"jcpearce" wrote in message ups.com... Thank you everyone for the input, now I am looking for some prioritization. I received the new power supply from www.mini-box.com and it is substantially better than the previous version (http://www.mini-box.com/s.nl/sc.8/ca...it.A/id.356/.f ) however I still get some noise in the radios. The new version is too big to fit in the previous enclosure so it is sitting slightly apart from the MB on its own. I have started to jot down what the system wants to do, pictures and status at http://69.229.202.54:8080 Under the 'Image' folder one can see the plane, the EPIA in the nose and the prototype ADC board. So now I have a case that has to heavily part for the ATX power lines to come into it & a non cased DC power supply. I have attached ferrite beads to the power lines coming in/out with little improvement. It takes time for many of the steps so I am looking for what you folks think would be the 'biggest bang for the buck', or the right priority to proceed with. (IE, build a brand new case for everything, build a seperate case for the PSU, don't build a case right away but do X,Y,Z, etc..) Thanks once again for the brains helping noodle this over. Check out this machine, only +5vdc required, linux capable... http://www.diamondsystems.com/products/prometheus I'm sure there are many more similar... |
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1 Blueskies wrote: "jcpearce" wrote in message ups.com... Thank you everyone for the input, now I am looking for some prioritization. I received the new power supply from www.mini-box.com and it is substantially better than the previous version (http://www.mini-box.com/s.nl/sc.8/ca...it.A/id.356/.f ) however I still get some noise in the radios. The new version is too big to fit in the previous enclosure so it is sitting slightly apart from the MB on its own. I have started to jot down what the system wants to do, pictures and status at http://69.229.202.54:8080 Under the 'Image' folder one can see the plane, the EPIA in the nose and the prototype ADC board. So now I have a case that has to heavily part for the ATX power lines to come into it & a non cased DC power supply. I have attached ferrite beads to the power lines coming in/out with little improvement. It takes time for many of the steps so I am looking for what you folks think would be the 'biggest bang for the buck', or the right priority to proceed with. (IE, build a brand new case for everything, build a seperate case for the PSU, don't build a case right away but do X,Y,Z, etc..) Thanks once again for the brains helping noodle this over. Check out this machine, only +5vdc required, linux capable... http://www.diamondsystems.com/products/prometheus I'm sure there are many more similar... All Right! Now that's what I call an embedded system. Actually I use systems almost exactly the same as these in my line of work... Put Linux on them too. -----BEGIN PGP SIGNATURE----- Version: GnuPG v1.0.6 (GNU/Linux) Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org iD8DBQFCFqZ1pxCQXwV2bJARAq0WAKCQoWnkN5Ncza2Q/smCjFLG3+Xs4wCgi6Gx EoJRK6xJaoaAcln6lG69Hcg= =8+p8 -----END PGP SIGNATURE----- |
Blueskies wrote:
Check out this machine, only +5vdc required, linux capable... http://www.diamondsystems.com/products/prometheus I'm sure there are many more similar... Looks to be a nice system to play around with. It has the possibility of handling both the data interface and computations. The main problem I see with this system is no windowing system ie KDE and I think that was part of his need. John |
Hash: SHA1 UJ, Well, it doesn't come with a video card if that is what you meant, however, that is a relatively simple matter to fix. PC104 video cards are quite reasonably priced & even support 1/2 or 1/4 VGA standards. Evan UltraJohn wrote: Blueskies wrote: Check out this machine, only +5vdc required, linux capable... http://www.diamondsystems.com/products/prometheus I'm sure there are many more similar... Looks to be a nice system to play around with. It has the possibility of handling both the data interface and computations. The main problem I see with this system is no windowing system ie KDE and I think that was part of his need. John -----BEGIN PGP SIGNATURE----- Version: GnuPG v1.0.6 (GNU/Linux) Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org iD8DBQFCFz4opxCQXwV2bJARAnAmAJoDMEDGi2BwdSuFbfQo/kYo1o/tGwCfXD6v P9jP1/H9v/OAWRmw3a++wi4= =iPrK -----END PGP SIGNATURE----- |
It's a PC. He can install all the Linux junk he wants.
"UltraJohn" wrote in message k.net... Looks to be a nice system to play around with. It has the possibility of handling both the data interface and computations. The main problem I see with this system is no windowing system ie KDE and I think that was part of his need. |
How much does one of these development systems cost? Check out this machine, only +5vdc required, linux capable... http://www.diamondsystems.com/products/prometheus I'm sure there are many more similar... |
So far I have spent
$180 MB $ 80 Power supply $80 512Mb DDR ram $90 on two USB flash cards $30 data aquisition board materials $30 odds and ends. ~$490 When I bought the EPIA the TC model was not out yet. This is what I would have purchased these days saving $80 and a lot of headache. I might end up buying this anyway and selling the old one on ebay. |
I bought one a couple of years ago for around $1k (+/- a couple hundred
bucks). Arcom also sells some very reasonable development kits. "AINut" wrote in message ... How much does one of these development systems cost? |
