"Cy Galley" wrote in message
news:eAeid.52917$R05.12713@attbi_s53... You can take it to an automotive speedometer shop and they can clean, lubricate, and calibrate. Tell them that it is driven off the cam in your stock car so they get it right and don't panic. Okay, Cy - here's what I found out. The speedo shop said they would be happy to look at it and fix it, even if they have to throw away the guts and replace them with a new SW unit. If they have the parts, it would be $92 for an overhaul. A completely new unit would run ~$120. They said the common problem with this type of tach is worn bearings on the cup shaft which allows interference between the cable shaft and the cup. The scuff marks in my tach make it appear as if this is the problem. I think I'll buy another used but operative unit. Prices seem to run in the $40-60 range. If it lasts another three years I'll be happy. Rich |
"Rich S." wrote in message
... I think I'll buy another used but operative unit. Prices seem to run in the $40-60 range. If it lasts another three years I'll be happy. Rich Just curious... Why would you want to get a second-hand, unknown history instrument for $50 when the difference to a new instrument is about as much as one long flight?!? You are going to rely on that instrument for years to properly run a $15000 engine in a $40000 plane (guestimates..), why not get a new one that will probably last the remainder of the plane's life?? Rob |
"Rob Turk" wrote in message
... Just curious... Why would you want to get a second-hand, unknown history instrument for $50 when the difference to a new instrument is about as much as one long flight?!? You are going to rely on that instrument for years to properly run a $15000 engine in a $40000 plane (guestimates..), why not get a new one that will probably last the remainder of the plane's life?? Rob.............. Several reasons come into play. I am not of the mind set that says, "If it ain't new, it's junk". My Pappy always told me, "All of the cars on the road stop with used brake parts". 1. A tachometer is not a critical instrument. 2. I will select a good quality instrument and have it calibrated. 3. At this point in my life's journey, I purchase items which will last as long as *I* will need them - not for "the remainder of the plane's life". The philosophy of sparing no expense simply because we are dealing with airplanes must have limits. Otherwise, we would change oil, filters, and sparkplugs before every flight - or other equally silly tasks. Every one of my instruments was purchased used. In five years and four hundred hours of flight, the tachometer is the first one to present a problem. Who's to say that an all-new panel wouldn't have had at least one malfunction in that time? Rich S. |
On Fri, 5 Nov 2004 07:14:45 -0800, "Rich S."
wrote: "Rob Turk" wrote in message ... Just curious... Why would you want to get a second-hand, unknown history instrument for $50 when the difference to a new instrument is about as much as one long flight?!? You are going to rely on that instrument for years to properly run a $15000 engine in a $40000 plane (guestimates..), why not get a new one that will probably last the remainder of the plane's life?? Rob.............. Several reasons come into play. I am not of the mind set that says, "If it ain't new, it's junk". My Pappy always told me, "All of the cars on the road stop with used brake parts". 1. A tachometer is not a critical instrument. 2. I will select a good quality instrument and have it calibrated. 3. At this point in my life's journey, I purchase items which will last as long as *I* will need them - not for "the remainder of the plane's life". The philosophy of sparing no expense simply because we are dealing with airplanes must have limits. Otherwise, we would change oil, filters, and sparkplugs before every flight - or other equally silly tasks. Every one of my instruments was purchased used. In five years and four hundred hours of flight, the tachometer is the first one to present a problem. Who's to say that an all-new panel wouldn't have had at least one malfunction in that time? Rich S. my airspeed indicator is ww2 vintage and is still calibrated within 1 knot of what it should read. my black and white AH is out of a dead cessna. in fact none of the instruments is younger than the airframe. they were all selected as old trusted mechanisms. no need to change the approach Rich. it works the world over. Stealth Pilot |
On Wed, 3 Nov 2004 13:23:05 -0800, "Rich S."
wrote: So, I was flying back home, happily burping all the shellfish I ate at the Shelton Oysterfest, when my engine started speeding up. Well, it didn't really - but my tach said it did. Without touching the throttle, I went from 2400 rpm up to 3400. Funny, my airspeed didn't change. It looks like my sturdy, simple mechanical tach (bought used at OSH) has gone South on me. I pulled it out and removed the case. Everything inside looks great. It is cable driven through a magnetic coupling just like a car speedo. The needle has a return spring wound in a coil like a clock spring. I assume the calibration is done by setting the needle on its shaft in a position relative to the return spring, so a given rpm matches the needle position on the dial. I thought I would discover a broken return spring, but it looks okay. Turning the drive with an 1100 rpm electric drill shows ~2500 on the dial. If I allow the needle to bypass the stop pin and add an extra full turn of tension on the return spring, the tach shows the drill turning ~400. It looks like the needle has slipped on the shaft releasing about a half-turn of spring tension. Either that or A. the spring has developed a weak spot or B. the other end of the spring has come unsoldered from the frame. I don't think it's "B" because the entire spring would be unwound. Visual examination of the spring doesn't show any defects. Any ideas? How about either a change inmagnetic flux or a change in the position of the EC (Edy Current) ring? A weakened magnet would cause the reading to DROP. So something that causes the aluminum disc to get closer to the magnet would cause the RPM to read high, or something that causes the air movement from the spinning magnet to influence the disc - like a bit of oil or grease from the cable migrating into the instrument. Rich "May as well take it apart - it don't work" S. |
"Jerry J. Wass" wrote in message
... DON'T TAKE IT APART !! At least not until you have lubed the drive cable.. when they get dry, they start sticking somewhere, the part in front of the "stick" winds up a little, then releases this energy in a quick snap, this causes the instrument to read high. I know this may sound silly, but it happens every winter with my trucks. TOO LATE !! But I got it back together. Even used all the pieces ![]() Actually, you anticipated my next thought. I got to wondering if I was assuming too much by blaming the tach head. I'm going to reassemble the unit in the case and lube the cable. Thanks, Jerry. Rich S. |
... How about either a change inmagnetic flux or a change in the position of the EC (Edy Current) ring? A weakened magnet would cause the reading to DROP. So something that causes the aluminum disc to get closer to the magnet would cause the RPM to read high, or something that causes the air movement from the spinning magnet to influence the disc - like a bit of oil or grease from the cable migrating into the instrument. Like I said, everything looked fine inside (no dirt or grease). There is a scuff mark on the inside of the disk which could be new or old. If lubing the cable doesn't do the trick, I'll probably send it out to be rebuilt; unless the cost is more than another used unit. Thanks, Rich S. |
"Rich S." wrote in message ...
wrote in message ... How about either a change inmagnetic flux or a change in the position of the EC (Edy Current) ring? A weakened magnet would cause the reading to DROP. So something that causes the aluminum disc to get closer to the magnet would cause the RPM to read high, or something that causes the air movement from the spinning magnet to influence the disc - like a bit of oil or grease from the cable migrating into the instrument. Like I said, everything looked fine inside (no dirt or grease). There is a scuff mark on the inside of the disk which could be new or old. If lubing the cable doesn't do the trick, I'll probably send it out to be rebuilt; unless the cost is more than another used unit. Thanks, Rich S. Look closer. The inboard end of the shaft that carries the needle fits into a tiny bore in the inboard end of the input shaft to keep the magnet and drum concentric with one another. This close fit is subject to dried-out lube or a bit of grit interfering with the needle shaft's freedom and drives the needle up. Or it might be worn to the point that it's chattering and adding friction, with the same result. Dan |
Ramifications of Cherokee Trim Jackcrew Failure | Bob Chilcoat | Home Built | 23 | June 9th 04 02:48 AM |
Tail flapper failure | Veeduber | Home Built | 2 | May 22nd 04 06:52 AM |
Single-Seat Accident Records (Was BD-5B) | Ron Wanttaja | Home Built | 41 | November 20th 03 05:39 AM |
Interesting Flybaby wing failure analysis... | Richard Lamb | Home Built | 3 | August 27th 03 05:21 PM |
Hinges under stress - mechanical engineering type question | Corrie | Home Built | 21 | August 6th 03 08:49 AM |
