Glider vs. Power Pattern Bank Angle?
Old June 11th 04, 09:52 PM
ADP
If you can't pull off power, abeam the numbers, between 500 ft and 1000 ft
above the airport and make a landing
without adding or using power, you ought not to be flying light aircraft.
(Single engine 5000#)
Allan
The power-off pattern, where you bring the power to idle at about
800-1000 ft AGL and abeam the touchdown point and continue to a
landing, was once the normal pattern in general aviation for all light
trainers. Of course in such a pattern your turns will be 30-45
degrees of bank, depending on wind and how many mistakes you make.
The trainers have not changed; in fact we're mostly flying the same
ones. However, today's instructors see this as an emergency
procedure, not a normal one, because it pushes their skill level.
Michael
Old June 12th 04, 01:25 AM
Vaughn
"Michael" wrote in message
om...
illspam (Jim Vincent) wrote
Mainly because the quality of power instruction is, on the whole,
dramatically worse than the quality of glider instruction. The
majority of power instructors are low time, inexperienced pilots who
have completed a training program that takes them from zero time to
instructor (single, multi, and instrument) in less than 300 hours.
They have been taught to fly wide, power-on patterns with stabilized
power-on approaches because this is what they will be doing in the
airlines (their eventual goal) and that's what they teach their
students because they don't know anything else.
Actually there are many reasons, some of them may be found in the SEL PTS.
Another is that airports with lots of light aircraft training end up with huge
"follow the leader" patterns.
Steep turns, especially at low speed, simply scare them. Therefore,
many of them tell students not to exceed 30 degrees of bank in the
pattern.
After several years of soaring, I recently decided to transition to power.
I have had that poor guy squirming in his seat and grabbing for the controls
more than once doing things that I considered perfectly normal, including tight
turns in the pattern.
Come to think of it, the FAA has changed landings since our trainers were
designed. Vaguely 20 years ago, there was a sea change in the way landing
technique was taught because someone in the FAA decided that normal landings
would be accomplished with full flaps. The normal technique that is taught
these days (at least in a Cezzna) is the first notch on downwind, second notch
on base and full flaps on final. This adds so much drag that you either do a
high (and or tight) pattern or you must drag the thing around the pattern with
power. Guess which one they usually teach?
Vaughn
Michael
Old June 14th 04, 03:28 PM
Michael
True. I oversimplified. Far be it from me to suggest that the FAA
isn't a big part of the problem - it is. Some of the stuff in the PTS
is garbage. It's getting better again, though. Real slow flight is
back - for several years, slow flight was redefined as 1.2 Vso. Steep
turns were redefined to 45 degrees and I see no hope of change there.
The 180 to a landing is back in the commercial PTS though, and that's
a plus.
with huge "follow the leader" patterns.
Ah, yes - the "everybody is doing it" argument. Actually, I do
understand - sometimes the safest thing to do is just grit your teeth
and do it the same way everyone else does it. Only when I learned to
fly I was taught that when the pattern is strung out that way, you
hold your altitude until you reach power-off gliding distance of the
field, then reduce to idle and glide in.
Well, that makes sense to me. As far as I'm concerned, the normal
landing is made with full flaps. Anything less is a special case - a
reduced-workload training exercise for an early presolo student,
strong crosswind in an airplane where flaps reduce rudder/elevator
authority, that kind of deal. Otherwise, why accept the higher
touchdown speed with its attendant risks, extra wear on tires and
brakes, etc?
And there's the problem. What's wrong with a clean downwind, two
notches on base to adjust the glide, and then the rest on final when
it looks right? I was taught to land that way. In fact, I was taught
to land a Cessna by bringing the power to idle abeam the numbers and
adding flaps as necessary to control glideslope. Might have had
something to do with the fact that my primary instructor flew gliders
too...
Right - because that's all they know. They really don't know enough
about flying a tight high pattern to teach it.
In a multiengine turbine airplane, what they teach is actually the
right thing to do. Those engines take time to spool up, so you dirty
the plane up, keep the engines spooled up, and for a go-around you
clean up the plane - this way you can get a climb going before the
engines are fully spooled up.
The problem is, we're flying light piston airplanes.
Michael
Glider power systems Bill Daniels Soaring 13 May 6th 04 10:53 PM
Winch Experts wanted Ulrich Neumann Soaring 117 April 5th 04 06:52 AM
Restricting Glider Ops at Public Arpt. rjciii Soaring 36 August 25th 03 04:50 PM
