water wing tank venting
Old January 4th 05, 03:37 AM
Hi Udo,
Yes, the Zuni has a vent line running from the outboard end of the
tank, back through the tank, and exiting the bottom side of the wing,
near the leading edge, ahead of the dump hole. This is not exactly as
you had asked about, but very similar. It does provide good venting of
the tank. It does have a drawback in that if the tanks are full and
the plane is slightly wing low (sitting with the wing wheel on, for
example), water will tend to siphon from the low wing out the vent
hole. This vent is about 5/16th diameter on my Zuni.
Also, the HP-18 built by my father, Robert Leonard, and now owned by my
brother, Ron Leonard, has a vent tube running the length of the wing.
It also exits the underside of the wing, but near the trailing edge,
just outboard of the root rib. I believe this vent tube is 1/2 inch
tygon tubing. His dump system comes out of the stock Schreder dump
port on the front face of the spar, goes through a 90 degree elbow to
go outboard, through a dump valve, and exits through the bottom of the
wing, one or two foam ribs outboard of the root rib. The intent of
this system was to keep the water plumbing all in/on the wing. That
way, there would be no leaks into the fuselage.
When building this HP-18, he had considered adding an extra ballast box
in the first bay ahead of the spar. His plan was to put an isolation
valve on this tank so he could either fly with half water (fill the
spar only) or full water (by openning the valve and filling both
tanks). He decided against this, and just stuck with the stock water
capacity. Is this similar to what you are planning to do, but with one
tank ahead of and one behind the spar?
But, yes. Vents back to the root do work. Oh, yes. You can set a wing
down and not worry about loosing your water! But you will fill the
vent lines and then drain at least part of that water overboard when
you level the wings for takeoff.
If you do tie all vents to a common manifold, you wil probably not be
able to be assured that you will not get some water into a tank you did
not fill. Amount would likely be vent line volume. Maybe a bit more
or less, depending on how you fill the system. My suggestioin would be
to keep each tank vent seperate.
Steve Leonard
Zuni II
HP-14
Too many others to mention ;-)
Old January 4th 05, 05:24 AM
Udo Rumpf
Steve,
I should maybe manifold all three lines at the turtle deck that would
prevent siphoning.
I believe also the 5/16" vent tube will be enough, as each tank is
relatively
small and all will have a separate dumb valve.
The centre tank is 2 x 8 gal. front 2x 6 and the back 2x5gal.
I was planning on placing the valves in the front and back tank
and stay with a standard 2 ball valve set-up for the spar tank.
Tank you
Udo
Old January 5th 05, 01:15 AM
Udo Rumpf wrote:
Steve,
prevent siphoning.
Now that I think about it a bit more, it is not so much siphoning, as
simply draining. With the wing low enough that the water is up to the
level of the vent at the outboard end of the tank, and the exit point
of the vent tube from the aircraft is below the water level in the
tank, it will simply drain. I suspect there is a point in the vent
tube that goes above the water level in the tank when it is sitting
with one wing level with the ground.
I think if you just keep them above the level of the water in the tank,
it should be OK. Manifolded together, or individually. I would make
sure it is either outside the airplane or in an area that can drain, as
if you tow the ballasted glider around a corner, you will likely push
some water into the vents, even if it was level to start with.
Steve
Water Cooled Jet Engines: a possibillity then and now? The Enlightenment Military Aviation 3 December 18th 03 10:41 AM
ASW27 Wing water tank Ray Gimmey Soaring 0 November 10th 03 11:35 PM
Yo! Fuel Tank! Veeduber Home Built 15 October 25th 03 03:57 AM
Props and Wing Warping... was soaring vs. flaping Wright1902Glider Home Built 0 September 29th 03 04:40 PM
#1 Jet of World War II Christopher Military Aviation 203 September 1st 03 04:04 AM
