"Same thing: If my transponder is not interrogated, the target
transponder won't be, either." Nothing could be further from the truth. I would reccomend you talk to your local center, or approach control and see why because the explanation is rather lengthy. Also bear in mind the growing amount of Mode S transponders which transmit regardless of interrogations. Even so, what altitude would your ATD show if you flew out of radar at 5,000 feet and descended 1,000 feet? Without that interrogation, it would still be locked at 5,000. "Well, time to read the manual again. To quote "In extremely rare cases..." the above may happen. A solution to the problem is given in the manual." I read that, and have learned from MANY years that when a manufacturer says *extremely rare cases* you can bank on it happening often. I also went a step further and read http://www.airsport-corp.com/modecascii.txt which lists the pages and pages and more pages of squawk codes that WILL confuse it. If you fly IFR at all, the last thing you want to be doing is trying to fix the ATD while you are flying through the soup. A "solution"? Why go through all this? Why wonder if the unit is getting the right altitude? Just get one of the other two units and then you'll know for sure, whether you fly in or out of radar. "Do you read Aviation Consumer, for example? Their preference among the previous generation of traffic detectors was pretty clear." Actually I have a subscription, but you know, nowhere is there a review on the Proxalert, Trafficscope, or ATD300. I do however, see a review from 2 years ago on previously two of the three manufacturers older devices of the TPAS and ATD200. Now surely, you are not trying to imply that a consumer review on completely different models from years past are applicable to anything these manufacturers, or future manufacturers develope are you?? If that where the case Garmin must STILL be living in a "dreamworld where we navigate by satellites" and glass cockpits are still a "Fad which will soon fade" Better yet, I would be curious if Aviation Consumer is planning on reviewing all three of these devices. Thomas Borchert wrote in message ... Loran, Since the ATD relies solely on your transponder for altitude, If you took off out of an airport and you didn't reach adequate radar coverage for 1000 feet or more, how is the ATD unit going to know what altitude you are? Huh? If my transponder is not interrogated, how will other traffic close by and at my altitude be interrogated? So, even if my traffic detector knows my altitude from pressure, it will still not know the target altitude. That scenario doesn't work for any traffic detector. If you where flying in radar coverage at say 5,000 feet, and another aircraft is say 5,700 feet headed towards you. The ATD would say you are 5,000 feet correct? but what happens if you fly out of radar coverage, and climb or descend? Same thing: If my transponder is not interrogated, the target transponder won't be, either. So if you started climbing, 5,100......5,200.....etc the ATD would still say you are at 5,000 feet since that was the last altitude it got from your transponder correct? No. It would show absolute altitude of the target, if the target transponder is being interrogated and giving off Mode C info, and mine isn't. Suppose you are flying with the ATD at 2,000 feet and ATC gives you a squawk code that equals 1,400 feet. Another aircraft close by is at an altitude of 2,900 feet The atd will be confused and bounce between showing traffic +900......-600.......+900.......-600 Well, time to read the manual again. To quote "In extremely rare cases..." the above may happen. A solution to the problem is given in the manual. let me ask you this. If you flying in the pattern of a busy airport, how often are other aircraft within 1 NM of you? Not sure I understand the meaning of the question. But I'll offer one thing which I have said befo If you are looking at any traffic detector while in the pattern of a busy airport, please tell me before which airport it will be so I can stay as far away as possible. If two equal threats come into the scene, what will the ATD show? a flipping back and forth picture? At what rate? Is it not possible for 2 or more aircraft to be flying around you near any airport? See the problem here? No. The ATD will give preference to the closer threat. Makes sense to me. And by that time, you should be looking outside anyway! Let me ask you this, with other units having most likely a higher profit margin, more ESSENTIAL features, why are you as a business, so eager to promote and sell a less superior product line and make less money? That makes no sense to me if I where a business. I would think you would want to sell your customers the best products for the most profit. That is how I run my business anyway. There are many competitive products I can choose from, but I wouldn't pick out the least favored and less profitable to run frontage on. Least favored by who? Do you read Aviation Consumer, for example? Their preference among the previous generation of traffic detectors was pretty clear. Also, if you assume higher profits (which I don't know anything about), are you saying you LIKE to be ripped off? Let me tell you my business model: I try not to rip off my customers on the vague assumption that "Anything good in aviation has to be expensive". And yes, that works quite well, thank you. Have you spent any time actually flying with a traffic detector? I have. That's how I arrived at my questions and conclusions. And the scenarios you offer frankly don't convince me at all to spend almost double the money. But then, I'm probably biased. g |
| Thread Tools | |
| Display Modes | |
| Plane with no stall warning device? | Roy Smith | General Aviation | 23 | February 17th 04 04:23 AM |
| "I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 10th 04 12:35 AM |
| USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 04:17 PM |
| Riddle me this, pilots | Chip Jones | Instrument Flight Rules | 137 | August 30th 03 05:02 AM |
| Riddle me this, pilots | Chip Jones | Piloting | 131 | August 30th 03 05:02 AM |
