"fred" wrote in message ... So what the devil is "91.211"? FAR 91.211, applicable to the US. § 91.211 Supplemental oxygen. (a) General. No person may operate a civil aircraft of U.S. registry- (1) At cabin pressure altitudes above 12,500 feet (MSL) up to and including 14,000 feet (MSL) unless the required minimum flight crew is provided with and uses supplemental oxygen for that part of the flight at those altitudes that is of more than 30 minutes duration; (2) At cabin pressure altitudes above 14,000 feet (MSL) unless the required minimum flight crew is provided with and uses supplemental oxygen during the entire flight time at those altitudes; and (3) At cabin pressure altitudes above 15,000 feet (MSL) unless each occupant of the aircraft is provided with supplemental oxygen. (b) Pressurized cabin aircraft. (1) No person may operate a civil aircraft of U.S. registry with a pressurized cabin- (i) At flight altitudes above flight level 250 unless at least a 10-minute supply of supplemental oxygen, in addition to any oxygen required to satisfy paragraph (a) of this section, is available for each occupant of the aircraft for use in the event that a descent is necessitated by loss of cabin pressurization; and (ii) At flight altitudes above flight level 350 unless one pilot at the controls of the airplane is wearing and using an oxygen mask that is secured and sealed and that either supplies oxygen at all times or automatically supplies oxygen whenever the cabin pressure altitude of the airplane exceeds 14,000 feet (MSL), except that the one pilot need not wear and use an oxygen mask while at or below flight level 410 if there are two pilots at the controls and each pilot has a quick-donning type of oxygen mask that can be placed on the face with one hand from the ready position within 5 seconds, supplying oxygen and properly secured and sealed. (2) Notwithstanding paragraph (b)(1)(ii) of this section, if for any reason at any time it is necessary for one pilot to leave the controls of the aircraft when operating at flight altitudes above flight level 350, the remaining pilot at the controls shall put on and use an oxygen mask until the other pilot has returned to that crewmember's station. |
Steven P. McNicoll wrote: (ii) At flight altitudes above flight level 350 unless one pilot at the controls of the airplane is wearing and using an oxygen mask that is secured and sealed and that either supplies oxygen at all times or automatically supplies oxygen whenever the cabin pressure altitude of the airplane exceeds 14,000 feet (MSL), except that the one pilot need not wear and use an oxygen mask while at or below flight level 410 if there are two pilots at the controls and each pilot has a quick-donning type of oxygen mask that can be placed on the face with one hand from the ready position within 5 seconds, supplying oxygen and properly secured and sealed. I flew on an air ambulance Lear 25 for a while.. and I can say I NEVER saw the cockpit crew remove the masks from the hangars and place them in "the ready position" even though we routinely went to FL 450-490. I am wondering how many operators follow this rule. Dave |
On 2005-08-15, Dave S wrote:
I flew on an air ambulance Lear 25 for a while.. and I can say I NEVER saw the cockpit crew remove the masks from the hangars and place them in "the ready position" even though we routinely went to FL 450-490. I am On our 25D the position of the hangers for the masks were considered in the 'ready' position, so you just made sure they were there. Believe it was a 5-sec operation (required time) to get them on your head, for the quick-doning masks. The old joke, before the quick-doning type masks, was that the Learjet pilots always squeezed their noses before de-boarding to make it look like they had been wearing their masks. ....Edwin -- __________________________________________________ _____ "Once you have flown, you will walk the earth with your eyes turned skyward, for there you have been, there you long to return."-- da Vinci ... www.shreve.net/~elj |
"Steven P. McNicoll" wrote
(ii) At flight altitudes above flight level 350 unless one pilot at the controls of the airplane is wearing and using an oxygen mask that is secured and sealed and that either supplies oxygen at all times or automatically supplies oxygen whenever the cabin pressure altitude of the airplane exceeds 14,000 feet (MSL), except that the one pilot need not wear and use an oxygen mask while at or below flight level 410 if there are two pilots at the controls and each pilot has a quick-donning type of oxygen mask that can be placed on the face with one hand from the ready position within 5 seconds, supplying oxygen and properly secured and sealed. The Part 121 requirement for Certificated Aircarriers is more restrictive than for Part 91 Operators. The FL350 is replaced with FL 250. Bob Moore |
"Bob Moore" wrote in message 21... The Part 121 requirement for Certificated Aircarriers is more restrictive than for Part 91 Operators. The FL350 is replaced with FL 250. But still not applicable to the Greek 737 that went down yesterday, although a similar requirement may have existed for them. |
On Mon, 15 Aug 2005 23:37:07 GMT, "Steven P. McNicoll"
wrote: "Bob Moore" wrote in message . 121... The Part 121 requirement for Certificated Aircarriers is more restrictive than for Part 91 Operators. The FL350 is replaced with FL 250. But still not applicable to the Greek 737 that went down yesterday, although a similar requirement may have existed for them. What would have been the effect if the O2 bottle for the cockpit had been inadvertently filled with breathing air rather than O2? I seem to remember that this was discovered to have happened somewhere in the US in the last few months? I would think that a casual test would have found it normal, but that the PPO2 would have been substantially too low even with a pressurized mask? |
GeorgeB wrote:
What would have been the effect if the O2 bottle for the cockpit had been inadvertently filled with breathing air rather than O2? They would have tested the system before the flight and found it working. They would have put on their mask in flight and thought it worked, slowly fading away without recognizing it. You may or may not recognize hypoxia when you suspect it and really watch your body, you definitely don't recognize it when you're unwary. Stefan |
"Stefan" wrote in message ... GeorgeB wrote: What would have been the effect if the O2 bottle for the cockpit had been inadvertently filled with breathing air rather than O2? They would have tested the system before the flight and found it working. They would have put on their mask in flight and thought it worked, slowly fading away without recognizing it. You may or may not recognize hypoxia when you suspect it and really watch your body, you definitely don't recognize it when you're unwary. The question was what happens when breathing air from the mask rather than O2 and the answer is nothing at all at a cabin pressure of 10K feet. |
fred wrote:
The question was what happens when breathing air from the mask rather than O2 and the answer is nothing at all at a cabin pressure of 10K feet. Got me :-). On the other hand, if the bottels were filled with say N2 instead of O2, they would still have faded away even at 10 kft. Further speculations? Stefan |
fred wrote:
The question was what happens when breathing air from the mask rather than O2 and the answer is nothing at all at a cabin pressure of 10K feet. But the question was asked about pilots that were at 35,000'. I believe that George B. is correct that the partial pressure would be too low and the pilots would pass out. George Patterson Give a person a fish and you feed him for a day; teach a person to use the Internet and he won't bother you for weeks. |
| Thread Tools | |
| Display Modes | |
| AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 03:26 PM |
| Sport Pilot pilots not insurable? | Blueskies | Piloting | 14 | July 12th 05 06:45 AM |
| Diamond DA-40 with G-1000 pirep | C J Campbell | Instrument Flight Rules | 117 | July 22nd 04 06:40 PM |
| Diamond DA-40 with G-1000 pirep | C J Campbell | Piloting | 114 | July 22nd 04 06:40 PM |
