![]() Is it correct to say that the consensus standards do not apply, when i t is a plans built? How about kit meeting 51% self built rule? I'm still not exactly sure I understand what an experimental LSA is, a nd what hoops must be jumped through. -- Jim in NC An ELSA is simply an SLSA that has been pulled off the production line at whatever point the customer wants. The customer then finishes the planes following the EXACT factory instructions but it must be identical to the SLSA. All factory parts and no modifications at all. It is subject to the same maintaince ect requirements as SLSA but can not be used for instruction or rental. Sorry, but you didn't catch what I asked. What about the plans built, or one that has no assembly, at all? What about the guy that designs one (one off) that fits under the specs of the rule? -- Jim in NC |
![]() Morgans wrote: Is it correct to say that the consensus standards do not apply, when i t is a plans built? How about kit meeting 51% self built rule? I'm still not exactly sure I understand what an experimental LSA is, a nd what hoops must be jumped through. -- Jim in NC An ELSA is simply an SLSA that has been pulled off the production line at whatever point the customer wants. The customer then finishes the planes following the EXACT factory instructions but it must be identical to the SLSA. All factory parts and no modifications at all. It is subject to the same maintaince ect requirements as SLSA but can not be used for instruction or rental. Sorry, but you didn't catch what I asked. What about the plans built, or one that has no assembly, at all? What about the guy that designs one (one off) that fits under the specs of the rule? Jim, If it is a plans-built or a "one-off" design (I guess that would be "plans built" too), forget about sLSA or eLSA. The type of aircraft that you are describing would be built and certified under the existing experimental/amateur-built rules and so long as it met the Sport Aircraft specs (stall speed, gross weight, maximum level speed, etc), a pilot could fly it with a Sport Pilot license (no medical). Rick Pellicciotti |
On Mon, 3 Jan 2005 20:21:43 -0500, "Morgans" wrote:
An ELSA is simply an SLSA that has been pulled off the production line at whatever point the customer wants. The customer then finishes the planes following the EXACT factory instructions but it must be identical to the SLSA. All factory parts and no modifications at all. It is subject to the same maintaince ect requirements as SLSA but can not be used for instruction or rental. Sorry, but you didn't catch what I asked. What about the plans built, or one that has no assembly, at all? What about the guy that designs one (one off) that fits under the specs of the rule? Rick gave you the right answer, but let me have a crack at clarifying this. The basic confusion here is over the term, "Light Sport Aircraft." IHMO, the developers of the new rules made a mistake here, as they use the same term for two separate, but related, concepts. The first is that of "Light Sport Aircraft" as a definition. The regulation changes added this definition to 14CFR Part 1...what us'n old timers would call FAR Part 1. In Part 1, an LSA is an aircraft that has a gross weight of 1320 pounds or less, a stall speed less than 52 MPH, a flat-out level flight top speed of 138 MPH or less, etc. A person with a Sport Pilot license, or someone with a Primary, Private, Commercial, or ATP license with an honorably lapsed FAA medical (e.g., a valid medical that expired and was not revoked or renewal denied), can fly an aircraft that meets the LSA definition. This airplane can be licensed in ANY Category... Normal, utility, primary, experimental, restricted, limited, etc. The only exceptions I can think if is if a given aircraft has a set of operating limitations assigned by the FAA that require a minimal set of pilot qualifications. So, that's LSA as a definition. The FAA also instituted a *certification category* called "Special Light Sport Aircraft," and added a new sub-category to "Experimental" called "Light Sport Aircraft." There are two basic kinds of Airworthiness Certificate. There is the 'Standard' category. Once an aircraft receives a certificate in the Standard category, the owner can operate the aircraft with no more attention from the FAA. A Standard category aircraft can be flown for pleasure, rented, leased, or carry passengers for hire with no additional involvement from the FAA other than the operator ensuring the appropriate FARs for the type of operation be followed.. Standard category includes "Normal" category, "Utility," "Aerobatic," "Commuter," and "Transport." Each aircraft in these categories is assumed to be airworthy as long as the appropriate inspections verify that the aircraft still meet the description of its type certificate. The other basic kind of Airworthiness is the "Special" category. The Special category exists to allow aircraft that do not necessarily meet the requirements of the Standard category to be operated to perform specific tasks. This category includes Restricted, Limited, Experimental, and, now, the Light Sport Aircraft category. The Light Sport Aircraft category under the "Special" category (hence, "Special Light Sport Aircraft") was created to allow production of ready-to-fly small aircraft without requiring the level of design verification that Standard category requires. To be produced on a Standard certificate, you have to meet the FARs...and SLSAs do NOT meet the "regular" FARs. The FAA is allowing the industry itself to define the amount of testing and validation necessary for a SLSA airworthiness certificate. The only things the FAA requires is that the aircraft produced must meet the FAR Part 1 definition of an LSA, that the industry agree on the requirements *all* SLSA aircraft must meet (e.g., the consensus standards), and that every occupant of a SLSA aircraft be advised that the airplane does not meet FAA certification requirements. In other words, all SLSA aircraft must include the same kind of "Passenger Warning" that our homebuilts carry. So, that's the production-type LSAs. As the development of the Special Light Sport Aircraft category was ongoing, some consideration was paid to the potential to sell kits of these SLSAs. The FAA was amenable...but the SLSA category was designed to place the entire onus on compliance with the consensus standards on the kit manufacturer. It was certainly possible to require the manufacturer to inspect a customer-built aircraft prior to certification (there have been kits of Standard category aircraft), but something closer to traditional homebuilding was wanted. Hence, the developers added a new sub-category under the Experimental category. Where there was Racing, Market Survey, Amateur-Built, etc, the FAA added a new sub-category for homebuilt Light Sport Aircraft: Experimental/Light Sport Aircraft (ELSA). Note that this was a *new* category under Experimental. It did not replace Amateur-Built; it is not something that was merged under the Experimental Amateur-Built sub-category. It is *entirely* separate, like Experimental/Racing or Experimental/Research and Development category aircraft are. Hence, traditional homebuilding is completely unaffected. BUT...if a homebuilder constructs an airplane that meets the FAR Part 1 definition of an LSA, it can be flown by a Sport Pilot. But unless it meets the specific requirements of the Experimental Light Sport Aircraft category, it cannot be licensed as a ELSA. It *can* be licensed as an Experimental Amateur-Built aircraft, just like always. But, let's look at this a different way. Let's say that I want to license a Fly Baby in the Experimental Light Sport Aircraft category. That'll let me do all my own maintenance, and, after taking a 16-hour course, I'll be able to sign off the annuals, too. First off, I *cannot* relicense my existing Fly Baby. The regs do NOT allow relicensing existing N-numbered aircraft as either Special or Experimental Light Sport Aircraft. So I gotta build a new one. But to get a plane into the Experimental Light Sport Aircraft category, I have to first certify a prototype as a SLSA. In other words, I have to go through the ENTIRE CERTIFICATION PROCESS for a production LSA. I have to perform the analysis/testing to verify that the design meets the required load factors (+4G, -2G, 1.5x factor of safety, with an additional factor of safety on critical components). I have to select an engine that meets the engine section of the consensus standards (since it's single-seat airplane, I only need a single-ignition engine). I have to build the aircraft in conformance with the quality control standards (which means a formal QC process), and develop the appropriate system for tracking airworthiness problems over the years. I have to write up an affidavit that certifies that the airplane I built meets the consensus standard, and have the aircraft safety-inspected by a DAR. As of that point, my Fly Baby has a SLSA certification. I can duplicate the building effort and produce ready-to-fly aircraft, or I can *truncate* the building process and sell kits. These kits can be sold at any level of completion...no 51% rule. The builder of the kit has to *exactly* follow the detailed assembly manual that I'm required to write. And at the end, they can get their planes licensed as ELSAs. But what about me? After I license my SLSA Fly Baby, I can voluntarily downgrade it to an ELSA. At which point I can take that 16-hour course and get the LS-I Repairman Certificate that allows me to perform ELSA annual inspections. A lot of work, right? Instead of going through all the SLSA certification stuff, I could have just licensed the durn thing as an Experimental/Amateur-Built and applied for the "regular" Repairman Certificate that would allow me to perform that annual anyway. The upshot is: If you are a traditional homebuilder, don't worry about the SLSA or ELSA certification standards. If your plane meets the FAR Part 1 Definition, you'll be able to fly it as a Sport Pilot without having to conform to consensus standards, etc. Ron Wanttaja |
![]() The upshot is: If you are a traditional homebuilder, don't worry about the SLSA or ELSA certification standards. If your plane meets the FAR Part 1 Definition, you'll be able to fly it as a Sport Pilot without having to conform to consensus standards, etc. Ron Wanttaja Nice write-up Ron! John |
Homebuilt Aircraft Frequently Asked Questions List (FAQ) | Ron Wanttaja | Home Built | 40 | October 3rd 08 03:13 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | October 1st 04 02:31 PM |
Homebuilt Aircraft Frequently Asked Questions List (FAQ) | Ron Wanttaja | Home Built | 0 | September 2nd 04 05:15 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | May 1st 04 07:29 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 2 | February 2nd 04 11:41 PM |
