Yes, I do think you hit the proverbial nail on the head when you said I
should keep in mind the word "conservative" when dealing with the FSDO folks. ![]() And yes, the turbine issue is the catch. 8130.2F is, IMO, not really designed for homebuilt turbine-powered aircraft. Again, the FAA is behind the curve. What can I say. This is one of many areas where the agency is reactive, rather than proactive. Thanks for the info! Juan "Bob Korves" bkorves@winfirstDECIMALcom wrote in message ... I fly a racing sailplane under Exp/Exh and it has not been a problem at all. Actually, this is the second glider I have owned that is Exp/Exh. The first one was built in the early '80's and was very generous WRT operating limitations. The current one, bought new in 2001, was still pretty lenient WRT operating limitations. This was after the fall of the Soviet bloc and the importing of military aircraft had become a bit of a problem, making the FAA more nervous. The FSDO came out to the local airport to look at the aircraft and its paperwork. My partner and I gave him our program letter stating the events that we _PLANNED_ to attend. We listed our bases of operation (all the gliderports in three states that we might ever fly out of). He offered us a flight radius of 300 nm from our 'bases'. We countered that we would be attempting SSA badge and record flights that may go father than that regularly and were able to get the radius increased to 500 nm. He told us that if we wanted to fly from other bases or farther than the 500 mile radius that we could fax a note to the FSDO explaining what we were planning to do. The only part of our Exp/Exh certificate that could be much of much concern is the prohibition from flying over congested areas. We are able to do all the repairs and minor modifications to the aircraft that we wish. We need an A&P to sign off the annual condition inspection. For single seat aircraft that will not be flown over urban areas, Exp/Exh is a good way to go. Our insurance company has been fine with it, too. For more than one seat or flying in and out of large airports in big cities you may have a problem. Insurance companies may have a problem with it , too. Experimental/amateur built would of course be better, if it is possible. Juan, I think the source of your problem is a turbine engine. The FAA relates turbine Exp/Exh to Mig 15/17's and a F-86 burning in a ice cream parlor. Make sure that you understand the meaning of "conservative" when you deal with them. -Bob Korves "Juan Jimenez" wrote in message ... "Bob K." wrote in message ups.com... Earlier, Juan Jimenez wrote: ...For example, 8130.2F says that you must provide a letter stating all air shows and other exhibition activities, including "static displays" in which the aircraft will participate, and lists the letter as a mandatory requirement. However, it doesn't say what happens when no plans have yet been made to attend any exhibition activities... Ah, the infamous "program letter." My suggestion would be to talk to the kinds of people who routinely file program letters and have no problems with them at all: competition sailplane pilots. There are probably more than a thousand European competition sailplanes in the US being operated on Experimental/Exhibition or Experimental/Racing certificates, and I've heard of very few complaints about their operating limitations or program letters. Interesting, I hadn't thought of that. I will look into that. Thanks! I think that the most common approach is to include on the program letter any contest or event that you might possibly attend, and then add some extra verbiage about proficiency flights. Kinda hard to do that when you're sitting on an island in the Caribbean more than 1k miles from the nearest airshow, and the plane doesn't have anywhere near the range to get there. ![]() If you search rec.aviation.soaring on the phrase "program letter" you'll find a lot of general advice, but probably few concrete examples of complete program letters. I think what I will do is state that I have no plans as of yet to attend any specific airshows because there are none on the island, but I am pursuing sponsors, will do static displays and perhaps some solo flybys over the beach to entertain people. ![]() Thanks, and best regards to all Bob K. http://www.hpaircraft.com/hp-24 Thanks for your help! ![]() Juan |
On Fri, 31 Dec 2004 16:42:54 -0400, "Juan Jimenez"
wrote: Again, the FAA is behind the curve. What can I say. This is one of many areas where the agency is reactive, rather than proactive. Now you're talkin'! Sounds like it's time for a scathing editorial! The Feds will wise up pronto, and the all new, clarified rule is bound to be named in your honor. But if the first critique doesn't humble a few FSDOs, then you should blast them annually. Geez, I can't believe Zoom doesn't tell you this stuff. Wayne |
