Hahaha...
I'l try this in the 2-33 at Vne (about 80 knots) and see if I get over 200 ft 'regained' I doubt it. But then again, that's maybe off topic. I think your calculations are for gliders that don't fly like they have a parachute attached to the back, right? ![]() I'm sure even the Blanik will get numbers fairly close to what you write, but I'lll give it a go (at altitude). Passengers love to 'zoom' so this should be fun... At 06:30 27 March 2005, Bruce Hoult wrote: In article , M B wrote: It occurs to me that if someone is on final glide at the end of a competition, they may pick a speed (like 85 knots) which their computer says is optimal for points, but which is both: 1) too fast for a rolling finish/landing and 2) too slow for a pull up, turn around, and landing. Is that an accurate assessment? Would a competition pilot be put in a situation where he must decide between points and safety of the landing? It seems to me that 85 knots is a little too slow to do a full circuit from, but plenty do do a 180, or a 360, or an abbreviated circuit similar to a rope-break exercise. Someone gave a figure of 9 ft of pullup for each knot of speed. That's about right for speeds around 110 knots, but is a gross overestimate for speeds around 80 or 90 knots (and an underestimate for higher speeds). The true numbers are quadratic. If you want a rule of thumb I suggest the following: take speed in knots, double it, drop off the last digit, square what is left giving height for a pull-up in feet. This calculation gives just over 90% of the theoretical maximum pull-up, which is proabably not a bad figure taking into the drag loses. Note that this is for a pull up to a zero speed hammerhead. For a pull up to flying speed you need to subtract the appropriate height for your circuit speed e.g. 100 ft for 50 knots. examples, from zero-height finish, 50 knot circuit speed: 50 knots - 100 - 10, squared = 100 ft gain, 0 ft AGL @ 50 kt 60 knots - 120 - 12, squared = 144 ft gain, 44 ft AGL @ 50 kt 80 knots - 160 - 16, squared = 256 ft gain, 156 ft AGL @ 50 kt 90 knots - 180 - 18, squared = 324 ft gain, 224 ft AGL @ 50 kt 100 knots - 200 - 20, squared = 400 ft gain, 300 ft AGL @ 50 kt 120 knots - 240 - 24, squared = 576 ft gain, 476 ft AGL @ 50 kt 150 knots - 300 - 30, squared = 900 ft gain, 800 ft AGL @ 50 kt A pull up from 85 knots to 50 knots will give you about a 200 ft height gain, plus whatever height your finish was at. We give students rope breaks at 200 ft, right? So a competent and alert pilot should have no trouble deciding whether to land straight ahead after the pull up or do an abbreviated circuit. -- Bruce | 41.1670S | \ spoken | -+- Hoult | 174.8263E | /\ here. | ----------O---------- Mark J. Boyd |
At 02:00 27 March 2005, Bill Daniels wrote:
The wing drop thing is easy to judge. Just watch the ailerons. If they don't start to move until the wing hits the ground or nearly so, it's pilot error. If they move to the stop as soon as the glider tilts a tiny bit yet the wing still goes down, he gets a pass. Any good instructor, towpilot, or any good pilot for that matter, can watch a takeoff and get a good idea of how well a pilot flies. I'd be surprised if you'd see many examples of reactions that slow on the contest circuit. In my experience 90+% of wing drops happen despite full opposite controls. A really experienced pilot will hold off on control input until he has enough speed, otherwise the downward deflection of the aileron will increase the angle of attack and stall the tip. So sometimes it's best to wait until the wing is nearly on the runway. In this test you'd flunk the pilots who are really inattentive as well as the ones who are really experienced. I wish it were simple. 9B |
![]() "Andy Blackburn" wrote in message ... At 02:00 27 March 2005, Bill Daniels wrote: The wing drop thing is easy to judge. Just watch the ailerons. If they don't start to move until the wing hits the ground or nearly so, it's pilot error. If they move to the stop as soon as the glider tilts a tiny bit yet the wing still goes down, he gets a pass. Any good instructor, towpilot, or any good pilot for that matter, can watch a takeoff and get a good idea of how well a pilot flies. I'd be surprised if you'd see many examples of reactions that slow on the contest circuit. In my experience 90+% of wing drops happen despite full opposite controls. A really experienced pilot will hold off on control input until he has enough speed, otherwise the downward deflection of the aileron will increase the angle of attack and stall the tip. So sometimes it's best to wait until the wing is nearly on the runway. In this test you'd flunk the pilots who are really inattentive as well as the ones who are really experienced. I wish it were simple. 9B Depends on where "enough speed" occurs. I think most gliders will have at least some aileron control at 12 Kts IAS or so. I've watched gliders reach 15-20 knots groundspeed and the ailerons didn't move until the wing touched the ground. I think experienced pilot/observers can tell when a pilot is waiting for the ailerons to get a grip on the air. In the event of an actual test, the pilot could brief the observer that his particular glider needs a non-standard technique and the observer would make allowances for it. Whenever I've made a fully ballasted takeoff in my N2C, I've carefully briefed both the wing runner and the tow pilot (as well as the peanut gallery who wanted to see a glider take off with 600 pounds of ballast.) So far, I haven't dropped a wing. Bill Daniels |
At 03:00 27 March 2005, Jack wrote:
Andy, I was not implying that anyone is stupid. I would never do that, either. I was trying in my poor manner to suggest that I was a knucklehead for flying at all. Gotcha - we were making basically the same point with different wording. Smart, competent pilots can get into trouble because they don't recognize that their normally inconsequential decisions can have potentially adverse consequences under slightly different circumstances. Tolerances can accumulate in the wrong direction on any given day. Medication + dehydration + lack of sleep + windy day can make you a hazard, but any one or two of these might not. The important thing is to recognize it. 9B |
A pull up from 85 knots to 50 knots will give you about a 200 ft height gain, plus whatever height your finish was at. We give students rope breaks at 200 ft, right? So a competent and alert pilot should have no trouble deciding whether to land straight ahead after the pull up or do an abbreviated circuit. Bruce's numbers are a pretty accurate rule of thumb. In an earlier thread there was some doubt expressed as to whether these 'theoretical' numbers can be achieved in flight. I took a look at some flight logs and found most of the time you convert into height ~90% of your kinetic energy (+/- the accuracy of my logger). There was one pull up where I only got 75% and one case where I got 100% (!). Best not to count on getting every last inch. I wouldn't recommend anyone try a pull up into a pattern unless they had confidence they were going to have at least 120 knots on the deck. I also fly my patterns a bit faster than 50 knots. 9B |
Andy Blackburn wrote: Bruce's numbers are a pretty accurate rule of thumb. In an earlier thread there was some doubt expressed as to whether these 'theoretical' numbers can be achieved in flight. I took a look at some flight logs and found most of the time you convert into height ~90% of your kinetic energy (+/- the accuracy of my logger). There was one pull up where I only got 75% and one case where I got 100% (!). Best not to count on getting every last inch. Agreed, and thanks for the confirmation. Could headwind account for the 100% example? And tailwind for the 75%? In other words, your airspeed was not the same as your ground speed? -- Bruce | 41.1670S | \ spoken | -+- Hoult | 174.8263E | /\ here. | ----------O---------- |
![]() "Bruce Hoult" wrote in message ... In article , Andy Blackburn wrote: Bruce's numbers are a pretty accurate rule of thumb. In an earlier thread there was some doubt expressed as to whether these 'theoretical' numbers can be achieved in flight. I took a look at some flight logs and found most of the time you convert into height ~90% of your kinetic energy (+/- the accuracy of my logger). There was one pull up where I only got 75% and one case where I got 100% (!). Best not to count on getting every last inch. Agreed, and thanks for the confirmation. Could headwind account for the 100% example? And tailwind for the 75%? In other words, your airspeed was not the same as your ground speed? -- Bruce | 41.1670S | \ spoken | -+- Hoult | 174.8263E | /\ here. | ----------O---------- I doubt it. More likely pulling up into rising/sinking air would account for the differentials. Frank Whiteley 40-26N 104-38W |
At 16:00 27 March 2005, Bill Daniels wrote:
I think experienced pilot/observers can tell when a pilot is waiting for the ailerons to get a grip on the air. In the event of an actual test, the pilot could brief the observer that his particular glider needs a non-standard technique and the observer would make allowances for it. Whenever I've made a fully ballasted takeoff in my N2C, I've carefully briefed both the wing runner and the tow pilot (as well as the peanut gallery who wanted to see a glider take off with 600 pounds of ballast.) So far, I haven't dropped a wing. My 27B has ailerons with the chord of a popsicle stick. I don't know what speed I need to hold a wing up against a gust, but when I'm full of water at 5,000' on a 95 degree day I want a heck of a fast wing runner. I'll take your point that an experienced observer can pick out poor piloting technique at any phase of flight. I remain skeptical of this whole test idea. While you might flunk some good pilots, it's principal shortcoming is that you are trying to catch something that for even moderately skilled pilots happens relatively infrequently, so the odds of it being useful is low, plus you have to set up the whole test process on top of whatever else you're doing to run a contest. I still think it's best left to the subjective assessment of the CD to determine if someone has a piloting deficiency. 9B |
![]() "Andy Blackburn" wrote in message ... At 16:00 27 March 2005, Bill Daniels wrote: I think experienced pilot/observers can tell when a pilot is waiting for the ailerons to get a grip on the air. In the event of an actual test, the pilot could brief the observer that his particular glider needs a non-standard technique and the observer would make allowances for it. Whenever I've made a fully ballasted takeoff in my N2C, I've carefully briefed both the wing runner and the tow pilot (as well as the peanut gallery who wanted to see a glider take off with 600 pounds of ballast.) So far, I haven't dropped a wing. My 27B has ailerons with the chord of a popsicle stick. I don't know what speed I need to hold a wing up against a gust, but when I'm full of water at 5,000' on a 95 degree day I want a heck of a fast wing runner. I'll take your point that an experienced observer can pick out poor piloting technique at any phase of flight. I remain skeptical of this whole test idea. While you might flunk some good pilots, it's principal shortcoming is that you are trying to catch something that for even moderately skilled pilots happens relatively infrequently, so the odds of it being useful is low, plus you have to set up the whole test process on top of whatever else you're doing to run a contest. I still think it's best left to the subjective assessment of the CD to determine if someone has a piloting deficiency. 9B Agreed. Having been a CD, I do know when a pilot deserves a bollicking or a refusal, having had to counsel 10000+ hour pilots on safety in the pattern and refuse a weak link because the chain link was not a suitable substitute for a Tost ring set. And also having had to call a day, which, in turn, meant calling the contest. Frank Whiteley |
Fantastic. Two great posts, from 59er and from Mr.
Cochrane. I am starting to lean towards the idea of a 500ft or 1000ft finish. My remaining question is still whether safety is best served by the idea of a narrow cylinder, remote 'control point' at 500-1000ft, or the standard 500-1000ft cylinder over the airport. I do think that low passes AFTER the finish as a crowd-pleaser are at contest organizer discretion, but I don't think these should be encouraged by extra contest points. Forgive me for this, but there is one perhaps morbid and a little tasteless observation about an advantage of low passes. The finishers who were dehydrated ended up stall/spinning somewhere near the airport that was likely unoccupied, instead of a half-uncoscious landing and swerving off into the poor spectators lining the runway. I have been in a situation with a problem aircraft where I purposely decided to fly over an ocean so that if anything went wrong further, I wouldn't hurt people on the ground. So I do take this seriously. I wonder if we will now see less of these stall/spin accidents and more of the final approach landing accidents instead, just shifting the problem. Well, since by far the most common victim is the pilot, and survivability seems much better with a miffed landing than a stall/spin, we're all maybe still better off with 500-1000ft finish altitudes and miffed landings instead. I'll get to watch all this in the coming contest, and I'm sure I'll see at least a few dehydrated pilots do 'interesting' things. Hopefully not TOO interesting... Hmmm...perhaps Alhambra or Evian would be a good contest sponsor? ![]() At 16:00 27 March 2005, Bb wrote: M B wrote: It occurs to me that if someone is on final glide at the end of a competition, they may pick a speed (like 85 knots) which their computer says is optimal for points, but which is both: 1) too fast for a rolling finish/landing and 2) too slow for a pull up, turn around, and landing. Is that an accurate assessment? Would a competition pilot be put in a situation where he must decide between points and safety of the landing? This is exactly right. The mathematically optimal point score comes when you cross the finish (50 feet, middle of the airport) at the regular inter-thermal glide speed, 70-80 kts rather than 130. This is of course about the worst place from which to start a sensible pattern, especially when 50 other guys are doing the same thing at the same time. You see fast finishes because most of us are a bit chicken and hold some reserve, losing a few points in the process. Everyone in these threads has been advocating 'just do a rolling finish if it seems touchy' but that's a hard decision too. The finish gate is typically downwind, so the following pattern is only a 180 to land into the wind. Thus, a rolling finish is a downwind landing, often in a substantial wind, with a huge fleet landing in the opposite direction. Furthermore the pilot in the typical marginal situation, with enough energy to cross the gate at 50-100 feet with 70-80 kts, has to dissipate a lot of energy to roll a finish at the far end of the runway. If not, this pilot would cross the runway threshold at say 100-200 feet and 80 kts. At this point it's really too late to roll (remember all those guys landing into the wind at the other end of the runway!) and you don't have enough energy to do a proper flying finish. Coffin corner. So the decision to roll - accept a downwind landing into the face of traffic - has to be made at least a mile or two out, while there is still substantial energy left and a good chance of picking up 50-100 feet of energy, or misjudging your total energy by 50-100 feet. I think I can start to sympathize with people who get in this mess. John Cochrane BB Mark J. Boyd |
AmeriFlight Crash | C J Campbell | Piloting | 5 | December 1st 03 02:13 PM |
Single-Seat Accident Records (Was BD-5B) | Ron Wanttaja | Home Built | 41 | November 20th 03 05:39 AM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Piloting | 25 | September 11th 03 01:27 PM |
