Stewart Kissel wrote:
So if a Start Point is declared....you can tow as high as you want with out penalty? And a declared finish point altitude is then subtracted from this? Not quite. You don't declare the elevation of the start and finish points, nor is the elevation of the ground underneath the points relevant. The start altitude for a declared start is the (pressure) altitude from the last fix recorded before you cross the start line or exit the start sector. The finish altitude for a declared finish is the (pressure) altitude from the first fix after you cross the finish line or enter the finish sector. So, if you cross the start line at an altitude of 3120 meters, you have to finish at 2120 meters or above to avoid the penalty. Marc |
And if you use tow release as your start with no declared finish...can you land anywhere you please? At 05:30 29 August 2004, Stewart Kissel wrote: So if a Start Point is declared....you can tow as high as you want with out penalty? And a declared finish point altitude is then subtracted from this? At 05:00 29 August 2004, Eric Greenwell wrote: Marc Ramsey wrote: Stewart Kissel wrote: For a distance task with 3 TP's and no Start Point or Finish Point declared...does the release from tow have to be the start or can it be declared post flight? If so does the 1,000 meter tow penalty still take effect? The finish point can be declared afterward? It does not have to be the landing? And the 1,000 meter difference between start and finish is calculated from the post-flight start and finishes? You can't post-declare start or finish points for a distance task. If you want a start point other than the point of release, or a finish point other than the point of landing, you need to declare them before flight, along with the turnpoints. The 1000 meter allowance is between the start point altitude and finish point altitude, so if neither start nor finish is declared, the difference in altitude between the point of release and the point of landing must be 1000 meters or less to avoid the penalty. It's unlikely Stewart was talking about world records, but the Code says 1.4.3 Free distance performances for records only The WAY POINT(S) of free distance record flight performances may be declared post-flight. Since the start and finish are way points, it sounds like they could be declared post-flight. This would also work for USA State records, which allow the free distance task. For badges, it's pretty clear (note the last sentence): 1.4.5.b. DISTANCE USING UP TO THREE TURN POINTS A flight from a START POINT via up to three TURN POINTS to a FINISH POINT. If the FINISH POINT is the landing place it need not be declared. The TURN POINTS must be at least 10 kilometres apart and may be claimed once, in any sequence, or not at all. This course must be declared. What I think is a quirk in the rules lets a motorglider pilot effectively choose the end of the task by starting the motor, but the unpowered glider pilot must either declare an end point or use the landing point. -- Change 'netto' to 'net' to email me directly Eric Greenwell Washington State USA |
And if you use tow release as your start with no declared finish...can you land anywhere you please? Yes, but for a distance task you can do that in any case, even if you declared a finish. I also believe (but I'm not 100% certain, Judy can correct me on this), that you can declare a start point, fly the distance task without actually claiming the declared start, and get credit for the distance task based on an undeclared start at the point of release. Marc |
Ah, that was going to be my next question Mark. Can
you use the release point if you have a declared Start Point. I gotta see what Judy says on this. Would you not want to always have a declared finish...so you can get credit for altitude you have at the finish, rather then use the landing for the finish and lose that altitude for your calculation versus the start altitude? At 06:00 29 August 2004, Marc Ramsey wrote: Stewart Kissel wrote: And if you use tow release as your start with no declared finish...can you land anywhere you please? Yes, but for a distance task you can do that in any case, even if you declared a finish. I also believe (but I'm not 100% certain, Judy can correct me on this), that you can declare a start point, fly the distance task without actually claiming the declared start, and get credit for the distance task based on an undeclared start at the point of release. Marc |
Would you not want to always have a declared finish...so you can get credit for altitude you have at the finish, rather then use the landing for the finish and lose that altitude for your calculation versus the start altitude? That's what I always do... Marc |
At 07:00 29 August 2004, Marc Ramsey wrote:
Stewart Kissel wrote: Would you not want to always have a declared finish...so you can get credit for altitude you have at the finish, rather then use the landing for the finish and lose that altitude for your calculation versus the start altitude? That's what I always do... Marc Ok, this helps clear up an issue that has been bugging me. I would be interested in anyone who could verify/comment on whether a tow release could be used for a start...If a Start Point had been declared. If this cannot occur, I see pluses and minuses for using either scenario. |
Ok, this helps clear up an issue that has been bugging me. I would be interested in anyone who could verify/comment on whether a tow release could be used for a start...If a Start Point had been declared. No, it cannot (except reverting to a *free record* performance) But you may use release altitude as your start altitude (for the 1000 m difference with the altitude at finish point) and pass within the declared start point observation zone later and higher (distance flights only, not allowed on speed tasks) -- Denis R. Parce que ça rompt le cours normal de la conversation !!! Q. Pourquoi ne faut-il pas répondre au-dessus de la question ? |
Denis wrote:
Stewart Kissel wrote: Ok, this helps clear up an issue that has been bugging me. I would be interested in anyone who could verify/comment on whether a tow release could be used for a start...If a Start Point had been declared. No, it cannot (except reverting to a *free record* performance) SC3 1.4.5.b says that distance using up to three turnpoints is "A flight from a START POINT via up to three TURN POINTS to a FINISH POINT." Note that is says "a START POINT", not "the START POINT". SC3 1.1.8 says a START POINT is either "(a) The RELEASE POINT, or (b) A WAY POINT declared as a START POINT, or (c) The midpoint of a START LINE." Note that the pilot or data analyst can apparently choose between (b) and (c) after the flight, as I've never seen a declaration form (paper or electronic) that requires that you declare before the flight that you are using a start line as opposed to a start way point (with OZ). Being a computer programmer, I'd argue that the "or" in clause (a) has the same logical precedence as the "or" in clause (b). Therefore, if you have declared a start, it still seems to me that it would be valid to use any of the START POINT options, including the RELEASE POINT. Have you found a rule someplace else that would render this interpretation incorrect? Marc |
Marc,
I can verify that this interpretation is correct. In 1999, I used this interpretation and received my 1000km. It was not easy to obtain with this interpretation and it took many months of perseverance. I believe I was the first to do this and I don't think they were happy about my insistence on this literal interpretation of the rule. It would be interesting to know if anyone else has successfully used it. I took off at Ridge Soaring with Altoona declared as a start and finish. Three turnpoints were declared between and then landed at Ridge Soaring. I got in wave on my way to Altoona and decided to fly down to Cumberland for fun before I started. I was in wave when I started at Altoona. I was able to use my tow release as my start altitude and my finish altitude at Altoona for the 1000m calculation. Dale Kramer K1 Marc Ramsey wrote in message . com... Denis wrote: Stewart Kissel wrote: Ok, this helps clear up an issue that has been bugging me. I would be interested in anyone who could verify/comment on whether a tow release could be used for a start...If a Start Point had been declared. No, it cannot (except reverting to a *free record* performance) SC3 1.4.5.b says that distance using up to three turnpoints is "A flight from a START POINT via up to three TURN POINTS to a FINISH POINT." Note that is says "a START POINT", not "the START POINT". SC3 1.1.8 says a START POINT is either "(a) The RELEASE POINT, or (b) A WAY POINT declared as a START POINT, or (c) The midpoint of a START LINE." Note that the pilot or data analyst can apparently choose between (b) and (c) after the flight, as I've never seen a declaration form (paper or electronic) that requires that you declare before the flight that you are using a start line as opposed to a start way point (with OZ). Being a computer programmer, I'd argue that the "or" in clause (a) has the same logical precedence as the "or" in clause (b). Therefore, if you have declared a start, it still seems to me that it would be valid to use any of the START POINT options, including the RELEASE POINT. Have you found a rule someplace else that would render this interpretation incorrect? Marc |
Dale Kramer wrote:
I took off at Ridge Soaring with Altoona declared as a start and finish. Three turnpoints were declared between and then landed at Ridge Soaring. I got in wave on my way to Altoona and decided to fly down to Cumberland for fun before I started. I was in wave when I started at Altoona. I was able to use my tow release as my start altitude and my finish altitude at Altoona for the 1000m calculation. If I understand, you did use your pre-declared start point (Altoona) as start position - meaning that you actually passed through its observation zone, and it was used for distance calculation ? -- Denis R. Parce que ça rompt le cours normal de la conversation !!! Q. Pourquoi ne faut-il pas répondre au-dessus de la question ? |
| Thread Tools | |
| Display Modes | |
| Run up for plug clearing | Roger Long | Piloting | 78 | October 18th 04 04:39 AM |
| ramifications of new TSA rules on all non-US and US citizen pilots | paul k. sanchez | Piloting | 19 | September 28th 04 12:49 AM |
| For Keith Willshaw... | robert arndt | Military Aviation | 253 | July 6th 04 06:18 AM |
| Ultralight Club Bylaws - Warning Long Post | MrHabilis | Home Built | 0 | June 11th 04 06:07 PM |
| Winch Experts wanted | Ulrich Neumann | Soaring | 117 | April 5th 04 07:52 AM |
