Lithium technology batteries
Old December 19th 04, 11:05 PM
John Giddy
On Sun, 19 Dec 2004 19:09:49 +0000 (UTC), tango4 wrote:
"WilLiscomb" wrote in message
voltage regulator
williscomb
Hmmmm
Build a 'better' battery so that you can dump power into a voltage
regulator. Cute.
Actually the forward biased semiconductor junction in the form of a diode is
a much easier way to do things.
Ian
Only problem is that the voltage drop is also present at the
end-of-charge point, thus losing the last 0.7v of possible battery
voltage before things start working strangely.
If you use a well designed switching regulator which can boost as well
as buck, the voltage supplied to the instruments can be maintained in
the ideal range until the battery is almost completely flat, and at an
average efficiency of about 80%. AFAIK, complete discharge is not
harmful to NiCd, Lithium types etc. It is harmful to lead acid
batteries.
Cheers, John G.
Batteries, charger for Yaesu handheld - NiCad or NiMH? David Herman Owning 10 November 7th 04 05:30 PM
Disruptive Technology Steelgtr62 Home Built 13 October 24th 04 08:32 PM
USA India Dual Use Technology Transfers Ravi V Prasad Military Aviation 2 April 13th 04 10:21 PM
Soviet State Committee on Science and Technology Mike Yared Military Aviation 0 November 8th 03 11:45 PM
Science, technology highlighted at hearing Otis Willie Military Aviation 0 July 23rd 03 11:30 PM
