18 feet. I'd rather deal with narrow than wide which are usually lacking in visual clues. "Kyle Boatright" wrote in message ... What's the narrowest runway you've ever used? At what runway width are you comfortable? Among other things, I had an interesting experience yesterday with a runway that was far narrower than any I'd used before... We had gone to Dallas for Mother's day, and returned to Atlanta yesterday in my RV-6, which is set-up for basic VFR. The weather was marginal for most of the way, and we made two unscheduled stops and a couple of 180 degree course reversals to avoid weather that was below my minimums. This turned a 3.5 hour trip into an 8 hour odyssey. Our first 180 turn and unscheduled stop occurred when the ceiling was lower than forecast, below my personal minimums, and dropping along our route of flight. I hit the "nearest" function on the GPS, and retreated to the nearest airfield to give the FSS a call on the cell phone (we were too low for radio communication). As we overflew the airfield, I noticed that all it was was a paved strip and a paved ramp. No buildings nearby. Also, the strip looked fairly narrow, but I went ahead with the landing anyway. On very short final, it became obvious that this strip redefined narrow. Accoring to the AFD, it is 50' wide, but what the AFD didn't say is that 3' tall sagebrush grows right to the edge of the strip, and occasionally cuts into the 50' useful width. Given that 3' sagebrush will hit the RV-6's wingtips, I probably had 10'-12' clear on each side. Catching the sagebrush with a wingtip would have almost certainly caused a groundloop. With this in mind, and concentrating hard enough to cause permanant forehead wrinkles, I managed to keep the airplane centered on landing and rollout, then taxiied (sp?) to the ramp, where I shut down, pulled out the cell phone and got exactly zero signal... (Sometimes you can't win.) So, we fired up again, taxiied out, and I kept the bird out of the weeds on takeoff and off we went. In the 30 minutes our detour consumed, the weather along the route improved meaningfully, and we made another 225 miles before the next unplanned stop. After a 3 hour wait and a couple of visits with the on-field FSS at Greenville, MS, we found a safe path around the line of storms on the Alabama/Mississippi border and came on home. One of the real advantages to a relatively high performance airplane is that if the weather allows, you can get above most of the cumulus and eyeball your way around the convective stuff. I'm not sure we would have gotten around yesterday's weather in a C-172 or Cherokee... |
I never landed on an 18ft runway - don;t really know it I would want to
- I think not. What was your shortest? Again, I'm very conservative about this. Mine to date is 2400 ft with trees. My worst airport to date is in a very narrow valley where the runway is longer and wider than my minimums, but the surrounding mountains encroach enough that you cannot fly a standard pattern. If I'm being honest, I'm not a great fan of extreme runways (nor is my insurer ![]() Tony C-GICE In article , "Dave Stadt" wrote: 18 feet. I'd rather deal with narrow than wide which are usually lacking in visual clues. "Kyle Boatright" wrote in message ... What's the narrowest runway you've ever used? At what runway width are you comfortable? Among other things, I had an interesting experience yesterday with a runway that was far narrower than any I'd used before... We had gone to Dallas for Mother's day, and returned to Atlanta yesterday in my RV-6, which is set-up for basic VFR. The weather was marginal for most of the way, and we made two unscheduled stops and a couple of 180 degree course reversals to avoid weather that was below my minimums. This turned a 3.5 hour trip into an 8 hour odyssey. Our first 180 turn and unscheduled stop occurred when the ceiling was lower than forecast, below my personal minimums, and dropping along our route of flight. I hit the "nearest" function on the GPS, and retreated to the nearest airfield to give the FSS a call on the cell phone (we were too low for radio communication). As we overflew the airfield, I noticed that all it was was a paved strip and a paved ramp. No buildings nearby. Also, the strip looked fairly narrow, but I went ahead with the landing anyway. On very short final, it became obvious that this strip redefined narrow. Accoring to the AFD, it is 50' wide, but what the AFD didn't say is that 3' tall sagebrush grows right to the edge of the strip, and occasionally cuts into the 50' useful width. Given that 3' sagebrush will hit the RV-6's wingtips, I probably had 10'-12' clear on each side. Catching the sagebrush with a wingtip would have almost certainly caused a groundloop. With this in mind, and concentrating hard enough to cause permanant forehead wrinkles, I managed to keep the airplane centered on landing and rollout, then taxiied (sp?) to the ramp, where I shut down, pulled out the cell phone and got exactly zero signal... (Sometimes you can't win.) So, we fired up again, taxiied out, and I kept the bird out of the weeds on takeoff and off we went. In the 30 minutes our detour consumed, the weather along the route improved meaningfully, and we made another 225 miles before the next unplanned stop. After a 3 hour wait and a couple of visits with the on-field FSS at Greenville, MS, we found a safe path around the line of storms on the Alabama/Mississippi border and came on home. One of the real advantages to a relatively high performance airplane is that if the weather allows, you can get above most of the cumulus and eyeball your way around the convective stuff. I'm not sure we would have gotten around yesterday's weather in a C-172 or Cherokee... -- Tony Roberts PP-ASEL VFR OTT Night Cessna 172H C-GICE |
| Thread Tools | |
| Display Modes | |
| Narrow Foil Strips for Ground Plane | Dennis Mountains | Home Built | 22 | August 29th 04 02:09 AM |
| Winds on long runways | Casey Wilson | Piloting | 15 | July 17th 04 09:35 AM |
| Cylinder Wrenches for 0-320A Narrow Deck | DAVE | Home Built | 1 | December 31st 03 02:45 PM |
| Extreme Runways | JohnMcGrew | Piloting | 9 | October 25th 03 03:57 PM |
| fs2002 - increase intensity taxiway and runways' lights? | Mark Cherry | Simulators | 0 | September 23rd 03 02:08 AM |
