Marc Ramsey wrote:
SC3 1.4.5.b says that distance using up to three turnpoints is "A flight from a START POINT via up to three TURN POINTS to a FINISH POINT." Note that is says "a START POINT", not "the START POINT". SC3 1.1.8 says a START POINT is either "(a) The RELEASE POINT, or (b) A WAY POINT declared as a START POINT, or (c) The midpoint of a START LINE." Note that the pilot or data analyst can apparently choose between (b) and (c) after the flight, as I've never seen a declaration form (paper or electronic) that requires that you declare before the flight that you are using a start line as opposed to a start way point (with OZ). Being a computer programmer, I'd argue that the "or" in clause (a) has the same logical precedence as the "or" in clause (b). Therefore, if you have declared a start, it still seems to me that it would be valid to use any of the START POINT options, including the RELEASE POINT. Have you found a rule someplace else that would render this interpretation incorrect? this one ? SC3 1.4.1.d. WAY POINTS must be declared and used in the sequence declared except where specifically not required in the rules. SC3c, which says how to interpret SC3, says in 1.1 : If you think a passage of text is capable of being interpreted in more than one way, the most straightforward interpretation is the correct one, not the obscure one that a lawyer may find. but in 1.2 it says (which may be the contrary) : OOs and national claims officers are encouraged to take the position that, while ensuring the rules are met, their job is to make awards, not turn them down for minor bureaucratic reasons or oversights that do not affect the proof of a soaring performance. SC3c 3.1 says: The Code gives four methods of starting and finishing to choose from. Any start method can be used with any finish method: The start (SC3-1.1.7) The finish (SC3-1.1.11) 1 release landing 2 leaving a start point OZ entering a finish point OZ 3 crossing a start line crossing a finish line 4 shutting down a MoP starting a MoP The first and fourth alternatives can be considered equivalent, and do not normally need to be pre-declared. The exceptions are a goal flight when the finish point is declared, or a closed course flight in which the nomination of “point of release” as the start point and finish point will meet the declaration requirement. The second and third methods of starting always require pre-declaration of the start point (except for free distance flights). Although it is not straightforward, I would say that you may declare "release point" as the start point (as of SC3 1.1.8 option a), but if you already declared a precise Start point, you may not change it inflight to the release point. In the case of a closed course, the release point may not be used since the start point and the finish point are to be identical and finish point may not be defined as the release point ! Start line option is another quirk in the SC3. I would say that it only applies when declared, but I see no mean to declare this in a logger ! Except in an official competition, the start line is undefined - SC3 says "*approximately* perpendicular to the first leg" which in the case of observation from the ground may have sense, but not when GPS is used. Same for finish line... Perhaps we'd need an annex D to the sporting code, saying how to interpret the annex C ;-) ? -- Denis R. Parce que ça rompt le cours normal de la conversation !!! Q. Pourquoi ne faut-il pas répondre au-dessus de la question ? |
Denis wrote:
In the case of a closed course, the release point may not be used since the start point and the finish point are to be identical and finish point may not be defined as the release point ! How about SC3 Annex C 3.1 which says 'or a closed course flight in which the nomination of "point of release" as the start point and finish point will meet the declaration requirement.'? Marc |
![]() Gotcha...so u gotta use the Start Point if declared...but u can pick which altitude for the calculation(Release from tow, or Start Point elevation) But you may use release altitude as your start altitude (for the 1000 m difference with the altitude at finish point) and pass within the declared start point observation zone later and higher (distance flights only, not allowed on speed tasks) -- Denis R. Parce que ça rompt le cours normal de la conversation !!! Q. Pourquoi ne faut-il pas répondre au-dessus de la question ? |
It's starting to get a little gray now, to summarize...
If u declare a Start Point...one can either use release or Start Point for initial altitude for penalty caluculation. And then you can compare this against altitude at Finish Point observation sector? At 12:54 30 August 2004, Dale Kramer wrote: Marc, I can verify that this interpretation is correct. In 1999, I used this interpretation and received my 1000km. It was not easy to obtain with this interpretation and it took many months of perseverance. I believe I was the first to do this and I don't think they were happy about my insistence on this literal interpretation of the rule. It would be interesting to know if anyone else has successfully used it. I took off at Ridge Soaring with Altoona declared as a start and finish. Three turnpoints were declared between and then landed at Ridge Soaring. I got in wave on my way to Altoona and decided to fly down to Cumberland for fun before I started. I was in wave when I started at Altoona. I was able to use my tow release as my start altitude and my finish altitude at Altoona for the 1000m calculation. Dale Kramer K1 Marc Ramsey wrote in message news:... Denis wrote: Stewart Kissel wrote: Ok, this helps clear up an issue that has been bugging me. I would be interested in anyone who could verify/comment on whether a tow release could be used for a start...If a Start Point had been declared. No, it cannot (except reverting to a *free record* performance) SC3 1.4.5.b says that distance using up to three turnpoints is 'A flight from a START POINT via up to three TURN POINTS to a FINISH POINT.' Note that is says 'a START POINT', not 'the START POINT'. SC3 1.1.8 says a START POINT is either '(a) The RELEASE POINT, or (b) A WAY POINT declared as a START POINT, or (c) The midpoint of a START LINE.' Note that the pilot or data analyst can apparently choose between (b) and (c) after the flight, as I've never seen a declaration form (paper or electronic) that requires that you declare before the flight that you are using a start line as opposed to a start way point (with OZ). Being a computer programmer, I'd argue that the 'or' in clause (a) has the same logical precedence as the 'or' in clause (b). Therefore, if you have declared a start, it still seems to me that it would be valid to use any of the START POINT options, including the RELEASE POINT. Have you found a rule someplace else that would render this interpretation incorrect? Marc |
"Stewart Kissel" wrote...
It's starting to get a little gray now, to summarize... The rules are ambiguous, which is not at all surprising given their history. If u declare a Start Point...one can either use release or Start Point for initial altitude for penalty caluculation. It's more complicated than that. According to SC3 Annex C.3.5, "the start height and time may be selected after the flight from the *most favourable fix* within the OZ before crossing the start line or OZ boundary." This is in addition to SC3 1.4.7 which states that "A distance flight starting as defined in 1.1.8b (a declared START POINT) may be claimed where the LOSS OF HEIGHT is measured from the release height to the elevation of the finish point." And then you can compare this against altitude at Finish Point observation sector? Perhaps, but does "elevation of the finish point" above mean the actual ground level elevation, or the altitude of the finish point? SC3 is in serious need of a rewrite... Marc |
Marc Ramsey wrote:
SC3 is in serious need of a rewrite... It has been rewrited 5 years ago. But this has been done without changing any piece of rule (which was not in the power of the rewriter), thus it remains as complicated and often unlogical that is was before rewriting. The need is to reintroduce a bit of logic and common sense in the rules, then the rewriting should be easier (as would be the interpretation !) -- Denis R. Parce que ça rompt le cours normal de la conversation !!! Q. Pourquoi ne faut-il pas répondre au-dessus de la question ? |
Run up for plug clearing | Roger Long | Piloting | 78 | October 18th 04 03:39 AM |
ramifications of new TSA rules on all non-US and US citizen pilots | paul k. sanchez | Piloting | 19 | September 27th 04 11:49 PM |
For Keith Willshaw... | robert arndt | Military Aviation | 253 | July 6th 04 05:18 AM |
Ultralight Club Bylaws - Warning Long Post | MrHabilis | Home Built | 0 | June 11th 04 05:07 PM |
Winch Experts wanted | Ulrich Neumann | Soaring | 117 | April 5th 04 06:52 AM |
