![]() wrote in message oups.com... Rick, I just checked my Cardinal POH and it does state leaving wing flaps retracted. snip Hai Original Cardinals had problems with horizontal tail stall, thus the slot on the LE. I can only imagine landing one iced up... |
Hai,
You've just defined the classic icing problem for general aviation airplanes: the need to come down final fast, with flaps up, toward a runway that isn't terribly long and may be contaminated. (Get the November issue of IFR Magazine for a long discussion on it). On top of things, you need to allow a little altitude over the threshold if there is any snow in the area because the plow driver may have piled snow at the end of the runway (which is not appropriate but sometimes happens). Once you get any ice whatsoever on the airplane you become a test pilot. At some point you will have enough that if you deploy the flaps the tail will stall and the airplane will pitch down radically...as has happened on a number of well-publicized commuter crashes. As a result, you don't know what the wing and tail are doing, so the only safe approach is to fly final fast, flaps up, with power (I owned a 117B Cardinal for a while and would come down final at 90-100 knots, flaps up, if I had ice). You don't know when the wing will stall, either. On the times I had to land the airplane with ice, I set up so that I would be in a position to see whether there is any snow pile at the end of the runway, and then land as near the threshold as conditions permit, flare slightly (at that speed with flaps up the airplane is pitched up anyway, so you don't need to worry about landing on the nosewheel) and put the wheels on the ground. Close the thottle immediately on touchdown and gently start applying the brakes to see what you've got. If the runway is contaminated, it's going to be challenging to keep the airplane straight and get it stopped. In 3,000 feet you should be able to do so unless it's icy. The reality is that you may go off the end of the runway. However, you have just been in a classic emergency: the airplane is iced up and you were at risk of loss of control while in the air at 90-110 knots; the impact from that would probably be fatal. If the choice is a loss of control at 100 knots or sliding off the end of a runway at 20 knots, I'll take the low speed impact every time. That's why we have insurance. With ice, avoid setting up high on final; when you have an emergency try to make everything else as normal as possible, so that you see a sight picture that is consistent with what you are used to. The problems I've seen include pilots who are high on final and don't touch down in the first part of the runway and then try to go around with a load of ice. It doesn't work. Set up for a normal approach, just fast. In fact, practice some no flap landings so it's not a new experience when you have to do it for real. Yes, get the defroster going full blast. You may even want to block off the copilot's defroster to put more on your side of the windshield. Divert all cabin heat to the defroster if you can. In the Cardinal you can also open the little window on your side at approach speed and use it to help you see forward. Yes, the cold air and snow or rain coming in won't be fun, but the idea is to see the runway. All the best, Rick |
AC 23.143-1, which deals with tailplane stalls due to icing, mentions tail
configuration as one of the considerations but does not distinguish between T-tails and conventional tails in its advice to avoid flap extension if icing is suspected. No free pass for T-tails or cruciform tails. Bob Gardner "steve.t" wrote in message oups.com... The tail plane stall that all keep talking about, isn't it caused by icing over a stablizer that is at or just below the plane of the wing? Then when the flaps are deployed, the air is disturbed sufficiently that the tail stalls? Therefore, if flying a T tail (or similar), deployment of flaps should not affect the tail. Is this correct? I'm asking because of flying a Piper wherein the wing is actually below the stabliator. Deployment of 15 degrees of flaps should not sufficiently disturb the airflow to cause the tail plane stall in this case. Is this correct? Later, Steve.T PP ASEL/Instrument ps. I'm almost at that 350hr mark some one else mentioned. T-storms, fog and ice conditions are automatic no-go situations for me. Too much at stake. |
![]() "steve.t" wrote in message oups.com... The tail plane stall that all keep talking about, isn't it caused by icing over a stablizer that is at or just below the plane of the wing? Then when the flaps are deployed, the air is disturbed sufficiently that the tail stalls? Therefore, if flying a T tail (or similar), deployment of flaps should not affect the tail. Is this correct? I'm asking because of flying a Piper wherein the wing is actually below the stabliator. Deployment of 15 degrees of flaps should not sufficiently disturb the airflow to cause the tail plane stall in this case. Is this correct? Later, Steve.T PP ASEL/Instrument ps. I'm almost at that 350hr mark some one else mentioned. T-storms, fog and ice conditions are automatic no-go situations for me. Too much at stake. The tailplane stall, in the iceing case, is caused by leading edge contamination by ice. The scenerio goes something like this: Leading edge ice causes less tail lift (or tail download ) to be available at at particular elevator angle. To maintain trim the pilot flies with an increased elevator angle. When flaps are selected the nose down pitching moment (NOT TRIM CHANGE) is controlled by more elevator deflection. In the iceing case this extra elevator deflection may cause the tailplane alpha to exceed the stalling angle (with ice). Tail download is then much reduced and the aircraft pitches nose down uncontrollably. My experience with tailplane stall in a turboprop twin (during flight test) is that the pitch down is sudden and dramatic - 0g or less, a height loss of 1500 to 2500 ft, and usually overspeed gear and flaps. In this case the elevator hinge moments reduced markedly and full aft stick could be easily applied but with no effect. Recovery was rapid if the airflow re-attached to the tailplane with full aft stick applied ie very easy to overstress the aircraft. Cheers, |
Bob,
Thank you very much for your tailplane stall explanation. We attended a Wing Safety Seminar last November on Winter Operations where it was mentioned but only in term of symptoms and recovery process. I did not realize that there would be more chance of a tailplane stall than wing stall due to heavier ice accumulation. Before landing, I had discussed with my husband, Rick on whether I should have landed with no flaps or with 10 degree flap. Since the standard Cardinal takeoff procedure calls for 10 degree flap, we thought it would provide more lift. We did not think of the possiblity of tailplane stall. Although I had practiced landings with different flap configurations every few months, I generally dislike the noflap approach due to extremely nose high position. I hate not being able to see a darn thing ahead while landing. The practices did come in handy late last fall in our long cross country trip from New York to northern Minnesota. Within an hour of flying, we had complete electrical failuires due to a bad crimp job on one ot the alternator wires. We have owned our plane for about 1 1/2 years and put over 200hrs on it. It was our luck that we landed at Seaman airport and the folks at O&N aviation (the home of the Silver Eagle) were open on Saturday. They found the problem right away and get us going within few hours. The owner did not write up a bill and told us just to give a tip to his mechanics. Fantastic folks!. (Note to Jay: In our short flying career, this was our first 'emergency' situation, the icing incidence was the second. Luckily ;-) , I was the PIC in both cases and Rick mainly offered assistance and did not insist on taking over. Just wonder how you and Mary handle your flying responsibilities?). On an aside note, for our instrument training, I bought at least half a dozen books on the subject. Rick was ahead of me so he had reviewed all of them. His main text book was your book, "The Complete Advanced Pilot". He got 98 on his written and recommend me to start right away with your book using others as supplemental readings. We have also made good use of your "Say Again, Please" book. Thank you so much for imparting your years of aviation skills, experiendce, wisdom and insight to many next generations of pilots. Best regards, Hai Longworth |
![]() " writes: [...] Before landing, I had discussed with my husband, Rick on whether I should have landed with no flaps or with 10 degree flap. [...] I generally dislike the noflap approach due to extremely nose high position. I hate not being able to see a darn thing ahead while landing. [...] Next time this happens, consider not only landing flapless, but touching down at well above normal stall airspeed, basically doing an airliner (or floatplane still-water) style flying-to-the-ground landing. The pitch angle won't be so high, and you won't be at the mercy of the possibly nastier stall characteristics with ice on the wings. You would need a longer runway. - FChE |
Thanks for the kind words, Hai. As is the case with all warnings about ice,
it is not the weight of the ice so much as the distortion of the airfoil due to ice accretion. On final, chances are that the horizontal stab is going to be tilted forward (leading edge down), improving the chances of ice collection on the upper surface. Since the horizontal stab develops a downward force, ice on the upper surface is the equivalent of ice on the bottom of the wing's leading edge. The problem with tailplane icing is twofold: First, you can't see it very well and must assume the 3-to-1 ratio I mentioned before. Second, when the tailplane stalls and the nose pitches down when flaps are extended, there is no time to react. We had a commuter twin dive in from 600 feet over in Eastern Washington a few years ago with no survivors. The problem with icing, period, is that it is not predictable or repeatable. Fly two airplanes through the same cloud at the same speed and the ice forms will be different; fly the same airplane through the same conditions twice and the ice forms will be different. The drawings of clear, mixed, and rime ice in FAA publications don't even come close to reality. Scary stuff, to be avoided at all costs. Here is part of AS 23.143.1: e. Ice Contaminated Tailplane Stall (ICTS). ICTS occurs due to airflow separation on the lower surface of the tailplane that is caused by the angle-of-attack of the horizontal tailplane being increased above the reduced stall angle-of-attack that can result when even small quantities of ice have formed on the tailplane leading edge. The increase in tailplane angle-of-attack can result from airplane configuration (for example, increased flap extension increasing the downwash angle or trim required for the CG position) and/or flight conditions (for example, high approach speed resulting in an increased flap downwash angle and reduced angle-of-attack, gusts, maneuvering or engine power changes). ICTS is characterized by a reduction or loss, sometimes sudden, of pitch control or stability while operating in, or recently departing from, icing conditions. For airplanes with longitudinal control systems that are not powered (reversible control systems), the pressure differential between the upper and lower surfaces of the stalled tailplane may result in a high elevator hinge moment, forcing the elevator trailing edge down. This elevator hinge moment reversal can be of sufficient magnitude to draw the control column forward with a level of force that is beyond the combined efforts of the flightcrew to overcome. On some airplanes, ICTS has been caused by a lateral flow component coming from the vertical stabilizer, as may occur in sideslip conditions or due to a gust with a lateral component. An evaluation should be made to determine if this unsafe flight condition is likely to occur. Susceptible airplanes are those having a near zero or negative stall margin with contamination. Flight test procedures for determining susceptibility to ICTS are included in AC 23.143-1, "Ice Contaminated Tailplane Stall (ICTS)". Bob Gardner wrote in message oups.com... Bob, Thank you very much for your tailplane stall explanation. We attended a Wing Safety Seminar last November on Winter Operations where it was mentioned but only in term of symptoms and recovery process. I did not realize that there would be more chance of a tailplane stall than wing stall due to heavier ice accumulation. Before landing, I had discussed with my husband, Rick on whether I should have landed with no flaps or with 10 degree flap. Since the standard Cardinal takeoff procedure calls for 10 degree flap, we thought it would provide more lift. We did not think of the possiblity of tailplane stall. Although I had practiced landings with different flap configurations every few months, I generally dislike the noflap approach due to extremely nose high position. I hate not being able to see a darn thing ahead while landing. The practices did come in handy late last fall in our long cross country trip from New York to northern Minnesota. Within an hour of flying, we had complete electrical failuires due to a bad crimp job on one ot the alternator wires. We have owned our plane for about 1 1/2 years and put over 200hrs on it. It was our luck that we landed at Seaman airport and the folks at O&N aviation (the home of the Silver Eagle) were open on Saturday. They found the problem right away and get us going within few hours. The owner did not write up a bill and told us just to give a tip to his mechanics. Fantastic folks!. (Note to Jay: In our short flying career, this was our first 'emergency' situation, the icing incidence was the second. Luckily ;-) , I was the PIC in both cases and Rick mainly offered assistance and did not insist on taking over. Just wonder how you and Mary handle your flying responsibilities?). On an aside note, for our instrument training, I bought at least half a dozen books on the subject. Rick was ahead of me so he had reviewed all of them. His main text book was your book, "The Complete Advanced Pilot". He got 98 on his written and recommend me to start right away with your book using others as supplemental readings. We have also made good use of your "Say Again, Please" book. Thank you so much for imparting your years of aviation skills, experiendce, wisdom and insight to many next generations of pilots. Best regards, Hai Longworth |
career, this was our first 'emergency' situation, the icing incidence was the second. Luckily ;-) , I was the PIC in both cases and Rick mainly offered assistance and did not insist on taking over. Just wonder how you and Mary handle your flying responsibilities?). We have discussed this issue at length, and we handle cockpit resource management in the same way you do. Whoever is in the left seat is pilot-in-command, and has absolute authority to make decisions. (This, of course, doesn't stop us from offering advice or making snide remarks about certain landings... :-) The right seater is only allowed to take the controls in the event of an emergency that threatens imminent danger. In Mary's 500 or so hours, I've taken the controls just once from the right seat, and that was when a NORDO Stinson tried to trade paint with us in the pattern. The plane was coming in from behind Mary's left shoulder, in her blind spot, and breaking hard right seemed the wise thing to do. It was sheer luck that I spotted it at all. As the Stinson flew through the spot we had just occupied, moments before, Mary didn't argue! ;-) -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Issues around de-ice on a 182 | Andrew Gideon | Piloting | 87 | September 27th 05 11:46 PM |
Rain and autopilot unstable | W9MV | Owning | 3 | May 18th 04 08:51 PM |
