#11
I got the self launch endorsement because my insurance required me to for
operating the DG-400...but it sure strikes me as odd that if you have an ASEL certificate...and a glider rating...that the combination of the two would not suffice...add to that a high-performance and taildragger sign off...and I never have understood what the self launch sign off was intended to accomplish. Maybe it's me, but it sure seems silly when you have pilots with both power and glider ratings. I can see the self launch sign-off if you only have a Glider certificate... Steve. |
On Tue, 07 Dec 2004 20:25:01 +0100, Stefan
wrote in :: I may be wrong, but I think the Stemme V10 is legally not a TMG. But is a remarkable piece of artistic engineering. http://www.stemme.de/ "The S 10-VT is the easiest to handle and most good-natured open class sailplane." The S8 is the TMG: http://www.stemmewest.com/pages/S8_E.pdf |
It seems like there's really only one thing to train an ASEL pilot
trainsitioning to self launch: if the engine quits on takeoff, then the extended engine is just a huge airbrake, so your glide ratio goes to poop and the pitch forces are changed. Recognise this and make your choice to turn back or go straight accordingly, not based on regular glide. I'm not self-launch endorsed, but other than this and the fact your engine is probably a $10,000 one cylinder chainsaw engine that causes double vision, I can't figure what is so different... flame away In article , Steve Hill wrote: I got the self launch endorsement because my insurance required me to for operating the DG-400...but it sure strikes me as odd that if you have an ASEL certificate...and a glider rating...that the combination of the two would not suffice...add to that a high-performance and taildragger sign off...and I never have understood what the self launch sign off was intended to accomplish. Maybe it's me, but it sure seems silly when you have pilots with both power and glider ratings. I can see the self launch sign-off if you only have a Glider certificate... Steve. -- ------------+ Mark J. Boyd |
Mark James Boyd wrote:
It seems like there's really only one thing to train an ASEL pilot trainsitioning to self launch: if the engine quits on takeoff, then the extended engine is just a huge airbrake, so your glide ratio goes to poop It's worse than having the engine retracted, but nothing like having the airbrakes extended. and the pitch forces are changed. Actually, the pitch forces don't change, but the glider does tend to pitch up a bit with power loss. Like a rope break, the pilot must put the nose down to maintain airspeed. Recognise this and make your choice to turn back or go straight accordingly, not based on regular glide. For my glider, and I think for most "engine on a stick" gliders, an extra 100' is _plenty_ over what the pilot would use for a turn-around height while towing. I'm not self-launch endorsed, but other than this and the fact your engine is probably a $10,000 one cylinder chainsaw engine Most of the self-launchers use a two cylinder engine. The Russia uses a single cylinder and probably has the most vibration; the ASH 26 E uses a single rotor wankel, and has the least vibration. Even the Russia, at about 28 horsepower, would make one heck of a macho chainsaw! that causes double vision, I can't figure what is so different... Perhaps the biggest difference is many of them will go up on their nose if full power is applied right at the start of the roll. Even if they don't, the reduced weight on the tail wheel can turn a cross-wind takeoff into a thriller. It only takes once to realize you need to be a little slower with the throttle at the start. Taxiing can be a challenge, since your "wheel track" is 25-30 feet wide, and you don't have differential braking to help you around the corners. Aside from these, and if the engine keeps running, it's easier than towing. -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
The Stemme is a TMG under German rules.
-- Bert Willing ASW20 "TW" "Stefan" a écrit dans le message de news: ... Marc Ramsey wrote: I may be wrong, but I think the Stemme V10 is legally not a TMG. The type category "Touring Motor Glider" does not exist in the US. I thought so. But the original poster lives in Germany, at least his name and email address point in this direction. And as he wrote that he would like to have the TMG rating, I think this question is of interest to him. Stefan |
Mark James Boyd Wrote:
" I'm not self-launch endorsed, but other than this and the fact your engine is probably a $10,000 one cylinder chainsaw engine" Well...I'm not sure if this is intended to be flippant or not...but I'll say my DG uses a two cylinder, dual CDI ignition, dual carburetor Rotax...about 505 cc's. The engine is very nicely mounted on isolation dampeners and really runs very smoothly, though it does have a slight harmonic in the 4,000rpm range you feel when you shut it down...I think the cost is easily considered as follows: this years 170 hours of soaring used 4.2 engine hours ( 21 gallons of super unleaded) If I'd average 3 three hours per flight that would be about 57 tows...say $30 a tow to be safe...around $1700 for the year...I'll leave out the 8 or 9 retrieves, when I either went straight out somewhere and landed, or simply got nailed and had to land somewhere...either way, retrieve costs could easily add up to a substantial cost, but I just started up and headed home...in my 700 hours of flying the DG-400 I have only had one very minor engine complication, self remedied, but trying to be unbiased. I would assert that the dollar per flight hour vs. freedom from tow lines and the benefit of going when and where I want is worth the minor investment and I believe it actually pays for itself over a 5 year period. My Stihl on the other hand..also has CDI igition AND mixes the fuel/oil for me...I sure wish the DG did that. Steve |
"Larry Dighera" wrote in message ... On Tue, 07 Dec 2004 20:25:01 +0100, Stefan wrote in :: I may be wrong, but I think the Stemme V10 is legally not a TMG. But is a remarkable piece of artistic engineering. http://www.stemme.de/ "The S 10-VT is the easiest to handle and most good-natured open class sailplane." The S8 is the TMG: http://www.stemmewest.com/pages/S8_E.pdf I know nothing about Gliders but I went and looked at the PDF document above. CS prop, retractable gear, 170 knots. That is impressive. My question. Can it be flown by a PP-SEL or do you have to have a glider rating? |
Steve (and others),
I put a tag for "flame suit on" and a winkey face under this comment, but it didn't make it to the post. C'mon, you know I love you engine lovers. I have an engine myself (well, a continental A-75). Sorry if I offended, Can I be in the club again? ![]() In article , Steve Hill wrote: Mark James Boyd Wrote: " I'm not self-launch endorsed, but other than this and the fact your engine is probably a $10,000 one cylinder chainsaw engine" Well...I'm not sure if this is intended to be flippant or not...but I'll say my DG uses a two cylinder, dual CDI ignition, dual carburetor Rotax...about 505 cc's. The engine is very nicely mounted on isolation dampeners and really runs very smoothly, though it does have a slight harmonic in the 4,000rpm range you feel when you shut it down...I think the cost is easily considered as follows: this years 170 hours of soaring used 4.2 engine hours ( 21 gallons of super unleaded) If I'd average 3 three hours per flight that would be about 57 tows...say $30 a tow to be safe...around $1700 for the year...I'll leave out the 8 or 9 retrieves, when I either went straight out somewhere and landed, or simply got nailed and had to land somewhere...either way, retrieve costs could easily add up to a substantial cost, but I just started up and headed home...in my 700 hours of flying the DG-400 I have only had one very minor engine complication, self remedied, but trying to be unbiased. I would assert that the dollar per flight hour vs. freedom from tow lines and the benefit of going when and where I want is worth the minor investment and I believe it actually pays for itself over a 5 year period. My Stihl on the other hand..also has CDI igition AND mixes the fuel/oil for me...I sure wish the DG did that. Steve -- ------------+ Mark J. Boyd |
Offended...?? Me..?? man...I got WAY thicker skin than that....you'd have to
be talking about my mama...to offend me...I know...I know...when she sits around the house....she REALLY sits around the house.... Nah...I just thought I'd set the record straight about my chainsaw engine...oops...self launcher... Ciao for now. Steve. |
Gig Giacona wrote:
"The S 10-VT is the easiest to handle and most good-natured open class sailplane." The S8 is the TMG: http://www.stemmewest.com/pages/S8_E.pdf I know nothing about Gliders but I went and looked at the PDF document above. CS prop, retractable gear, 170 knots. That is impressive. My question. Can it be flown by a PP-SEL or do you have to have a glider rating? In the USA, you need a glider rating with a self-launch enddorsement. Other countries treat it quite differently. -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
| Thread Tools | |
| Display Modes | |
| API - San Diego. Approach gremlin mortally wounded... | Beav | Rotorcraft | 0 | October 14th 04 01:17 AM |
| Military jet crashes in San Diego Bay | Otis Willie | Military Aviation | 0 | August 28th 04 01:24 AM |
| What is carrier beside USS John C. Stennis (CVN 74) at San Diego ? | Dong | Military Aviation | 7 | January 9th 04 07:58 PM |
| San Diego Pilots Yahoo Group | mutts | Piloting | 0 | October 28th 03 03:32 AM |
| Good instrument program near San Diego? | [email protected] | Instrument Flight Rules | 1 | October 26th 03 04:59 AM |
