Go Back   Home » AviationBanter forum » rec.aviation newsgroups » General Aviation
Engine on Global Flyer
Old April 4th 05, 04:03 PM
David Lesher
"David Cartwright" writes:
You can't be sure, after all, that whatever caused the fault in one engine
won't do so in another. I remember reading of an incident in a three-engine
aircraft (DC-10?) where a mechanic changed the magnetic chip detectors
(little screw-in plugs that attract particles of metal that have worn off
the engine so you can analyse them) and replaced them with new ones that
didn't have their rubber seals fitted. So all three engines ran low on oil
some way into the flight. Initially they thought there was a spurious oil
leak (ruptured/worn pipe or whatever) in the engine that failed first, only
to see the oil pressure drop on the other two first!
I think it was an L-1011 belonging to National. It made it to Miami Beach,
or almost...
As a result, ETOPS has strict segregation rules. No mechanic works on
both engines, etc.
A host is a host from coast to
& no one will talk to a host that's close........[v].(301) 56-LINUX
Unless the host (that isn't close).........................pob 1433
is busy, hung or dead....................................20915-1433
Global Flyer Success Jan Nademlejnsky Home Built 23 March 10th 05 02:13 AM
Proposals for air breathing hypersonic craft. I Robert Clark Military Aviation 2 May 26th 04 07:42 PM
Emergency Procedures RD Piloting 13 April 11th 04 09:25 PM
Autorotation ? R22 for the Experts Eric D Rotorcraft 22 March 5th 04 07:11 AM
Corky's engine choice Corky Scott Home Built 39 August 8th 03 05:29 AM
