This new pilot was rather freaked out after losing one of my two radios
on my first 'real' long trip. Making me an even firmer believer in redundancy, it is time to get a handheld backup. I was all set on the Icom A5 Sport (alkaline battery) as this would be used as a backup. Now I see the A6 Sport has arrived. Can anyone familiar with these models recommend if the A6 is worth the extra $40 or so? It's hard for me (an inexperienced handheld user) to spot the differences online. Thanks, |
I'm not familiar with the A5 or A6.. I have an A-22, the NAV function is not
of much use with the rubber ducky antenna on my A-22... I've tried to use it once.. so.. maybe save the $ and not get the Nav model... but.. it would be good to be able to transmit on one when you have to listen to the VOR freq to get FSS.. so maybe the NAV function would be worth it for that reason alone. I do not have the sport model, but an alkaline battery will last longer in storage than the NiMH. But I use my A-22 every weekend and it goes on the charger every Friday night. It is my primary radio while providing glider instruction (training glider not equipped with mounted radio or battery)and monitoring the freq/traffic pattern from airfield ops (out on the airfield).. I do keep a battery backup (alkaline) in the flight bag.. when I needed it, the 10 AA batteries lasted about 5 hours of continuous use. BT "Jonathan Sorger" wrote in message ... This new pilot was rather freaked out after losing one of my two radios on my first 'real' long trip. Making me an even firmer believer in redundancy, it is time to get a handheld backup. I was all set on the Icom A5 Sport (alkaline battery) as this would be used as a backup. Now I see the A6 Sport has arrived. Can anyone familiar with these models recommend if the A6 is worth the extra $40 or so? It's hard for me (an inexperienced handheld user) to spot the differences online. Thanks, |
not of much use with the rubber ducky antenna on my A-22... I've tried to use it once.. so.. maybe save the $ and not get the Nav model... Agreed. I had the A21, with the NAV feature, and it was utterly useless. I now own the A5 (I think? It's the ICOM without the NAV feature) and it's great. Very small (especially by comparison to my old A21, which was twice as big and over twice as heavy), lightweight, rugged, water-resistant, and has great sound. It uses either rechargeable batteries, or a separate alkaline battery pack (which is what I use), or external power. It's a great little unit. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
BTIZ wrote:
I'm not familiar with the A5 or A6.. I have an A-22, the NAV function is not of much use with the rubber ducky antenna on my A-22... I've tried to use it once.. so.. maybe save the $ and not get the Nav model... but.. it would be good to be able to transmit on one when you have to listen to the VOR freq to get FSS.. so maybe the NAV function would be worth it for that reason alone. I do not have the sport model, but an alkaline battery will last longer in storage than the NiMH. But I use my A-22 every weekend and it goes on the charger every Friday night. It is my primary radio while providing glider instruction (training glider not equipped with mounted radio or battery)and monitoring the freq/traffic pattern from airfield ops (out on the airfield).. I do keep a battery backup (alkaline) in the flight bag.. when I needed it, the 10 AA batteries lasted about 5 hours of continuous use. I'm also not familiar with either A5 or A6. I have an A-something, maybe A22. I was able to get an aux battery pack so the rechargeables stay in the unit all the time for occasional use, and the alkaline pack is right there in my flight bag with fresh batteries in case I really need it. Picked up the aux pack at OSH. |
Thanks for all of your replies - I have heard that the NAV function is
fairly useless. I hope to never be in a situation where my sectional reading, dead reckoning, situational awareness AND gps go out on me! In Jonathan Sorger wrote: This new pilot was rather freaked out after losing one of my two radios on my first 'real' long trip. Making me an even firmer believer in redundancy, it is time to get a handheld backup. I was all set on the Icom A5 Sport (alkaline battery) as this would be used as a backup. Now I see the A6 Sport has arrived. Can anyone familiar with these models recommend if the A6 is worth the extra $40 or so? It's hard for me (an inexperienced handheld user) to spot the differences online. Thanks, |
Not if you connect it to a NAV antenna.
Horizontal polarization vice vertical polarization for a COM antenna. Jonathan Sorger wrote: Thanks for all of your replies - I have heard that the NAV function is fairly useless. |
I'd go with the A6.
I have an A5 Sport and am satisfied with it, but for a few bucks more, why not get the latest whiz-bang features? Nothing is ever cheap about aviation. One thing others have not mentioned about the A5: it was designed for use with a battery pack that outputs a higher voltage than is obtained by using six AA's in the Sport pack. This means that even when using fully-charged NiMH cells or brand-new alkalines, the low battery indicator is always on. Does this cut down on the range? I don't know. I have contacted Icom about this and they confirm that there's nothing unusual about my radio. That's just how it is when using AA cells, standard alkaline or recharable. As others have noted, the nav features are useless when all you have is a rubber ducky antenna. However, not all handhelds are equal. I was amazed to find that, though a Yaesu could not detect an VOR until I could hit it by throwing the silly little thing at it, a Sporty's worked almost as well as the panel-mount. I did have an Icom along for this experiment, but it was a COM-only so it could not play in the NAV section. Tests were done with rubber duckies on the radio and with one taped horizontally along the top of the windshield. For COM performance, my tests were not sensitive enough to find any difference. And to the rental company, I'm really sorry about the duct tape residiue on the window. I did try to get it off, but someone was waiting for the airplane. |
I have a A 23 Sport here and I don't have the battery indicator on.
But only after changing from 1 Euro a pack alkalines to high quality ones. A pack for 6.99 Euro. "doc" schrieb im Newsbeitrag ... I'd go with the A6. I have an A5 Sport and am satisfied with it, but for a few bucks more, why not get the latest whiz-bang features? Nothing is ever cheap about aviation. One thing others have not mentioned about the A5: it was designed for use with a battery pack that outputs a higher voltage than is obtained by using six AA's in the Sport pack. This means that even when using fully-charged NiMH cells or brand-new alkalines, the low battery indicator is always on. Does this cut down on the range? I don't know. I have contacted Icom about this and they confirm that there's nothing unusual about my radio. That's just how it is when using AA cells, standard alkaline or recharable. As others have noted, the nav features are useless when all you have is a rubber ducky antenna. However, not all handhelds are equal. I was amazed to find that, though a Yaesu could not detect an VOR until I could hit it by throwing the silly little thing at it, a Sporty's worked almost as well as the panel-mount. I did have an Icom along for this experiment, but it was a COM-only so it could not play in the NAV section. Tests were done with rubber duckies on the radio and with one taped horizontally along the top of the windshield. For COM performance, my tests were not sensitive enough to find any difference. And to the rental company, I'm really sorry about the duct tape residiue on the window. I did try to get it off, but someone was waiting for the airplane. |
"Jonathan Sorger" wrote in message ... This new pilot was rather freaked out after losing one of my two radios on my first 'real' long trip. Making me an even firmer believer in redundancy, it is time to get a handheld backup. I was all set on the Icom A5 Sport (alkaline battery) as this would be used as a backup. Now I see the A6 Sport has arrived. I have an Icom A23. The one time I needed it, the rechargeable batteries were dead. Get an extra alkaline battery pack even for the sport models. All of the radios draw some current even when off and eventually you'll be replacing batteries or recharging them. The alkaline battery packs have to be removed and then the batteries can be changed before re-assembling everything. I wouldn't want to be changing individual alkalines solo in IMC. Much easier to swap a pack. Feature for feature, all the radios from several manufacturers have virtually the same specifications. Vertex Standard models had a few specifications that were very slightly better than other brands. I did a lot of research before I bought the Icom A23. The only reason I didn't buy the Vertex Standard was the NiCd battery vs. the NiMH in the Icom. The NiMH battery should last longer than NiCd because of the higher power output and generally has better characteristics. The Icom A5 is virtually identical to the A23 except for the nav and duplex functions. The new A6 appears to be a slightly larger version of the A5. If you need or want the duplex function go with the A23. Size is about the only difference between the A5 and the A6. If the headset adapter doesn't come with it be sure and get one. My former instructor kept his headset adapter plugged into his radio and told me about losing radios (complete electrical failure) on more than one occasion though for different reasons. He had an older A21 and it worked fine on alkalines though the NiCd batteries died. Icom is a good company and I joked with my DE for my instrument checkride. I must be really having a bad day if the electrical system in the airplane and my handheld died. It has already earned it's keep in my bag though.I keep spare batteries for everything in my bag so even dead batteries won't stop me. I'm really having a bad day if everything fails. |
I keep a pack of alkaline batteries in the airplane.. A 30 pak I get
from Home Depot... I have switched from NiCd, NiMh, Li, etc., batteries to alkalines for back up in the 195 and 295 in the plane... Also for the Lightspeeds, the prop tach meter, the LED flash lights, etc... Also in the antenna analyzers, the frequency counter, the Nikon F5, and on, and on, in my shop... After I idly did a cost analysis one night I realized that by the time you purchase batteries and chargers, and put up with the rapid self discharge, and the lower voltage, and buying new rechargeable batteries on nearly an annual basis, you are money ahead to simply use alkalines... Denny |
| Thread Tools | |
| Display Modes | |
| Thoughts on handheld Aviation radios (ICOM vs Vertex-Standard) | Barnyard BOb - | Home Built | 5 | September 8th 04 08:27 PM |
| Thoughts on handheld Aviation radios (ICOM vs Vertex-Standard) | Cub Driver | Piloting | 0 | September 8th 04 11:35 AM |
| Boosting ICOM IC-A23 Handheld Aviation Radio | CHANGE USERNAME TO westes | Instrument Flight Rules | 23 | June 9th 04 01:41 PM |
| HeadSets, Handheld Radios and GPS's forsale all NEW. | George | Piloting | 0 | January 9th 04 04:01 PM |
| HeadSets, Handheld Radios and GPS's forsale all NEW. | George | Aviation Marketplace | 0 | January 9th 04 04:01 PM |
