Beta Prop
Old August 10th 05, 08:44 PM
Dave S
Wouldn't you have this "effect" ANY time you went from a thrusting to a
braking action with regards to thrust generated?
If I pulled power back, set the pitch to flat, and pushed the nose over,
wouldn't the prop be "driving" the engine in the manner you describe?
All of this is able to be done without a specific Beta range.
Dave
PittsS1C wrote:
Is it a good idea to have beta with any geared engines?
Aren't there typically problems with chattering the gears
back and forth leading to failures?
Mike
"Dave S" wrote in message
nk.net...
I believe you are mistaken on the IVO.
The IVO has a specific range of travel that is accomplished by twisting
the blade midshaft, not rotating the entire blade in the hub.
Also, with the auto engines the original poster is discussing, it is less
a function of the engine and more a function of will the PSRU (re-drive)
support a hydraulic governor. The Marcotte and Mistral PSRU's will support
a hydraulic constant speed prop, others such as the Real World Solutions
brand will not.
An electric MT can be obtained that will run in the beta (and even
reverse) ranges, but that is a $10k US proposition. Of course, getting a
hydraulic governor, the price difference for a redrive that supports one,
and getting a hydraulic CS prop, you are likely there with the cost of an
Electric MT in the first place.
It costs money.. plain and simple.
The IVO may be an option for you, but as for a specific "beta" range, I am
fairly sure it doesnt have one.
Dave
Gig 601XL Builder wrote:
I believe both the Woodcomp and the IVO will go into Beta.
"Rob Fonhof" wrote in message
Hi All.
Just wondering if there are any props out there that can be used on an
experimental aircraft engine, ie:subaru or RX-8 Renesis, which have a
beta range. Don't even want to consider a certified unit as this would
probably cost more than the rest of the firewall forward components.
Thanks in advance,
Rob.
Melbourne Australia.
Old August 10th 05, 09:15 PM
PittsS1C
I believe the porper operation of geard engines is not operate in regions of
zero thrust during glides (which is a common occurnace using beta during
taxi...)
Mike
nk.net...
Dave
Mike
nk.net...
support a hydraulic constant speed prop, others such as the Real World
Solutions brand will not.
am fairly sure it doesnt have one.
Dave
Hi All.
Thanks in advance,
Rob.
Old August 11th 05, 02:38 AM
Morgans
nk.net...
Dave
Actually, no. Kinda. g
When the engine is using HP to turn the prop, all is well, be it forward or
reverse thrust. The only difference the gearing sees is the thrust on the
shaft goes from pulling the shaft out, to pushing the shaft in, but the load
on the gears is the same. (all for tractor applications, in this case)
When the possible chattering comes in, is when you are gliding, and at a
very low power setting, and the *windmilling* prop is trying to turn the
engine, thus the prop is "making" HP to try to turn the engine- opposite
from normal.
Jim in NC
Right prop, wrong prop? Wood prop, metal prop? Gus Rasch Aerobatics 1 February 14th 08 10:18 PM
Ivo Prop on O-320 Dave S Home Built 14 October 15th 04 03:04 AM
Prop Pitch Question Eugene Wendland Home Built 2 April 25th 04 03:22 AM
IVO props... comments.. Dave S Home Built 16 December 6th 03 11:43 PM
Metal Prop vs. Wood Prop Larry Smith Home Built 21 September 26th 03 07:45 PM
