Re-Reading the original post on this subject made me realize
something... The plane was on approach not on a departure... If that makes a difference on the effect of loosing an engine, I do not know. I would certainly suspect it would make a difference since I would think on approach engines would be on a low power setting... On 31 May 2005 22:17:51 GMT, wrote: My understanding is that the aircraft will tend to roll due to the side with the failed engine having less lift. My CFI was explaining this to me some time ago. Engine failure would require immediate and extreme rudder input and feathering the props on the failed engine to reduce the drag. He said something about "Lawn Dart" and that it can happen in a blink of the eye. I'm a ASEL primary student. What's the skinny on multi-engine control issues when one engine fails on approach? Mike Alexander PP-ASEL Temecula, CA See my online aerial photo album at http://flying.4alexanders.com |
On 5/31/2005 6:57 PM, Mike 'Flyin'8' wrote:
Re-Reading the original post on this subject made me realize something... The plane was on approach not on a departure... If that makes a difference on the effect of loosing an engine, I do not know. I would certainly suspect it would make a difference since I would think on approach engines would be on a low power setting... I was assuming he didn't like the approach, and decided to go around ... then added full power on the remaining engine. This is assumption on my part, as I have no additional information. On 31 May 2005 22:17:51 GMT, wrote: My understanding is that the aircraft will tend to roll due to the side with the failed engine having less lift. My CFI was explaining this to me some time ago. Engine failure would require immediate and extreme rudder input and feathering the props on the failed engine to reduce the drag. He said something about "Lawn Dart" and that it can happen in a blink of the eye. I'm a ASEL primary student. What's the skinny on multi-engine control issues when one engine fails on approach? Mike Alexander PP-ASEL Temecula, CA See my online aerial photo album at http://flying.4alexanders.com -- Mark Hansen, PP-ASEL, Instrument Student Sacramento, CA |
This sounds a little on the macho side. He may be making it sound worse
than it is. With low power there's not that much yaw into the failed engine. If you get too slow and try to do a go around on one engine you could sure manage to roll it over. If you want to understand it .. find a CFI to take you out for a quick ride and demo minimum controllable airspeed (Vmc) on one engine for you. There's a red line on the airspeed indicator for Vmc. This is under set conditions though and in reality can change due to weight, CG location, altitude. An airspeed below this won't give you sufficient directional control. Pitching down and removing power gets control back by increasing airspeed and reducing asymetrical thrust. wrote in message ... My understanding is that the aircraft will tend to roll due to the side with the failed engine having less lift. My CFI was explaining this to me some time ago. Engine failure would require immediate and extreme rudder input and feathering the props on the failed engine to reduce the drag. He said something about "Lawn Dart" and that it can happen in a blink of the eye. I'm a ASEL primary student. What's the skinny on multi-engine control issues when one engine fails on approach? -- Mike Flyin'8 PP-ASEL Temecula, CA http://flying.4alexanders.com |
My understanding is that the aircraft will tend to roll due to the side with the failed engine having less lift. My CFI was explaining this to me some time ago. Bull****. If the engine failed on approach when you were already on final, you wouldn't even notice. It's the asymetrical thrust that causes the problem.. Not an isste at low RPM. Now if you had to firewall it for a go around..... that would be a different story. |
An engine failure in a twin is far more hazardous on takeoff than on
approach, because the "good" engine is trying to turn the airplane upside down and frequently succeeds. On approach, with power reduced, it is sometimes difficult to even sense that an engine has failed. Emphasize "sometimes." I have no experience with Swearingens and/or how power is set on approach. Many turboprops have a negative-torque sensor that automatically feathers the prop on a failed engine...but this is a good thing, as Martha Stewart might say...no drag on the failed engine side, low power(?) on the good engine side. Shouldn't result in a 90 degree roll. Bob Gardner "R.L." wrote in message . .. This is the best latest (Google, 5/31/05, 1700 EDT) on the TEB incident today. http://www.northjersey.com/page.php?...ZWVFRX l5Mg== I heard earlier on NY CBS Radio that the pilot reported "engine trouble" on approach and that a witness saw the plane making contact with the runway right-wing-down, almost 90 degrees. I'm a ASEL primary student. What's the skinny on multi-engine control issues when one engine fails on approach? |
unless he just got to slow.. but low power below Vmc should not be that
bad.. unless he pushed it up fast and forgot his Vmc demos.. hard to believe because I'm sure they are practiced in the SIM on a regular basis BT "Bob Gardner" wrote in message ... An engine failure in a twin is far more hazardous on takeoff than on approach, because the "good" engine is trying to turn the airplane upside down and frequently succeeds. On approach, with power reduced, it is sometimes difficult to even sense that an engine has failed. Emphasize "sometimes." I have no experience with Swearingens and/or how power is set on approach. Many turboprops have a negative-torque sensor that automatically feathers the prop on a failed engine...but this is a good thing, as Martha Stewart might say...no drag on the failed engine side, low power(?) on the good engine side. Shouldn't result in a 90 degree roll. Bob Gardner "R.L." wrote in message . .. This is the best latest (Google, 5/31/05, 1700 EDT) on the TEB incident today. http://www.northjersey.com/page.php?...ZWVFRX l5Mg== I heard earlier on NY CBS Radio that the pilot reported "engine trouble" on approach and that a witness saw the plane making contact with the runway right-wing-down, almost 90 degrees. I'm a ASEL primary student. What's the skinny on multi-engine control issues when one engine fails on approach? |
Maybe he was planning to go around and lost it in the power increase?
"Bob Gardner" wrote in : An engine failure in a twin is far more hazardous on takeoff than on approach, because the "good" engine is trying to turn the airplane upside down and frequently succeeds. On approach, with power reduced, it is sometimes difficult to even sense that an engine has failed. Emphasize "sometimes." I have no experience with Swearingens and/or how power is set on approach. Many turboprops have a negative-torque sensor that automatically feathers the prop on a failed engine...but this is a good thing, as Martha Stewart might say...no drag on the failed engine side, low power(?) on the good engine side. Shouldn't result in a 90 degree roll. Bob Gardner snip |
Judah wrote:
Maybe he was planning to go around and lost it in the power increase? With one or two engines operating, it's possible to lose it in a high performance aircraft go-around if you're not prepared for the pitch-up as power is abruptly added, the airplane is improperly trimmed, you're dealing with a particularly nasty, gusty wind flowing over some trees about 50-75 feet high, and you suddenly find yourself a bit slower than you'd like. Case in point: Text: http://www.ntsb.gov/ntsb/brief.asp?e...05X02197&key=1 Key: http://www.ntsb.gov/ntsb/GenPDF.asp?...02LA017&rpt=fi If those links don't work, search for Pittstown, NJ, Beech, Oct 26, 2001. I looked over the accident aircraft and couldn't believe my eyes. Although upside down and the tail bent beyond repair, the passenger compartment was intact and my mechanic (based at the field) told me the pilot & his wife walked away shaken, not stirred. I was sold on Beech products from that day forward. Not that I have any intention to test the strength of the Beech design, I pray my next aircraft is either a Bonanza or Baron. -Doug -- -------------------- Doug Vetter, CFIMEIA http://www.dvcfi.com -------------------- |
issues when one engine fails on approach? As you would expect, there is a tendency for the aircraft to yaw towards the failed engine which then creates a roll in the same direction (secondary effect of yaw). It's countered with rudder - but the amount required depends on how much power the engine is producing, and how much airspeed you have. Multi-engine aircraft have a minimum asymetric control speed (Vmca) (Vmc in some parts) - below this speed you won't have sufficient rudder authority to stop the yaw/roll unless you reduce power on the good engine - unfortunately it's all too common for pilots of twins to get low and slow on one engine, and then go below Vmca whilst trying to go around on 1 engine - at which point the aircraft slowly rolls on it's back and everyone dies. So - the lessons are ... 1. Don't get low and slow on 1 engine, and 2. If you ABSOLUTLELY have to go around on 1 engine, make the decision as early as possible. 3. Practice these things with an instructor on a regular basis (every 90 days is good) As previously noted by Bob, on the approach it's often so subtle you don't even know one has failed. |
Even better rule...don't try to go around on one engine. Put it on a
taxiway, on the grass, whatever, but don't try to go around on one. IMHO it is bad training practice to even suggest to a MEL student that waving off is a practical alternative. Bob Gardner "Cockpit Colin" wrote in message ... I'm a ASEL primary student. What's the skinny on multi-engine control issues when one engine fails on approach? As you would expect, there is a tendency for the aircraft to yaw towards the failed engine which then creates a roll in the same direction (secondary effect of yaw). It's countered with rudder - but the amount required depends on how much power the engine is producing, and how much airspeed you have. Multi-engine aircraft have a minimum asymetric control speed (Vmca) (Vmc in some parts) - below this speed you won't have sufficient rudder authority to stop the yaw/roll unless you reduce power on the good engine - unfortunately it's all too common for pilots of twins to get low and slow on one engine, and then go below Vmca whilst trying to go around on 1 engine - at which point the aircraft slowly rolls on it's back and everyone dies. So - the lessons are ... 1. Don't get low and slow on 1 engine, and 2. If you ABSOLUTLELY have to go around on 1 engine, make the decision as early as possible. 3. Practice these things with an instructor on a regular basis (every 90 days is good) As previously noted by Bob, on the approach it's often so subtle you don't even know one has failed. |
Parachute fails to save SR-22 | Capt.Doug | Piloting | 72 | February 10th 05 05:14 AM |
Tactical Air Control Party Airmen Help Ground Forces | Otis Willie | Military Aviation | 0 | January 22nd 04 02:20 AM |
How much could I get for these back issues? | Aaron Smith | Home Built | 8 | December 15th 03 12:07 PM |
Flight Simulator 2004 Control Issues | SouthBayGuy | Simulators | 22 | November 26th 03 04:31 PM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
