup AI (using solid state gyro) for portable
Can anyone provide a pointer to some hardware/software usable on a portable
computer (Microsoft's CE, or perhaps even XP on a small system) that
provides a backup AI solution using "solid state gyros" (accelerometers?
altitude heading reference system?). I'm looking for something that I can
run on a system also running Airgator's NavAir product.
Bluetooth-speaking would be especially interesting.
Thanks...
Andrew
Old November 23rd 04, 06:19 PM
john smith
There is already a product available, but I do not recall the name.
The "box" sits on the floor under seat (or where ever available) and
feeds a display.
Thanks...
Andrew
Old November 23rd 04, 07:32 PM
Andrew Gideon
feeds a display.
I know that there's something available. I've played with the add-on to The
Cheetah product (Echo Flight?), and I know ControlVision has one. But
those are integrated (more or less {8^) solutions. I'm trying to learn
more about ControlVision's (AnywhereAI), but I'm wondering what else is out
there.
BTW, does anyone happen to know if Cheetah is WxWorx yet?
- Andrew
Old January 27th 05, 09:41 AM
Control Vision leads the pack by far.
Old November 24th 04, 04:43 AM
BTIZ
A friend has a Ring Laser Gyro installed in his glider.. provides Attitude
data to a PDA display. I think it was built by Garmin.. I'll check on it.
BT
"Andrew Gideon" wrote in message
online.com...
portable
Thanks...
Andrew
Old November 24th 04, 06:45 AM
jc
Windows ?????????????? for an AI or any critical application
Russian roulette would be much cheaper
regards
jc
LEGAL - I don't believe what I wrote and neither should you. Sobriety and/or
sanity of the author is not guaranteed
EMAIL - and are not valid email
addresses. news2x at perentie is valid for a while.
Old November 24th 04, 10:24 AM
MC
Not necessarilly.
If all you need to do is run a well defined set of
applications, then MS Windows (or *any* windows system
for that matter) is ok.
The problem with all operating-systems is that they
try to cater for a *huge* range of different
applications and users.
Limit the scope on *a* platform and any windows
system will work fine.
Old November 24th 04, 10:38 AM
MC
Your really don't want much ! g
Anyway.., make sure you're siting down and look at ;
http://www.bluemountainavionics.com/
and
http://www.xbow.com/
Actually, I've recently started to make my own pseudo AHI,
(mostly as an microprocessor exercise), but also to provide
a backup to the vacuumn-driven DI and AH.
A couple of dual-axis accelerometers, a GPS feed,
3-axis magnetic sensors, and some maths...
easy! (he says with a big g)
Initially I'll use a laptop and later a PDA.
Old November 24th 04, 05:12 PM
Andrew Gideon
portable computer (Microsoft's CE, or perhaps even XP on a small system)
that provides a backup AI solution using "solid state gyros"
(accelerometers?
can run on a system also running Airgator's NavAir product.
Nope. I'm just that kind of guy.
and
Why do I need to be sitting? But unless I'm missing it, the first is about
full EFIS-type solutions. That's not quite what I'm seeking.
My "baseline" is AnywhereAI. I'm looking for something similar that can
work along with AirGator's NavAir (or something similar).
The xbow site is interesting, and I'm going to spend more time on it to
learn more about this product space, but I don't see anything integrated
into the type of backup AI I'm seeking. Again, though, I could easily be
missing something on the site.
Well, I'm hoping to buy this. As wrote, I know about AnywhereAI and I've
seen an AI on Cheetah. I'm just trying to learn what else is out there.
[But your project does sound like fun. How you manage to get time for that
*and* flying, though...laugh]
- Andrew
Old November 25th 04, 12:18 AM
MC
(accelerometers?
and
They have (or did have at one time), modules to give heading/attitude/etc
to feed into their EFIS panels.
Honeywell also have modules (HMR3200, HMR3300) which give a
magnetic-heading output, but will also provide some attitude/roll information.
You'd have to write an app. to decode and present the data-stream
from the sensor(s) that you have.
AFAIK there doesn't appear to be much standardisation of the
data-streams across manufacturers/sensors,
(although there are NMEA sentences which could be used satisfactorily)
Bush IS Attempting to Steal the Election WalterM140 Military Aviation 6 June 19th 04 01:30 AM
Solid State Gyro PaulH Owning 2 March 31st 04 04:41 PM
FA: 10 Watt - Solid State Digital VHF- Transceiver Unicom OH Aviation Marketplace 0 March 30th 04 03:29 PM
Q for Jim Weir or others: solid state fuel level probes? Charlie England Home Built 11 March 12th 04 01:35 AM
Solid State Backup AI Dan Truesdell Instrument Flight Rules 20 January 15th 04 10:53 PM
