Altimeter settings: QNH versus QFE
Old June 2nd 05, 06:34 PM
Graeme Cant
stephanevdv wrote:
Just another point in this discussion: when I look at an approach map of
an airfield, the pattern altitude is expressed as a height above
ground.
The only ones I knew did that were the old Aeradio ones published for BA
when they used QFE. Never seen a Jepp chart in QFE - but I guess
they're produced that way for some operators.
If you want to fly QNH, pattern altitudes should be expressed AMSL.
They almost always are on the charts I've seen.
By the way, here in Europe (except UK, of course) glider altimeters are
in meters, not feet, thereby conforming to ICAO annex 5
True. But in non-conformity to the great bulk of aviation globally. A
classic example of the problems of one-nation one-vote in these matters.
BTW - Aren't your altimeters in metres, not meters?
whose purpose
it is to standardize units of measurement to the ISU
No. Its purpose is just to standardise measurements. Feet are
perfectly good units to standardise on.
. As the approach
maps (and other aviation maps) usually are in feet, we already have to
make computations anyhow.
Well stop resisting. Learn to think in feet instead of metres.
It's high time we got rid of feet, knots and nautical miles! Their only
real purpose in aviation seems to be to make it more difficult to get a
pilot's licence, as you have to adjust to a new set of units. (Yes, I
know there are certain countries where they like to use outdated unit
systems. I also know the classical arguments like "a nautical mile
equals a minute of latitude", but how often do you fly true north or
south?)
ICAO working document(23/9/04): "...a study...completed in 1997,
indicated that 97% of jet aircraft worldwide were non-SI equipped
aircraft. Moreover, a growing number of non-SI equipped aircraft were
being operated by airlines of the small number of States which use SI
units."
You'll be flying in feet, knots and nautical miles for quite a while.
Better relax and go with the flow.
GC
stephanevdv
Posted via OziPilots Online [ http://www.OziPilotsOnline.com.au ]
- A website for Australian Pilots regardless of when, why, or what they fly -
Old June 2nd 05, 09:52 PM
Jack
south?)
How often do you look at a map?
Jack
Old June 3rd 05, 04:02 AM
Tony Verhulst
south?)
Airplane pilots like to look at the length of a course line, compare it
to the minutes latitude and know exactly the distance without the use of
any other tools. I understand that there are other tools. I was raised
as a Dutch man and brought up with the metric system - and prefer it.
But, to me nautical miles make sense, YMMV.
On another topic, why have horizontal speed in km/h and vertical speed
in meters/sec? To me, this is odd. If the units were the same, you could
simply divide one into the other and get the L/D - again, YMMV.
Tony V.
Old June 3rd 05, 04:37 AM
Bill Daniels
"Tony Verhulst" wrote in message
south?)
Tony V.
Knots, MPH, KPH, meters/sec are just numbers. Just read the POH and fly the
numbers.
However, I have a beef with metric altimeters. The large hand reads 1000
meters per rev. An imperial units altimeter reads 1000 feet per rev. 1000
meters = 3281 feet so the metric altimeter is less than 1/3 as sensitive as
the one based on feet. To me, that seems inadequate.
I like to see the altimeter hand move with small changes in altitude.
That's confirmation that all is well in the instrument panel. I've seen
haywire varios insistently reading up while the altimeter was winding down.
I'm not sure I would have spotted that as quickly with a metric altimeter.
I suppose there is no reason that a metric altimeter could not be more
sensitive. With today's digital technology, 100 meters per rev should be
possible. I've never seen one that sensitive.
Bill Daniels
Old June 3rd 05, 04:56 AM
Eric Greenwell
Actually, even yesterday's digital technology already provides very
sensitive altimeters in our varios, GPS units, or flight computers.
These are digital readouts, of course, not hands, but I find myself
looking at my Cambridge 302 altimeter reading much more than the
mechanical one. You can use it in feet or meters, and have plenty of
sensitivity.
The next mechanical altimeter I buy will likely be an INsensitive unit,
like one of the 0-10,000' or 0-20,000 single hand units for less than $150.
Eric Greenwell
Washington State
USA
Old June 3rd 05, 09:15 AM
Bruce Hoult
Some gliders I have flown have altimeters marked in feet, but 3000 ft
per revolution rather than 1000.
Presumably it's possible to design a single unit for either metric or
imperial use and tweak the calibration by the 10% difference.
Bruce | 41.1670S | \ spoken | -+-
Hoult | 174.8263E | /\ here. | ----------O----------
Old June 3rd 05, 12:37 PM
stephanevdv
Funny to get exactly the reactions one could foresee. OK, I admit I
don't have much hope of getting the ISU units accepted in aviation, but
the "nautical mile/minute of latitude" story has been dealt with long
ago, shortly after the French Revolution. There still are French (I'm
Belgian, please don't mix us up) survey maps with longitude and
latitude in grades, not degrees (400 grades = 360 degrees). You then
have: 1 hundredth of a grade = 1 kilometre (UK) / kilometer (USA). Just
as efficient (or inefficient), and decimal, but it hasn’t been able to
replace the 360 degree system, not even in the ISU. Oh, by the way,
this geodetic system uses the Paris meridian as zero, not the Greenwich
one.
why have horizontal speed in km/h and vertical speed in meters/sec? To
me, this is odd. If the units were the same, you could simply divide
Odd, yes, but I’m not really in favour of calculating the L/D by
dividing indicated speed by sink anyhow: the value will vary wildly in
a relatively short time, and wind can play havoc with this kind of
calculation.
stephanevdv
Old June 3rd 05, 01:07 PM
Stefan
stephanevdv wrote:
Just
Just to add confusion to the discussion: The decimal system has been
about the dumbest idea which has happened to mankind. The phoenicians
got it right by using the duodecimal system (actually, they used even
the 60-system), which is much more suited for most real life situations.
But some dimmer folks replaced it by the decimal system, because they
couldn't do the math without using their fingers. So I fear we have to
live with that.
Stefan
Old June 3rd 05, 05:09 PM
01-- Zero One
'duodecimal system' -- We use that all the time in libraries in the
USA.
Larry
"Stefan" wrote in message
stephanevdv wrote:
Just
as efficient (or inefficient), and decimal, but it hasn't been able to
live with that.
Stefan
Old June 4th 05, 03:52 AM
Tony Verhulst
01-- Zero One wrote:
'duodecimal system' -- We use that all the time in libraries in the USA.
Groan :-).
Tony V.
Altimeter settings: QNH versus QFE [email protected] Soaring 28 June 6th 05 12:26 PM
Reading back altimeter settings? Paul Tomblin Piloting 31 April 12th 05 04:53 PM
ATC Altimeter Settings O. Sami Saydjari Instrument Flight Rules 81 April 11th 05 08:07 PM
Pressure Altitude and Terminology Icebound Piloting 0 November 27th 04 09:14 PM
Local altimeter at BFM Dan Luke Instrument Flight Rules 3 June 15th 04 02:01 PM
