On Fri, 06 May 2005 16:50:22 GMT, George Patterson
wrote: Jose wrote: No. As you said, Class B airspace requires ATC to tell you you are cleared into it. You need to hear "Cleared through the Bravo airspace" or somesuch. The last clearance I got from New York ran something like "November 3162 Kebec, climb to 2500 feet, heading 355, stay west of the river, report at the Hudson tunnel." When I've asked for a Bravo clearance, and they have to check with another controller, they'll sometimes come back with something like the above... Just directions that would be take me into the Bravo without the explicit 'cleared into the bravo'. I'll usually read those back with 'understand cleared into the bravo' appended to the end so there is no mistaking things. aw |
On 5 May 2005 14:21:41 -0700, "Andrew"
wrote: ATC says "radar contact, 20 miles south of XYZ, proceed on course". Do you acknowledge this transmission? Do they want read back for everything, or should we shut up as much as possible? The best thing to do is click your transmitter twice. And in deference to Dudley, I'm going to put a smiley here. 00000000000000000000000000000000000000000000000000 00 Sorry, but I just couldn't do it. Mike Weller |
On 5 May 2005 14:21:41 -0700, "Andrew" wrote: ATC says "radar contact, 20 miles south of XYZ, proceed on course". Do you acknowledge this transmission? Do they want read back for everything, or should we shut up as much as possible? The best thing to do is click your transmitter twice. Where did you hear that? ATC does that. But there's only one of them on the freq. Pilots shouldn't. ATC requires a verbal response. moo |
I was told under no uncertain terms by ATC one day that "Double clicking is
*NOT* an acknowledgement." On the below, ATC is not only giving information ("radar contact"), but relaying instructions ("proceed on course"). Instructions require not only acknowledgement, but readback: "Proceeding on course, 45Q." As far as altimeter settings, if you don't acknowledge, ATC doesn't whether or not you heard them. If you don't read them back, they don't know whether or not you heard them correctly. "29.92, 45Q." wrote in message news:1115361381.ba8215193ce4b7d4faa4002afd3225cc@o nlynews... On 5 May 2005 14:21:41 -0700, "Andrew" wrote: ATC says "radar contact, 20 miles south of XYZ, proceed on course". Do you acknowledge this transmission? Do they want read back for everything, or should we shut up as much as possible? The best thing to do is click your transmitter twice. And in deference to Dudley, I'm going to put a smiley here. 00000000000000000000000000000000000000000000000000 00 Sorry, but I just couldn't do it. Mike Weller |
![]() "Andrew" wrote in message oups.com... ATC says "radar contact, 20 miles south of XYZ, proceed on course". Do you acknowledge this transmission? How about when ATC says "altimeter setting 2992" on your first contact after a handoff? Does this require acknowledgement? If you don't acknowledge them they're going to be repeated. In the past, I've acknowledged such things if the controller was not busy. But I've heard all kinds. Some people read back the altimeter setting. I've even heard people reading back the "radar contact" message. I feel that this is a waste of bandwidth. However, I don't know what ATC prefers. Do they want read back for everything, or should we shut up as much as possible? I read back control instructions; routes, headings altitudes, etc. Everything else is just acknowledged. |
For me it depends on the situation and what I've been hearing
on frequency. I will most always acknowledge with something .. it tells them I'm still with them. If they're up to their hind ends in alligators .. then a quick acknowledgement of the last 3 letters of my N number or just a "thanks". If I'm hearing them chit chatting indicating they're bored silly then I might stretch it out to include "good morning, how's things going for you this morning".... "Andrew" wrote in message oups.com... ATC says "radar contact, 20 miles south of XYZ, proceed on course". Do you acknowledge this transmission? How about when ATC says "altimeter setting 2992" on your first contact after a handoff? Does this require acknowledgement? In the past, I've acknowledged such things if the controller was not busy. But I've heard all kinds. Some people read back the altimeter setting. I've even heard people reading back the "radar contact" message. I feel that this is a waste of bandwidth. However, I don't know what ATC prefers. Do they want read back for everything, or should we shut up as much as possible? |
In article .com, Andrew wrote:
ATC says "radar contact, 20 miles south of XYZ, proceed on course". Do you acknowledge this transmission? Yes, but only with my callsign (abbreviated when applicable). How about when ATC says "altimeter setting 2992" on your first contact after a handoff? Does this require acknowledgement? And a readback. You want to know that both you and the controller are working off the same altimeter setting or Bad Stuff may happen. My readback is pretty short ('two niner niner two, november four one bravo') -- Dylan Smith, Castletown, Isle of Man Flying: http://www.dylansmith.net Frontier Elite Universe: http://www.alioth.net "Maintain thine airspeed, lest the ground come up and smite thee" |
Andrew wrote:
ATC says "radar contact, 20 miles south of XYZ, proceed on course". Do you acknowledge this transmission? How about when ATC says "altimeter setting 2992" on your first contact after a handoff? Does this require acknowledgement? In the past, I've acknowledged such things if the controller was not busy. But I've heard all kinds. Some people read back the altimeter setting. I've even heard people reading back the "radar contact" message. I feel that this is a waste of bandwidth. However, I don't know what ATC prefers. Do they want read back for everything, or should we shut up as much as possible? I don't read back "ident" instructions, I just press the button. I acknowledge everything else. Things like altimeter and such I just use the (shortened) tail number. Anything that's an instruction I read back. -- Frank....H |
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1 Sorry about my last post, Steve. It's directed towards you, not Ron. BL. - -- Brad Littlejohn | Email: Unix Systems Administrator, | Web + NewsMaster, BOFH.. Smeghead! ![]() PGP: 1024D/E319F0BF 6980 AAD6 7329 E9E6 D569 F620 C819 199A E319 F0BF -----BEGIN PGP SIGNATURE----- Version: GnuPG v1.4.1 (GNU/Linux) iD8DBQFCfoRMyBkZmuMZ8L8RAsibAJ9IXbqKZDFYnPR4MdKEIe kWAjPfBACggbpZ uWWXkFydqHkC1HG1LkpKqPk= =9rb2 -----END PGP SIGNATURE----- |
What F-102 units were called up for Viet Nam | Tarver Engineering | Military Aviation | 101 | March 5th 06 03:13 AM |
