Joe,
When I started flying my LS-1 with it's CG hook, I probably had never aero-towed with a CG hook. I had aero-towed with nose hooks and winch launched with CG hooks and probably had about 300 hours (?). I did experience a problem on my first takeoff that can be attributed to the CG hook and a bit of tail-heaviness in the glider. It was cured with a proper 'A&P' certified weight and balance with me in the cockpit and the glider sitting on the scales. We added weight to the nose (since then, I've added weight around my belly...) I would think an experienced pilot should handle the CG hook for aerotowing well, but a newly licensed pilot, I think, should get a lot of information from the instructor. Maybe allow the instructor to fly the ship some before he, the newly licensed pilot does, so the instructor can discuss the flying characteristic? Also, if a two-place ship is available with a CG hook, could it legally and safely be aerotowed with the CG hook if a nose hook is available? If so, why not do some dual with the instructor in the two-seater? Ray Lovinggood Carrboro, North Carolina PS: To David Hofstee. Hi David. Still the same Ray here on the 'liberal' side of Chapel Hole! At 22:36 22 July 2003, Joe Lacour wrote: I have recently bought an LS-4A with a CG hook. What kind of problems did you have with aero-towing with a DG hook? Joe On Tuesday, July 22, 2003, at 05:15 PM, Glider Pilot Network wrote: ------------------------------------------------------------ Newsgroup: rec.aviation.soaring Subject: ASW 24 WL for beginner ? Author: Dhofstee Date/Time: 22:10 22 July 2003 ------------------------------------------------------------ Ray Lovinggood wrote: If you get a ship with a CG hook and you launch via aero-tow, make sure you can learn all you can from the instructors before you make that first launch. Didn't do that, nearly became a statistic... One of the two moments in my (never ending) 'training' that I don't want to repeat. Ray Lovinggood Carrboro, North Carolina, USA Is that the same Ray that was present then? ;-) David NL ------------------------------------------------------------ |
"Ray Lovinggood" wrote in message ... Snip---- Also, if a two-place ship is available with a CG hook, could it legally and safely be aerotowed with the CG hook if a nose hook is available? If so, why not do some dual with the instructor in the two-seater? Ray Lovinggood Carrboro, North Carolina It's legal and a good idea. I've done this sort of transition training many times using a variety of two-place trainers equipped with CG hooks. If the pilot flies the airtow within normal limits there are few differences to show the effect of the CG hook. However, if the glider gets high, things can go bad in an instant. I always brief the tug pilot that if he feels the tail being pulled up, he should release his end of the rope instantly. Occasionally, a transitioning pilot will turn up who has a habit of relying on the nose mounted hook to help keep him in position laterally. That pilot, when flying with a CG hook, will have to learn to fly the glider more aggressively to stay in position. There were some flights testing air towing with CG hooks done in the UK. The take-home lesson seemed to be that a glider in a too-high position with a nose hook is still recoverable. With a CG hook, the situation becomes unrecoverable in an eyeblink. Air towing with a CG hook creates a situation where things can appear controllable one instant and completely out of control the next. This is what prompted the LBA to mandate the installation of nose hooks for airtow in Germany. I wouldn't go that far, but replacing the tug's Schweitzer hook that can't be released under a strong up-load with a Tost hook that can makes a lot of sense. Bill Daniels |
Why wouldn't you "go that far"?
Every glider should be equipped with a nose hook. In today's world, how many of us will ever fly off a winch? The nose hook should be standard with the c of g hook optional, not the other way around! We should insist on nose hooks on all new gliders and stop letting our knuckle-dragging egos cling to the past. This is what prompted the LBA to mandate the installation of nose hooks for airtow in Germany. I wouldn't go that far, but replacing the tug's Schweitzer hook that can't be released under a strong up-load with a Tost hook that can makes a lot of sense. Bill Daniels |
Depends where you are.
There are winches at every club I have ever visited in South Africa. At my club we gave up on Aerotow 8 years ago. It is expensive. It is slow. It is more dangerous in some ways. We have predictable enough thermals that we have very low 'relight' incidence. That said, you need aerotow when you have long wings, or are carrying water or need the height or physical displacement to be able to contact lift. The nose hooks on our gliders are pristine, make us an offer... Stephen Szikora wrote: Why wouldn't you "go that far"? Every glider should be equipped with a nose hook. In today's world, how many of us will ever fly off a winch? The nose hook should be standard with the c of g hook optional, not the other way around! We should insist on nose hooks on all new gliders and stop letting our knuckle-dragging egos cling to the past. This is what prompted the LBA to mandate the installation of nose hooks for airtow in Germany. I wouldn't go that far, but replacing the tug's Schweitzer hook that can't be released under a strong up-load with a Tost hook that can makes a lot of sense. Bill Daniels |
"Bruce Greeff" wrote in message ... Depends where you are. There are winches at every club I have ever visited in South Africa. At my club we gave up on Aerotow 8 years ago. It is expensive. It is slow. It is more dangerous in some ways. We have predictable enough thermals that we have very low 'relight' incidence. That said, you need aerotow when you have long wings, or are carrying water or need the height or physical displacement to be able to contact lift. The nose hooks on our gliders are pristine, make us an offer... I agree. Bill Daniels |
| Thread Tools | |
| Display Modes | |
