Excel Formula minutes convert to hours
Old December 13th 04, 07:40 PM
Andy Blackburn
Go to the menu item Format Cells
Select the Custom Category (at the bottom of the menu
on the left)
Type the following into the 'Type' box in the upper
right of the dialog:
[h]:mm;@
This will give you the standard flight log format -
hhh:mm (no seconds)
This works in Excel 2003 - but I don't think the formats
have changed much if at all since Excel '97
9B
At 19:00 13 December 2004, Marc Ramsey wrote:
Wayne Paul wrote:
Using the format Category of 'Time' and the Type '37:20:55'
I entered 12:22,
14:38, 72:14 and the above mentioned 45:36. Summing
this column gave an
accurate total of 144:50:00.
What version of Excel are you using?
I tried this in Excel 97 (I'm too cheap to upgrade).
The key seems to
be using the '37:30:55' time format in the Format Cells
dialog. If any
other time format is used, the values are interpreted
as time of day,
and wrap around at 24 hours.
Marc
Old December 14th 04, 12:04 AM
Peter Seddon
"Andy Blackburn" wrote in message
on the left)
[h]:mm;@
hhh:mm (no seconds)
9B
I entered 12:22,
this column gave an
The key seems to
dialog. If any
as time of day,
Marc
That one works a treat;-)
Peter.
Old December 15th 04, 08:14 PM
tango4
Using later versions of Excel highlight the column that you will use for
your time entries and then select the format of that column ( Format /
Cells ) as 'Number' and select 'Custom' in the list box. In the 'type' box
enter [hh]:mm ( where 'general' is displayed )
The column will now total properly. ie
14:00
15:00
10:00
=39:00
You have to enter hours as X: ie with the colon otherwise X is interpreted
as X days - this can be picked up visually since the cell will display 24 *
X if you enter just the X.
minutes must be entered as 0:mm ie: with the leading zero otherwise the
entry is simply ignored.
Ian
Old December 15th 04, 09:43 PM
Peter Seddon
"tango4" wrote in message
box enter [hh]:mm ( where 'general' is displayed )
14:00
15:00
10:00
=39:00
* X if you enter just the X.
Ian
Yes I used that system and now my log book is workin perfectly on excel.
Peter.
millionaire on the Internet... in weeks! Malcolm Austin Soaring 0 November 5th 04 11:14 PM
Excel formula for logbook Wizard of Draws Instrument Flight Rules 11 August 30th 04 12:55 AM
AmeriFlight Crash C J Campbell Piloting 5 December 1st 03 02:13 PM
