How long before /G required for IFR?
Old February 26th 05, 08:27 PM
Colin W Kingsbury
news
"Dan Thompson" wrote in message
. com...
This is an old horse and I almost hate to bring it up again, but are you
aware you can legally accept direct FUBAR as a /U under IFR, and monitor
your progress with a handheld GPS?
It is a sad day that people now assume clearance direct to an intersection
can only be complied with if you have some sort of RNAV. Makes me wonder
how
we ever did it in the '70s with only a VOR and a TACAN.
Pray enlighten me to one thing- let's say I'm on V123 and cleared direct to
FUBAR which is defined by the intersection of V456 and V789. Leaving out the
legal-vs-practical debate, there is no way for me to navigate from my
present position to FUBAR in a straight line sans RNAV. It's always been my
understanding that "direct" means they assume you will in fact go straight
there, not turn left 20 degrees, intercept V456, and then head to FUBAR. Am
I missing something here?
-cwk.
Old February 27th 05, 02:10 AM
Ron Rosenfeld
On Sat, 26 Feb 2005 19:27:47 GMT, "Colin W Kingsbury"
The old (pre 1996) USAF manual AFM 51-37 had a technique which could be
used to do that. And USAF pilots were trained in that technique. However,
I am told the current manual no longer discusses this method, it having
been replaced with INS, RNAV, GPS, etc.
Old February 27th 05, 03:19 AM
Roy Smith
Sure there is. Get a position fix (VOR-VOR radial cross, VOR-DME, DME-DME,
NDB-NDB bearing cross, GPS, Loran, Omega, Celestial, whatever). Plot that
fix on a chart, measure the bearing from your current position to your
destination, adjust for estimated wind, and fly the heading indicated.
Take additional fixes along the way to correct your heading as required.
It takes a bit of work (possibly more work that is practical single-pilot
IFR in a typical GA cockpit), but it's certainly possible. Depending on
what equipment you've got, there may well be better methods than what I've
described. Knowing how to do it is the difference between being a
navigator and being a button pusher.
Like Colin, I'm going to bypass the legality question completely, but
there's no doubt that it's possible to do.
Old February 27th 05, 09:07 AM
C J Campbell
"Colin W Kingsbury" wrote in message
ink.net...
news
. com...
you
monitor
intersection
how
to
my
Am
The Air Force has written all kinds of instrument and navigation manuals
which you can download. They are considerably modernized from my day, but
all the old information is still there. An example may be found he
http://www.e-publishing.af.mil/pubfi...fpam11-216.pdf.
An MB-4 Computer is the Air Force version of the E6-B. From the Air Force
AFPAM 11-216 "Navigation Procedures:"
5.16. Fix-to-Fix Navigation (Using the MB-4 Computer). A fix-to-fix can also
be computed on the
wind face side of an MB-4 computer. First, give the pilot a general heading
toward the fix. (NOTE: You
can work in bearings; however, all work must be done in either bearings or
radials to compute the
solution.) For the following example, radials will be used. The fix you wish
to navigate to is the 280o
radial at 30 DME. Set up a graphic depiction on the wind face side of your
computer with your present
position (350o radial at 050 DME) and the desired fix (280o/030). Use the
following steps:
5.16.1. Place your present position (350o/050) on the wind face side using
the square grid at the bottom
of the MB-4. Align 350o on the compass rose under the true index. Mark the
point by counting down 50
NM from the true airspeed (TAS) grommet and mark with a +. Use the scale set
up on the square grid or
set up an applicable scale. The scale used must remain constant throughout
the problem (Figure 5.13).
5.16.2. Place the fix radial and DME (280o/030) on the computer the same way
you did in step one
(Figure 5.14). Mark as a fix symbol (?).
5.16.3. Determine the no wind heading by rotating the compass rose so that
the present position (+) is
directly above the fix (?). Use the square grid at the bottom to help with
alignment (Figure 5.15). Turn
the aircraft to MC under the true index (206o for this example) and kill the
drift. (NOTE: You can place
your present position (+) on the 0 NM horizontal baseline then, using your
NM increment scale, count
down to the fix position (?) to determine how far you are from the fix (48
NM in this example; Figure
5.15.)
5.16.4. Repeat the procedure as necessary to keep your progress updated.
Old February 27th 05, 09:11 AM
C J Campbell
way
you did in step one
OK, you can't make the little delta shaped fix symbol on USENET, so it
substituted the question mark. It also converted 280 degrees to 280o. The +
sign worked, at least.
Old February 26th 05, 08:29 PM
Colin W Kingsbury
. com...
Yeah, well aware of it, and in my neighborhood (New England) you're usually
operating under radar and on airways anyway. My point was more that it
seemed as though ATC was simply starting to expect everyone to have GPS.
Old February 26th 05, 09:17 PM
Dan Thompson
What it is, is ATC expects everyone to be able to navigate direct, one way
or another.
ink.net...
. com...
usually
Old February 26th 05, 09:28 PM
Steven P. McNicoll
. com...
or another.
I don't expect everyone to be able to navigate direct, but I do expect
everyone to be able to navigate what they file. It isn't unusual for
someone to file direct to a distant point, accept their clearance "as filed"
and an instruction to proceed "on course" or "direct" to that distant point,
and then to request vectors to it after departure.
Old February 27th 05, 03:37 AM
Chip Jones
. com...
or another.
Well, not all of ATC. I expect you to be able to fly your filed route on
own navigation. I don't expect you to be able to proceed direct unless you
file the appropriate equipment suffix, file point to point direct, or you
ask me for direct somewhere en route. I agree that some controllers don't
know what in the hell they are doing these days, but that's because the FAA
dumbed down training after 1992 and let PC run amok. We're in the process
of fixing that right now though.
Chip, ZTL
Old February 27th 05, 05:06 AM
Newps
Yep, you're getting all the AFSS guys that will be, ah, surplussed.
Christmas Annual - long drivel Denny Owning 23 December 31st 04 09:52 PM
Does China have long range bombers? Mike Military Aviation 10 May 24th 04 03:16 AM
SWRFI Pirep.. (long) Dave S Piloting 19 May 21st 04 04:02 PM
making the transition from renter to owner part 1 (long) Journeyman Piloting 0 April 13th 04 03:40 PM
First flight with my wife! (long) Wily Wapiti Piloting 8 August 30th 03 06:57 PM
